09-11-2021, 19:58 | #1 (permalink) |
Insane Poster Join Date: Jul 2020 Location: Warszawa Age: 45
Member: 2962418 Status: Offline Thanks Meter: 7 | Problem with AW3 42mm [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_7.6.1_18U70_n121bAP_GPS_Restore_42mm/018-33222-073.dmg' [info] Found ECID 001b0ae204f8e0a6 [info] Getting ApNonce in dfu mode... [data] EE240D08D99175DC68CBC5897579ADAB6E848D926F7093DAF4 613E7F4801BF6C [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 99A63EECC1010D495453D086B850E883E87DA621 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773156 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001b0ae204f8e0a6 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: ee 24 0d 08 d9 91 75 dc 68 cb c5 89 75 79 ad ab 6e 84 8d 92 6f 70 93 da f4 61 3e 7f 48 01 bf 6c [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773156 bytes)... [info] Device ecid 001b0ae204f8e0a6 disconnect detected! [info] device serial number is FHMWK9SNJ5X4 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9312 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807906 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32229 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13383720 bytes)... [info] Device ecid 001b0ae204f8e0a6 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 25e3d4e3982cb94adb3bd40f94c89d14c19c5780 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 7611790233493670 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Waiting for NAND (28) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Checking for uncollected logs (44) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating partition map (11) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating filesystem (12) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-33222-073.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [info] device disconnect... [erro] Could not read data (-256). Aborting. [erro] Unable to restore device [done] Operation finished! [data] ECID:6812892122447910 [data] ProductType:Apple Watch S3 [info] Using LOCAL IPSW C:\Users\jacma\Downloads\MFC_Watch3,4_7.6.1_18U70_ n121bAP_GPS_Restore_42mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001b0ae204f8e0a6 [info] Getting ApNonce in dfu mode... [data] 9689DE568BDD878B3924902278FB069D6AF83EFA9DCCEAD076 3DB56ED6D31AD4 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] A0DD2CB5E7CD2A8B874E0BD1EAC351DCEBA174F3 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_7.6.1_18U70_n121bAP_GPS_Restore_42mm/018-33222-073.dmg' [info] Found ECID 001b0ae204f8e0a6 [info] Getting ApNonce in dfu mode... [data] 9689DE568BDD878B3924902278FB069D6AF83EFA9DCCEAD076 3DB56ED6D31AD4 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] A0DD2CB5E7CD2A8B874E0BD1EAC351DCEBA174F3 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773156 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001b0ae204f8e0a6 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 96 89 de 56 8b dd 87 8b 39 24 90 22 78 fb 06 9d 6a f8 3e fa 9d cc ea d0 76 3d b5 6e d6 d3 1a d4 [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773156 bytes)... [info] Device ecid 001b0ae204f8e0a6 disconnect detected! [info] device serial number is FHMWK9SNJ5X4 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9312 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807906 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32229 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13383720 bytes)... [info] Device ecid 001b0ae204f8e0a6 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 25e3d4e3982cb94adb3bd40f94c89d14c19c5780 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 7611790233493670 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Waiting for NAND (28) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Checking for uncollected logs (44) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating partition map (11) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating filesystem (12) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Connecting to FDR client at port 49158 [info] FDR 14207150 Proxy connect request to gg.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0E2DBEA8 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 14207390 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 14207510 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 14207498 Proxy connect request to skl.apple.com:443 [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-33222-073.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [info] device disconnect... [erro] FDR 14207498 Unable to receive proxy payload (-3) [erro] Could not read data (-256). Aborting. [erro] Unable to restore device [done] Operation finished! Thanks in advance for help or suggestions |
