03-16-2021, 17:43 | #1 (permalink) |
Crazy Poster Join Date: Aug 2018
Member: 2859050 Status: Offline Thanks Meter: 4 | s4 44 gps + s5 40 gps error HELP mfc 3.5B1 help error [info] Using LOCAL IPSW C:\Users\Alex\Downloads\MFC_Watch4,2_18S801_7.3_n1 31bap_GPS_Restore_44mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131bap, Watch4,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.3 [data] Product Build: 18S801 Major: 18 [info] device serial number is FHMXN0LJKDH0 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000c7cce010a002e [info] Getting ApNonce in recovery mode... [data] 4EA29C102C0845278A7760FE57C52DC8036E61B4AF6148B867 BD5EAE4F9B4F7D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] AB2BF1EEC90BEA6250896BA5CC01AD116E46B663 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch4,2_18S801_7.3_n131bap_GPS_Restore_44mm/038-95775-059.dmg [info] Extracting filesystem [info] Found ECID 000c7cce010a002e [info] Getting ApNonce in recovery mode... [data] 4EA29C102C0845278A7760FE57C52DC8036E61B4AF6148B867 BD5EAE4F9B4F7D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] AB2BF1EEC90BEA6250896BA5CC01AD116E46B663 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1118644 bytes)... [info] Device ecid 000c7cce010a002e disconnect detected! [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:0A_ECID:000C7CCE010A002E_IBFL:3 D_SRNM:[FHMXN0LJKDH0] [info] Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:0A_ECID:000C7CCE010A002E_IBFL:3 C_SRNM:[FHMXN0LJKDH0] [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.80.19 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10947 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1722817 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1857125 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1730909 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 compon ent AOP... [info] Sending AOP (1535125 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (848101 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-96011-059.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16314 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20257 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160145 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31956 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-96011-059.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (81576088 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (39621 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5217662 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11703809 bytes)... [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:0A_ECID:000C7CCE010A002E_IBFL:3 C_SRNM:[FHMXN0LJKDH0] silent [info] Device ecid 000c7cce010a002e disconnect detected! [info] Arrival USB\VID_05AC&PID_12AF\00008006-000C7CCE010A002E silent [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-000C7CCE010A002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 10 [info] ChipID: 32774 [info] UniqueChipID: 3514923943067694 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info ] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N131B_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N131b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-96011-059.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 038-95775-059.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFi rmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Status message: Verification Error [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Removing USB\VID_05AC&PID_12AF\00008006-000C7CCE010A002E [done] Operation finished! |
