12-24-2020, 08:34 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | I cannot activate Iphone X after restoration. Imei Ok, Baseband Ok After checking and testing it, I deactivated the old owner's icloud and then formatted the device. After restarting the device, it is no longer activated. It remains on the activation screen, but does not leave it. I tried to activate through 3utools, through itunes, via wi-fi and via 4g, but the device does not activate at all. I installed IOS 14.3 and I still can't activate it. All imei and baseband information is showing up normally. The device was not jailbroken and is clean. Could it be an NFC-related problem, since the cover is destroyed and the NFC antenna is also damaged? |
The Following User Says Thank You to celltellpb For This Useful Post: |
