11-23-2017, 12:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2016 Location: iran tehran 021
Member: 2643931 Status: Offline Sonork: ****** Thanks Meter: 225 | :::::g570f not power on after frp:::: but phone is off full dead Now I have to buy 1 phone for the customer Last edited by Octopus box; 11-23-2017 at 13:24. |
The Following User Says Thank You to afghanistanmob For This Useful Post: |
11-24-2017, 09:23 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Also read and always follow these rules: http://forum.gsmhosting.com/vbb/f62/...rules-1591101/, http://forum.gsmhosting.com/vbb/f103...leted-2291568/. |
11-24-2017, 10:55 | #6 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
Code: Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\24-11-2017_09-00-56.log" created (2017/11/24 09:00:59 AM). INFO : 2017/11/24 09:01:10 AM > Set up system language English (file: English.ini) INFO : 2017/11/24 09:01:10 AM > Welcome to Octoplus Box Samsung software version 2.6.2 INFO : 2017/11/24 09:01:17 AM > ----------------------------------------------------------------------------------- INFO : 2017/11/24 09:01:17 AM > To connect SM-G935F phone you have to perform the following steps: INFO : 2017/11/24 09:01:17 AM > 1. Disconnect USB cable from phone. INFO : 2017/11/24 09:01:17 AM > 2. Go to Menu->Settings->More->About Device. INFO : 2017/11/24 09:01:17 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 2017/11/24 09:01:17 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 2017/11/24 09:01:17 AM > 5. Turn on "USB Debugging" option. INFO : 2017/11/24 09:01:36 AM > ----------------------------------------------------------------------------------- INFO : 2017/11/24 09:01:36 AM > To connect SM-G570F phone you have to perform the following steps: INFO : 2017/11/24 09:01:36 AM > 1. Disconnect USB cable from phone. INFO : 2017/11/24 09:01:36 AM > 2. Go to Menu->Settings->More->About Device. INFO : 2017/11/24 09:01:36 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 2017/11/24 09:01:36 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 2017/11/24 09:01:36 AM > 5. Turn on "USB Debugging" option. INFO : 2017/11/24 09:01:39 AM > ----------------------------------------------------------------------------------- INFO : 2017/11/24 09:01:40 AM > Platform: Samsung Android INFO : 2017/11/24 09:01:40 AM > Selected port: COM3 INFO : 2017/11/24 09:01:40 AM > Selected model: SM-G570F INFO : 2017/11/24 09:01:40 AM > Searching for UART interface.. INFO : 2017/11/24 09:01:40 AM > COM3 WARN : 2017/11/24 09:01:40 AM > Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds INFO : 2017/11/24 09:01:40 AM > Searching for device. Please wait... INFO : 2017/11/24 09:02:05 AM > Phone found. INFO : 2017/11/24 09:02:05 AM > Rebooting phone in Upload Mode... INFO : 2017/11/24 09:02:06 AM > OK WARN : 2017/11/24 09:02:15 AM > Please connect phone to USB cable.. INFO : 2017/11/24 09:02:15 AM > Searching for a phone. Please wait... INFO : 2017/11/24 09:02:16 AM > OK INFO : 2017/11/24 09:02:16 AM > Reading data... INFO : 2017/11/24 09:02:23 AM > Checking operation... INFO : 2017/11/24 09:02:23 AM > OK INFO : 2017/11/24 09:02:23 AM > Searching for UART interface.. INFO : 2017/11/24 09:02:23 AM > COM3 WARN : 2017/11/24 09:02:23 AM > Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds INFO : 2017/11/24 09:02:23 AM > Searching for device. Please wait... INFO : 2017/11/24 09:02:40 AM > Phone found. INFO : 2017/11/24 09:02:40 AM > Resetting FRP lock (1/4 attempt).. SUCC : 2017/11/24 09:03:46 AM > success WARN : 2017/11/24 09:03:46 AM > FRP / Reactivation lock is successfully reseted! INFO : 2017/11/24 09:03:52 AM > Performed by 2.6.2 Software version. Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\24-11-2017_09-00-56.log" closed (2017/11/24 09:16:51 AM). | |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
11-30-2017, 11:23 | #7 (permalink) |
Crazy Poster Join Date: Feb 2014 Location: Russia, Komsa Age: 47
Member: 2123031 Status: Offline Thanks Meter: 11 | I had the same problem. Сompletely discharge the phone. Then you can recharge it a little and flash it. |
The Following User Says Thank You to pacsik77 For This Useful Post: |
11-30-2017, 12:18 | #11 (permalink) | |
Member: 2123031 Status: Offline Thanks Meter: 11 | Quote:
After the procedure frp octopus the phone died. I will not argue further. at least press any combination of buttons. | |
