04-28-2019, 21:31 | #1 (permalink) |
No Life Poster Join Date: May 2014
Member: 2188956 Status: Offline Thanks Meter: 29 | G935T Bit 9 FRP Help [Answered] I have followed the octopus guide -load full combination sw on it, but inside developer settings it does not have OEM unlock -I have also loaded full combination software and reload stock s/w without cache, recovery, and user data. But the phone does not boot up all the way without the stock recovery it keeps bootlooping - I have tried to load just the boot from the combination software into the phone, the phone just boot loops. Anyone else know how to fix this problem? |
04-29-2019, 09:34 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. There are few methods, of how to reset FPR on phones with latest firmwares: I. Try to write SBoot file of older firmware. Repeat "Reset FRP/Reactivation/EE" operation. II. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). Perform "Reset FRP" operation in Software. 74957382 III. Write Full Combination Firmware. Go to "Developer Options" in phone Settings. Check "Enable OEM unlock" option. Make Factory Data Reset. Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service. |
