06-09-2020, 07:53 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, download and install the latest Software version then try to select from the list X420MM and perform Reset FRP operaiton, after post here full Software log Last edited by Octopus box; 06-11-2020 at 09:43. |
09-21-2020, 18:02 | #3 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | I tested and it worked: Welcome to Octoplus/Octopus Box LG Software version 3.0.3 Card S/N : 0000098F7F -------------------------------------------------------------------------------- Connecting to server ...OK Username: dombronx Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM27 Selected model: X420MM Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X220MA Incompatible model ID! IMEI: 352533103XXXX37 Android version: 8.1.0 Battery level: 43% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX220MAAT-02-V10i-310-160-AUG-23-2019-ARB00 +0 Android version: 8.1.0 LAF Version: 1.1 Product ID: YS93S190110000278 IMEI: 352533103XXXX37 Target operator: LAO Hardware: rev_10 Reading partitions...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: dombronx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "X420MM_352533103XXXX37_21-09-2020_11- 25-09.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions! |
