Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus FRP Tool
Old 09-24-2019, 14:24   #511 (permalink)
Member: 413738
Thanks Meter: 7
Platform: HUAWEI
Selected model: BND-AL10
Put the phone in FastBoot Mode:
1. Remove SD and SIM cards from the phone
2. Power phone OFF
3. Press and hold "Vol-" and insert USB cable
4. Wait until the phone enter in FastBoot Mode
Searching for a phone. Please wait...
Detected phone model: BND-AL10
Phone SN: QDT4C17C03010094
Phone IMEI:
Phone IMEI2:
SW version: BND-AL10 8.0.0.370(C675)
Connecting to server..OK
Authorizing...OK
Resetting FRP lock..
Operation was failed!
Performed by 1.7.9.0 Software version.
Old 09-25-2019, 20:47   #512 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 160
please add
tablet admiral one mundial
cpu: RK3126C
android: 7.1.2
loader protect
Old 09-26-2019, 13:10   #513 (permalink)
Member: 2812901
Thanks Meter: 493
Plz add LAVA Z62 from solutions
Old 09-27-2019, 07:23   #514 (permalink)
Member: 1344629
Thanks Meter: 24
please Add oppo A5s factory reset and frp remove
Old 09-30-2019, 13:24   #515 (permalink)
Member: 848042
Thanks Meter: 2
add Nokia 3 -TA-1032 brom version 05 , please !
Old 10-04-2019, 03:19   #516 (permalink)
Member: 2616002
Please add Sony Xperia Smartphone
Old 10-04-2019, 17:55   #517 (permalink)
Member: 2643931
Sonork: ******
Thanks Meter: 225
hi team
please update spd
Old 10-05-2019, 22:43   #518 (permalink)
Member: 2812901
Thanks Meter: 493
Plz add Lenovo k320t frp support.
The Following User Says Thank You to Oyetunde Semiu For This Useful Post:
Old 10-08-2019, 10:36   #519 (permalink)
Member: 1534323
Sonork: 578316251
Thanks Meter: 6
INFO : 08.10.2019 11:03:11 > Connecting to server...
INFO : 08.10.2019 11:03:11 > Username: gssfactoxxxxxxxx
INFO : 08.10.2019 11:03:11 > Authorizing...
INFO : 08.10.2019 11:03:12 > Checking balance...
WARN : 08.10.2019 11:03:12 > Your balance: 100 credits.
INFO : 08.10.2019 11:03:12 > Performed by 1.8.0.0 Software version.
INFO : 08.10.2019 11:04:25 > Platform: XIAOMI
INFO : 08.10.2019 11:04:25 > Selected model: MI MIX 2S
WARN : 08.10.2019 11:04:25 > Please, select one of the options for "Reset Mi Account" operation or press Ok to continue...
WARN : 08.10.2019 11:04:36 > Go to "Wi-Fi Settings" and forget connected Wi-Fi network or perform Wipe Data from recovery
WARN : 08.10.2019 11:04:36 > Put the phone into EDL mode:
WARN : 08.10.2019 11:04:36 > 1. Attach testpoint as shown in Help manual;
WARN : 08.10.2019 11:04:36 > 2. Connect USB cable;
WARN : 08.10.2019 11:04:36 > 3. Release testpoint after 3-5 seconds.
INFO : 08.10.2019 11:04:36 > Found phone on COM224
INFO : 08.10.2019 11:04:36 > Mode: Qualcomm 9008
INFO : 08.10.2019 11:04:37 > Connecting...
INFO : 08.10.2019 11:04:39 > Reading info...
INFO : 08.10.2019 11:04:39 > QC HW ID: 0008B0E100720000
INFO : 08.10.2019 11:04:39 > QC CPU: Snapdragon 845 SDM845
INFO : 08.10.2019 11:04:39 > QC SW VER: 00000001
INFO : 08.10.2019 11:04:39 > Searching loader...
INFO : 08.10.2019 11:04:42 > Sending loaders...
INFO : 08.10.2019 11:05:03 > Loader send successfuly.
INFO : 08.10.2019 11:05:03 > Reconnecting...
INFO : 08.10.2019 11:05:11 > Chip SN: 5E7E6DC7
INFO : 08.10.2019 11:05:11 > Checking request..
INFO : 08.10.2019 11:05:11 > Connecting to server...
INFO : 08.10.2019 11:05:12 > Checking smart card...
INFO : 08.10.2019 11:05:14 > Username: gssfactoxxxxxxxx
INFO : 08.10.2019 11:05:14 > Authorizing...
INFO : 08.10.2019 11:05:14 > Checking balance...
WARN : 08.10.2019 11:05:14 > Your balance: 100 credits.
INFO : 08.10.2019 11:05:14 > Checking operation...
INFO : 08.10.2019 11:05:15 > Operation successfully checked.
INFO : 08.10.2019 11:05:15 > Sending device information...
INFO : 08.10.2019 11:05:16 > Get credits, needed for current operation...
WARN : 08.10.2019 11:05:16 > Your balance: 100 credits. Need: 15 credits.
INFO : 08.10.2019 11:05:19 > Start Authentication...
INFO : 08.10.2019 11:05:19 > Connecting to server..
INFO : 08.10.2019 11:05:20 > OK
INFO : 08.10.2019 11:05:20 > Authorizing...
INFO : 08.10.2019 11:05:20 > Initializing..
INFO : 08.10.2019 11:05:20 > Calculating...
INFO : 08.10.2019 11:05:29 > Authentication done!
INFO : 08.10.2019 11:05:29 > Checking request..
INFO : 08.10.2019 11:05:29 > Reading partition...
INFO : 08.10.2019 11:05:29 > Reading info...
INFO : 08.10.2019 11:05:29 > Brand: Xiaomi
INFO : 08.10.2019 11:05:29 > Model: Mi MIX 2S
INFO : 08.10.2019 11:05:29 > Device: polaris
INFO : 08.10.2019 11:05:29 > Android version: 8.0.0
INFO : 08.10.2019 11:05:29 > Display ID: OPR1.170623.032
INFO : 08.10.2019 11:05:29 > Firmware version: V10.0.2.0.ODGMIFH
INFO : 08.10.2019 11:05:30 > Resetting Mi Account...
WARN : 08.10.2019 11:05:30 > On Your device detected FRP Lock! Reset it?
If "Yes" operation will cost as Reset FRP + Reset Mi Account operations.
INFO : 08.10.2019 11:06:30 > Get credits, needed for current operation...
WARN : 08.10.2019 11:06:31 > Your balance: 100 credits. Need: 30 credits.
INFO : 08.10.2019 11:06:48 > Reading MI part...
INFO : 08.10.2019 11:06:58 > Writing MI part...
INFO : 08.10.2019 11:07:02 > Resetting FRP lock..
INFO : 08.10.2019 11:07:02 > Rebooting phone
INFO : 08.10.2019 11:07:02 > Backup saved as Xiaomi_Mi MIX 2S_08-10-2019_11-07-02.dump file
WARN : 08.10.2019 11:07:02 > Please power phone ON and enable "USB Debugging" then press "OK" button!
ERROR : 08.10.2019 11:07:02 >
If operation wasn't completed, then Your device get re-locked and credits aren't refundable!
INFO : 08.10.2019 11:09:39 > Searching for a phone (waiting for ADB device)...
ERROR : 08.10.2019 11:10:09 > Proper android device not found. Make shure that "USB debug" option on the device is turned on.
INFO : 08.10.2019 11:10:09 >
ERROR : 08.10.2019 11:10:09 > Don't connect to Wi-Fi spot, until operation isn't completed!
ERROR : 08.10.2019 11:10:09 > Please, perform operation again with selected "Disable MI Services (Prevent Re-lock)"
xiaomi stay locked ,credits is gon ,please refund my credits
Old 10-09-2019, 09:29   #520 (permalink)
Member: 2243017
Thanks Meter: 29
huawei dra-lx5
hi team.i tryd 3 pc of dra-lx5 frp reset but it always fails.pleas fix it
Old 10-12-2019, 09:42   #521 (permalink)
akhtar.abbas's Avatar
Member: 1190193
Sonork: 1619687
Thanks Meter: 406
Alcatel a3a OR Alcatel 5058i -Android version: 8.1.0 PLZ add
Old 10-13-2019, 09:43   #522 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Please ADD In Next Update In Vivo Y91i (1816) & Vivo Y81i ( 1812 )
mtk new series not going reboot with adb method & Not W
Old 10-13-2019, 09:56   #523 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Please ADD These model In Next Update In Vivo Y91i (1816) & Vivo Y81i ( 1812 )
mtk new series not going reboot with adb method & Not Work QC Method For FRP Remove Method
Please ADD These model Direct FRP In Octoplus FRP Tool
Thanks & regards By:All TECH 4 You
Old 10-16-2019, 04:24   #524 (permalink)
dineshras's Avatar
Member: 2185083
Sonork: 100.1670782:dineshras
Thanks Meter: 185
Xiaomi RedMi Note 3G (2013121) MTK CPU mi account add team
Old 10-21-2019, 15:14   #525 (permalink)
Member: 1813122
Thanks Meter: 24
Please add oppo new version
Page generated in 0.19280 seconds with 10 queries
