04-22-2021, 01:04 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | Q720CS frp process failed [Answered] INFO : 21/4/2021 5:37:20 p. m. > Connecting to server... INFO : 21/4/2021 5:37:21 p. m. > Username: dombronx INFO : 21/4/2021 5:37:21 p. m. > Authorizing... INFO : 21/4/2021 5:37:23 p. m. > Checking balance... WARN : 21/4/2021 5:37:24 p. m. > Your balance: 100 credits. INFO : 21/4/2021 5:37:24 p. m. > Performed by 2.0.0.0 Software version. INFO : 21/4/2021 5:37:24 p. m. > INFO : 21/4/2021 5:37:41 p. m. > Work ID: 0000000000E8322D INFO : 21/4/2021 5:37:41 p. m. > Platform: LG INFO : 21/4/2021 5:37:41 p. m. > Selected model: Q720CS WARN : 21/4/2021 5:37:41 p. m. > Put the phone into Download Mode: WARN : 21/4/2021 5:37:41 p. m. > 1. Power phone OFF; WARN : 21/4/2021 5:37:41 p. m. > 2. Press and hold "Vol+" button and connect USB cable. INFO : 21/4/2021 5:37:41 p. m. > Searching for a phone. Please wait... INFO : 21/4/2021 5:37:42 p. m. > Found phone on COM129 INFO : 21/4/2021 5:37:42 p. m. > Reading info... INFO : 21/4/2021 5:37:43 p. m. > Detected phone model: LM-Q720CS INFO : 21/4/2021 5:37:43 p. m. > Mode: Emergency INFO : 21/4/2021 5:37:43 p. m. > Initializing.. INFO : 21/4/2021 5:37:48 p. m. > SW version: LMQ720CSAT-01-V10k-310-150-AUG-23-2019-ARB00+0 INFO : 21/4/2021 5:37:48 p. m. > Android version: 9 INFO : 21/4/2021 5:37:48 p. m. > Platform: msm8953 INFO : 21/4/2021 5:37:48 p. m. > Reading partition... INFO : 21/4/2021 5:41:11 p. m. > Searching for signatures... INFO : 21/4/2021 5:41:11 p. m. > Connecting to server... INFO : 21/4/2021 5:41:13 p. m. > Checking smart card... INFO : 21/4/2021 5:41:19 p. m. > Username: dombronx INFO : 21/4/2021 5:41:19 p. m. > Authorizing... INFO : 21/4/2021 5:41:22 p. m. > Checking balance... WARN : 21/4/2021 5:41:23 p. m. > Your balance: 100 credits. INFO : 21/4/2021 5:41:23 p. m. > Checking operation... INFO : 21/4/2021 5:41:25 p. m. > Operation successfully checked. INFO : 21/4/2021 5:41:25 p. m. > Sending device information... INFO : 21/4/2021 5:41:25 p. m. > Get credits, needed for current operation... WARN : 21/4/2021 5:41:26 p. m. > Your balance: 100 credits. Need: 100 credits. INFO : 21/4/2021 5:42:31 p. m. > Reading partition... It Stuck forever |
04-22-2021, 03:55 | #2 (permalink) |
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | Also tried with LG Tool and failed the connection too. Plz refund the 2 attempts. user: dombronx THANKS Welcome to Octoplus/Octopus Box LG Software version 3.1.1.03 Card S/N : 0000098F7F -------------------------------------------------------------------------------- Work ID: 0000000000E840C9 Checking data...OK Platform: LG Qualcomm Selected port: COM23 Selected model: Q720CS Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-Q720CS IMEI: 355691-10-289xxx-4 Android version: 9 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ720CSAT-01-V10k-310-150-AUG-23-2019- ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: VS03S190909003293 IMEI: 355691-10-289xxx-4 Target operator: LAO Hardware: rev_10 Reading partitions...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: dombronx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "Q720CS_35569110289xxx4_21-04-2021_19- 51-54.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions! Failed! Performed by 3.1.1.03 Software version. |
