12-27-2018, 22:21 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | Samsung SM-J530F Combination firmware question [Answered] I wanted to use COMBINATION_FAC_FA70_J530FMXXU1AQG2_FAC_CL11896694 _QB14311229_REV01_user_mid_noship.oct but it does not work. When trying to flash the complete file I received secure check fail error When I tried to flash only boot.img I received custom binary (boot) Blocked by FRP Lock Is there any further solution? Thanks Last edited by Octopus box; 12-28-2018 at 05:38. |
12-28-2018, 09:52 | #3 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | The phone can be started in download mode only, it can not be started in recovery mode( it is blocked ). So, how can I check the current version of software in the mobile? Thank you for help |
12-28-2018, 10:00 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | First of all check http://forum.gsmhosting.com/vbb/f103...wares-2336370/. after try to use another combination firmware. Post here full Software log. |
12-28-2018, 10:27 | #5 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Here is the log Selected firmware file: COMBINATION_FAC_FA70_J530FMXXU1AQG2_FAC_CL11896694 _QB14311229_REV01_user_mid_noship.oct Platform: SAMSUNG Selected model: SM-J530F Please put the phone into Download Mode and connect USB cable. To put SM-J530F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing Firmware Failed Performed by 1.5.5.0 Software version. and mobile says secure check fail |
12-28-2018, 12:35 | #7 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | I tried COMBINATION_FAC_FA70_J530YDXU2AQJ3_FAC2AQJ3_CL1216 6159_QB15370348_REV01_user_mid_noship.oct but the result the same. When trying to load the complete file I receieve Selected firmware file: COMBINATION_FAC_FA70_J530YDXU2AQJ3_FAC2AQJ3_CL1216 6159_QB15370348_REV01_user_mid_noship.oct Platform: SAMSUNG Selected model: SM-J530F Please put the phone into Download Mode and connect USB cable. To put SM-J530F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... Writing firmware Canceled Performed by 1.5.6.0 Software version. and mobile says secure check fail when I try ONLY boot.img Platform: SAMSUNG Selected model: SM-J530F Please put the phone into Download Mode and connect USB cable. To put SM-J530F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing Firmware Failed Performed by 1.5.6.0 Software version. and mobile says Custom Binary (BOOT) Blocked by FRP Lock Do you have any further idea? Thanks |
