Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 01-14-2021, 12:57   #1 (permalink)
Member: 2909174
Sonork: 100.650600
Thanks Meter: 77
Huawei MED LX9 imei repair not change [Answered]
Welcome to Octoplus Huawei Software v.‪1.2.3‬
To enable 'Manufacture' mode dial
- for Qualcomm and Hisilicon based models: *#*#2846579#*#*
ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
- for MTK based models: *#*#14789632#*#*
ProjectMenu > Background Settings > USB Port Settings > Debug Mode
To enable 'Fastboot' mode
1. Power off the phone. Remove SD and SIM cards
2. Press 'Vol-' and insert USB cable
3. Wait until phone enters 'Fastboot' mode
To enable 'Upgrade' mode
2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable
3. Wait until phone enters 'Upgrade mode'
Found COM ports:
1: COM1 Communications Port
2: COM8 USB Serial Port
3: COM32 Intel(R) Active Management Technology - SOL
4: COM52 Android Adapter PCUI
5: COM53 HUAWEI Mobile Connect - Fake Acm Interface
6: COM54 DBAdapter Reserved Interface
Job ID: 00000000006B7FF5
2021-01-14 11:40:21 GMT -------------------------------------------------
Starting Connect
Selected phone model: ‪MED-LX9‬
Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable
Canceling... Please be patient!
MediaTek USB Port is not found
Connect failed.
Performed by ‪1.2.3‬ Software version.
Job ID: 00000000006B8013
2021-01-14 11:40:39 GMT -------------------------------------------------
Starting Connect
Connect failed.
Job ID: 00000000006B8022
2021-01-14 11:40:49 GMT -------------------------------------------------
Starting ON/OFF Factory Mode
Selected phone model: MED-LX9
To Enable Factory mode put the phone in Upgrade mode and connect USB cable!
To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode!
Checking the existence of the auto firmware file...
Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation.
ON/OFF Factory Mode failed.
Job ID: 00000000006B82C6
2021-01-14 11:48:02 GMT -------------------------------------------------
Performing ON Factory Mode operation...
Initializing remote service connection...
Checking firmware package type
Searching device in Upgrade mode...
Connecting to phone..
Phone connect successfully!
Writing firmware partitions...
Writing ‪SHA256RSA‬ partition...
Writing ‪CRC‬ partition...
Writing ‪BASE_VERLIST‬ partition...
Writing ‪BASE_VER‬ partition...
Writing ‪PACKAGE_TYPE‬ partition...
Writing ‪EFI‬ partition...
ON/OFF Factory Mode done.
Job ID: 00000000006B832B
2021-01-14 11:49:12 GMT -------------------------------------------------
Starting Connect
Detecting Chip Version...
HW Chip : MT6765
HW Version : 8A00.CA00.0000.0000
Brom Version: 5
Boot Loader Version: FE
Sending Authentication Data
Sending Download Agent...
DA successfully sent
Synchronizing with DA...
Mobile Status: SYNC
Mobile Status: brom
Sending BootLoader Info...
Initializing Memory Flash...
Initialization completed
Sending Loader...
Mobile Status: SYNC
Loader successfully sent
Reading Flash Info...
EMMC rpmb size : 16 Mb
EMMC boot1 size : 4 Mb
EMMC boot2 size : 4 Mb
EMMC gp1 size : 0 Mb
EMMC gp2 size : 0 Mb
EMMC gp3 size : 0 Mb
EMMC gp4 size : 0 Mb
EMMC user area size : 59640 Mb
IMEI A: ‪868800048305241‬
IMEI B: ‪868800048305258‬
Connect done.
Job ID: 00000000006B83AB
2021-01-14 11:50:34 GMT -------------------------------------------------
Starting Repair Info
New IMEI A: ‪354647912069887‬
New IMEI B: ‪354647912069895‬
Creating partition backup: ‪MED-LX9_nvram_2021-01-14_16-50-35.bin‬
Writing secure data...
Please perform a Factory Data Reset of your device manually through Recovery mode.
Repair Info done.
Job ID: 00000000006B8412
2021-01-14 11:51:42 GMT -------------------------------------------------
HW Chip : MT6765
Brom Version: 5
Mobile Status: SYNC
Mobile Status: brom
Sending Loader...
Mobile Status: SYNC
Writing PRELOADER partition...
Writing PRELOADER_BACKUP partition...
Old 01-14-2021, 12:58   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
Please, try to do Factory Reset, after Repair IMEI operation was completed
Page generated in 0.14223 seconds with 8 queries
