01-14-2021, 12:57 | #1 (permalink) |
Freak Poster Join Date: May 2019 Location: Gujranwala
Member: 2909174 Status: Offline Sonork: 100.650600 Thanks Meter: 77 | Huawei MED LX9 imei repair not change [Answered] To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM8 USB Serial Port 3: COM32 Intel(R) Active Management Technology - SOL 4: COM52 Android Adapter PCUI 5: COM53 HUAWEI Mobile Connect - Fake Acm Interface 6: COM54 DBAdapter Reserved Interface Job ID: 00000000006B7FF5 2021-01-14 11:40:21 GMT ------------------------------------------------- Starting Connect Selected phone model: MED-LX9 Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable Canceling... Please be patient! MediaTek USB Port is not found Connect failed. Performed by 1.2.3 Software version. Job ID: 00000000006B8013 2021-01-14 11:40:39 GMT ------------------------------------------------- Starting Connect Selected phone model: MED-LX9 Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable Canceling... Please be patient! MediaTek USB Port is not found Connect failed. Performed by 1.2.3 Software version. Job ID: 00000000006B8022 2021-01-14 11:40:49 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: MED-LX9 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Checking the existence of the auto firmware file... Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.3 Software version. Job ID: 00000000006B82C6 2021-01-14 11:48:02 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: MED-LX9 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Checking the existence of the auto firmware file... Performing ON Factory Mode operation... Initializing remote service connection... Checking firmware package type Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Writing BASE_VER partition... Writing PACKAGE_TYPE partition... Writing EFI partition... ON/OFF Factory Mode done. Performed by 1.2.3 Software version. Job ID: 00000000006B832B 2021-01-14 11:49:12 GMT ------------------------------------------------- Starting Connect Selected phone model: MED-LX9 Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable Detecting Chip Version... HW Chip : MT6765 HW Version : 8A00.CA00.0000.0000 Brom Version: 5 Boot Loader Version: FE Sending Authentication Data Sending Download Agent... DA successfully sent Synchronizing with DA... Mobile Status: SYNC Mobile Status: brom Sending BootLoader Info... Initializing Memory Flash... Initialization completed Sending Loader... Mobile Status: SYNC Loader successfully sent Reading Flash Info... EMMC rpmb size : 16 Mb EMMC boot1 size : 4 Mb EMMC boot2 size : 4 Mb EMMC gp1 size : 0 Mb EMMC gp2 size : 0 Mb EMMC gp3 size : 0 Mb EMMC gp4 size : 0 Mb EMMC user area size : 59640 Mb IMEI A: 868800048305241 IMEI B: 868800048305258 Connect done. Performed by 1.2.3 Software version. Job ID: 00000000006B83AB 2021-01-14 11:50:34 GMT ------------------------------------------------- Starting Repair Info New IMEI A: 354647912069887 New IMEI B: 354647912069895 Creating partition backup: MED-LX9_nvram_2021-01-14_16-50-35.bin Writing secure data... Please perform a Factory Data Reset of your device manually through Recovery mode. Repair Info done. Performed by 1.2.3 Software version. Job ID: 00000000006B8412 2021-01-14 11:51:42 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: MED-LX9 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable Detecting Chip Version... HW Chip : MT6765 HW Version : 8A00.CA00.0000.0000 Brom Version: 5 Boot Loader Version: FE Sending Authentication Data Sending Download Agent... DA successfully sent Synchronizing with DA... Mobile Status: SYNC Mobile Status: brom Sending BootLoader Info... Initializing Memory Flash... Initialization completed Sending Loader... Mobile Status: SYNC Loader successfully sent Reading Flash Info... EMMC rpmb size : 16 Mb EMMC boot1 size : 4 Mb EMMC boot2 size : 4 Mb EMMC gp1 size : 0 Mb EMMC gp2 size : 0 Mb EMMC gp3 size : 0 Mb EMMC gp4 size : 0 Mb EMMC user area size : 59640 Mb Writing PRELOADER partition... Writing PRELOADER_BACKUP partition... ON/OFF Factory Mode done. Performed by 1.2.3 Software version. |
