![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | ![]() Starting Connect Selected phone model: COL-L29 Searching HUAWEI USB COM 1.0 port... Error: HUAWEI USB COM 1.0 port not found Searching Fastboot devices... Warning: Reading serial number failed Device Model: COL-L29 System: COL-L29 10.0.0.177(C432E3R1P4) Connect done. Performed by 1.2.0.1 Software version. Selected base file: C:/Users/expor/Downloads/col_l29_2/PTABLE.APP PACKAGE_TYPE: OFFLINE_UPDATE Selected phone model: COL-L29 2020-08-19 14:51:54 GMT ------------------------------------------------- Starting Write Firmware(Fastboot mode) Searching Fastboot devices... Warning: Reading serial number failed Device Model: COL-L29 System: COL-L29 10.0.0.177(C432E3R1P4) Extracting firmware partitions... Partitions has been extracted successfully Writing BASE_VERLIST partition... Warning: Writing BASE_VERLIST partition failed Connecting to server... Error: Writing BASE_VERLIST partition failed Error: Writing BASE_VER partition failed Error: Writing ptable partition failed Switching to Upgrade Mode... Write Firmware(Fastboot mode) failed. Performed by 1.2.0.1 Software version. Is it a problem of firmware versions? Should I first try to use a board firmware - in case current firmware is damaged badly? Besides I can not start UPGRADE Mode ( Press and hold 'Vol-' and 'Vol+' keys and insert USB cable). Thank you for help |
![]() | #3 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for reply. I tried to write board firmware but failed Starting Write Firmware(Board mode) Searching HUAWEI USB COM 1.0 port... Phone connect successfully Updating bootloader... Writing xloader partition.. Writing uce partition.. Error: Failed write uce partition Write Firmware(Board mode) failed. Performed by 1.2.0.1 Software version. I used Columbia-BD 1.0.0.41_Board Software_general_8.1.0_r1_EMUI8.1_05022HLW and Columbia-BD 1.0.0.33_Board Software_general_Android 8.1.0_EMUI8.1.0_05022HLW The phone is Device Model: COL-L29 System: COL-L29 10.0.0.177D(C432E3) Where can be a problem? Thanks Last edited by Jane1; 08-21-2020 at 13:48. |
![]() | #4 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,163 | Please check if your firmware has the folder "update_nv_bootloader_block", if it does, rename it to "update_nv_bootloader" and select the file "update_nv_rback.xml" when selecting the firmware in the software, then repeat the operation. |
The Following User Says Thank You to Octopus support For This Useful Post: |
![]() | #5 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thank you for that idea. It worked. I flashed the board firmware Columbia-BD 1.0.0.41_Board Software_general_8.1.0_r1_EMUI8.1_05022HLW but I can not flash the firmware via UPGRADE mode Starting Write Firmware(Upgrade mode) Checking firmware package type Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Error: Failed write BASE_VERLIST partition Write Firmware(Upgrade mode) failed. Performed by 1.2.0.1 Software version. Via upgrade mode I tried to flash Columbia-L29D 9.0.0.162(C432E4R1P9)_Firmware_9.0.0_r3_EMUI9.0.0_ Is there a problem in that firmware version? Thank you for your reply |
![]() | #7 (permalink) | |
Member: 1212133 Status: Offline Thanks Meter: 58 | Quote:
But one more thing. The phone is not seen in Windows explorer eventhough I set USE USB TO as Transfer files choice. Where can be a problem? Thanks | |
![]() | #8 (permalink) | |
![]() | #9 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Oct 2009 Location: Romania, Bucharest
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,442 | Quote:
