02-15-2022, 15:43 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,162 | Hello. Please, perform Read Info operation via Fastboot mode and post here results. We'll check it. Last edited by Octopus support; 02-16-2022 at 08:20. |
02-16-2022, 07:08 | #3 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,283 | Quote:
Code: Welcome to Octoplus Huawei Software v.1.2.8 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM4 USB Serial Port 3: COM76 RIM Virtual Serial Port v2 4: COM82 RIM Virtual Serial Port v2 Job ID: 00000000024083CD 2022-02-16 06:06:29 Starting Read Info Selected phone model: ELS-NX9 Searching Fastboot devices... Found android device: K5J0220C17003773 Detected Android Sooner Single ADB Interface port Device Model: ELS-N29 System: ELS-N29 11.0.0.182(C185E2R6P3) Android Version: 10 Base Version: ELS-LGRP4-OVS 11.0.0.249 Custom Version: ELS-N29-CUST 11.0.0.6(C185) Preload Version: ELS-N29-PRELOAD 11.0.0.3(C185R6) C_Version: C185 D_Version: D000 Read Info done. Performed by 1.2.8 Software version. Last edited by Octopus support; 02-16-2022 at 08:20. | |
02-16-2022, 09:48 | #4 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,162 | Hello. Try to use other USB cable and other USB port on motherboard and close all third party Software (Samsung Kies, Android managers, modem dashboards, etc.). Disconnect all third party devices from PC (other phones, modems, boxes, etc.) and connect your device directly to USB port of PC motherboard. Also, you have 2 RIM Virtual Serial Port v2, they may have a bad effect on the operation of the Octoplus Software. |
The Following User Says Thank You to Octopus support For This Useful Post: |
02-16-2022, 13:23 | #5 (permalink) | |
this not tht issue just fix 2 phone higher ver when customer downgrade phone then phone don't want boot up even with tp all software in market even try **** cant get right i hve two phone both them some one downgrade it now no fast boot r upgrade mode working even e recover cant download latest firmware even this fast i get info only modify cable Found COM ports: 1: COM1 Communications Port 2: COM4 USB Serial Port 3: COM76 RIM Virtual Serial Port v2 4: COM82 RIM Virtual Serial Port v2 Job ID: 000000000240F00C 2022-02-16 12:22:03 Starting Read Info Selected phone model: ELS-NX9 Searching Fastboot devices... Found android device: K5J0221105000379 Detected Android Sooner Single ADB Interface port Device Model: ELS-N29 System: ELS-N29 11.0.0.182(C185E2R6P3) Android Version: 10 Base Version: ELS-LGRP4-OVS 11.0.0.201 Custom Version: ELS-N29-CUST 11.0.0.2(C185) Preload Version: ELS-N29-PRELOAD 11.0.0.3(C185R6) C_Version: C185 D_Version: D000 Read Info done. Performed by 1.2.8 Software version. Last edited by Octopus support; 02-16-2022 at 14:29. | |
02-16-2022, 16:28 | #6 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,162 | Hello. We are still working on resolving this issue. Also, please check your PM. Last edited by Octopus support; 02-17-2022 at 09:34. |
