02-07-2022, 14:45 | #1 (permalink) |
Junior Member Join Date: Aug 2018
Member: 2859643 Status: Offline Thanks Meter: 2 | g630-u10 repair imei failed [Solved] Welcome to Octoplus Huawei Software v.1.2.8 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM27 DBAdapter Reserved Interface 2: COM1 Communications Port 3: COM5 USB Serial Port 4: COM23 Android Adapter PCUI 5: COM26 Android Adapter Modem Job ID: 000000000236C98D 2022-02-07 13:41:58 Starting Repair Info Selected phone model: G630-U10 Detected DBAdapter Reserved Interface port Error: Platform verification failed Repair Info failed. Performed by 1.2.8 Software version. |
02-07-2022, 14:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Hello. Please, post here full software log of Repair Imei operation, we will check it. You can find Software log here: C:\Program Files (x86)\Octoplus\Octoplus_Huawei\LOG folder |
02-07-2022, 15:01 | #3 (permalink) |
Member: 2859643 Status: Offline Thanks Meter: 2 | 022-02-07 14:00:19.896 Loading application settings 2022-02-07 14:00:19.920 Refreshing serial ports list 2022-02-07 14:00:19.942 Found COM ports: 2022-02-07 14:00:19.944 1: COM27 DBAdapter Reserved Interface 2022-02-07 14:00:19.944 2: COM1 Communications Port 2022-02-07 14:00:19.944 3: COM5 USB Serial Port 2022-02-07 14:00:19.944 4: COM23 Android Adapter PCUI 2022-02-07 14:00:19.944 5: COM26 Android Adapter Modem 2022-02-07 14:00:20.509 Welcome to Octoplus Huawei Software v.1.2.8 2022-02-07 14:00:20.510 2022-02-07 14:00:20.510 To enable 'Manufacture' mode dial 2022-02-07 14:00:20.510 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2022-02-07 14:00:20.511 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2022-02-07 14:00:20.511 - for MTK based models: *#*#14789632#*#* 2022-02-07 14:00:20.511 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2022-02-07 14:00:20.512 2022-02-07 14:00:20.512 To enable 'Fastboot' mode 2022-02-07 14:00:20.512 1. Power off the phone. Remove SD and SIM cards 2022-02-07 14:00:20.513 2. Press 'Vol-' and insert USB cable 2022-02-07 14:00:20.513 3. Wait until phone enters 'Fastboot' mode 2022-02-07 14:00:20.513 2022-02-07 14:00:20.514 To enable 'Upgrade' mode 2022-02-07 14:00:20.514 1. Power off the phone. Remove SD and SIM cards 2022-02-07 14:00:20.514 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2022-02-07 14:00:20.515 3. Wait until phone enters 'Upgrade mode' 2022-02-07 14:00:21.529 Refreshing serial ports list 2022-02-07 14:00:21.550 Found COM ports: 2022-02-07 14:00:21.553 1: COM27 DBAdapter Reserved Interface 2022-02-07 14:00:21.553 2: COM1 Communications Port 2022-02-07 14:00:21.554 3: COM5 USB Serial Port 2022-02-07 14:00:21.554 4: COM23 Android Adapter PCUI 2022-02-07 14:00:21.555 5: COM26 Android Adapter Modem 2022-02-07 14:00:21.645 Init finished 2022-02-07 14:00:32.949 Refreshing serial ports list 2022-02-07 14:00:32.987 Found COM ports: 2022-02-07 14:00:32.991 1: COM27 DBAdapter Reserved Interface 2022-02-07 14:00:32.991 2: COM1 Communications Port 2022-02-07 14:00:32.991 3: COM5 USB Serial Port 2022-02-07 14:00:32.991 4: COM23 Android Adapter PCUI 2022-02-07 14:00:32.991 5: COM26 Android Adapter Modem 2022-02-07 14:01:01.487 Job ID: 000000000236D0CE 2022-02-07 14:01:01.917 2022-02-07 14:01:01 2022-02-07 14:01:02.131 Starting Repair Info 2022-02-07 14:01:02.342 Selected phone model: G630-U10 2022-02-07 14:01:02.600 Detected DBAdapter Reserved Interface port 2022-02-07 14:01:03.654 Platform verification failed 2022-02-07 14:01:03.865 2022-02-07 14:01:04.077 Repair Info failed. 2022-02-07 14:01:04.291 Performed by 1.2.8 Software version. |
02-07-2022, 16:07 | #5 (permalink) | |
Member: 2859643 Status: Offline Thanks Meter: 2 | Quote:
but in device manager in ports(com&lpt) showing: android adapter pcui(com23) communications port(com1) dbadapter reserved interface (com27) printer port(lpt1) usb serial port (com5) | |
02-08-2022, 08:54 | #8 (permalink) | |
2022-02-08 05:42:56.296 Refreshing serial ports list 2022-02-08 05:42:56.320 Found COM ports: 2022-02-08 05:42:56.323 1: COM1 Communications Port 2022-02-08 05:42:56.323 2: COM27 DBAdapter Reserved Interface 2022-02-08 05:42:56.323 3: COM5 USB Serial Port 2022-02-08 05:42:56.323 4: COM23 Android Adapter PCUI 2022-02-08 05:42:56.323 5: COM26 Android Adapter Modem 2022-02-08 05:42:56.891 Welcome to Octoplus Huawei Software v.1.2.8 2022-02-08 05:42:56.891 2022-02-08 05:42:56.891 To enable 'Manufacture' mode dial 2022-02-08 05:42:56.892 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2022-02-08 05:42:56.892 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2022-02-08 05:42:56.892 - for MTK based models: *#*#14789632#*#* 2022-02-08 05:42:56.892 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2022-02-08 05:42:56.893 2022-02-08 05:42:56.893 To enable 'Fastboot' mode 2022-02-08 05:42:56.893 1. Power off the phone. Remove SD and SIM cards 2022-02-08 05:42:56.894 2. Press 'Vol-' and insert USB cable 2022-02-08 05:42:56.894 3. Wait until phone enters 'Fastboot' mode 2022-02-08 05:42:56.894 2022-02-08 05:42:56.895 To enable 'Upgrade' mode 2022-02-08 05:42:56.895 1. Power off the phone. Remove SD and SIM cards 2022-02-08 05:42:56.896 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2022-02-08 05:42:56.896 3. Wait until phone enters 'Upgrade mode' 2022-02-08 05:42:58.015 Refreshing serial ports list 2022-02-08 05:42:58.036 Found COM ports: 2022-02-08 05:42:58.039 1: COM1 Communications Port 2022-02-08 05:42:58.039 2: COM27 DBAdapter Reserved Interface 2022-02-08 05:42:58.040 3: COM5 USB Serial Port 2022-02-08 05:42:58.040 4: COM23 Android Adapter PCUI 2022-02-08 05:42:58.041 5: COM26 Android Adapter Modem 2022-02-08 05:42:58.133 Init finished 2022-02-08 05:43:23.016 Job ID: 00000000023782A5 2022-02-08 05:43:23.364 2022-02-08 05:43:23 2022-02-08 05:43:23.537 Starting Repair Info 2022-02-08 05:43:23.710 Selected phone model: G630-U10 2022-02-08 05:43:23.926 Detected DBAdapter Reserved Interface port 2022-02-08 05:43:26.470 Connecting to server... 2022-02-08 05:43:26.643 Check auth 0 2022-02-08 05:43:27.656 Authorization is successful 2022-02-08 05:43:31.372 Device Model: G630_U00 2022-02-08 05:43:31.546 Firmware: HD1G630M 2022-02-08 05:43:31.720 Boot: MSM8x1xC00B140_BOOT 2022-02-08 05:43:31.895 System: G630-U10V100R001C00B159_SYSTEM 2022-02-08 05:43:32.069 Recovery: G630-U10V100R001C00B159_RECOVERY 2022-02-08 05:43:32.244 MEID: 00000000000000 2022-02-08 05:43:32.418 PESN: 00000000 2022-02-08 05:43:32.595 IMEI A: *************** 2022-02-08 05:43:32.767 IMEI B: *************** 2022-02-08 05:43:32.943 Bluetooth MAC: 58:2A:F7:F0:A9:6D 2022-02-08 05:43:33.120 WiFi MAC: 58:2A:F7:F0:AE:B4 2022-02-08 05:43:33.296 S/N: H3L7S15503005423 2022-02-08 05:43:33.472 Board S/N: 7S2NPX154S021356 2022-02-08 05:43:33.647 Vendor Code: hw 2022-02-08 05:43:33.824 Country Code: meaf 2022-02-08 05:43:34.021 Downloading additional resources... 2022-02-08 05:43:34.204 New IMEI A: *************** 2022-02-08 05:43:34.382 New IMEI B: *************** 2022-02-08 05:43:37.936 Repairing IMEI A... 2022-02-08 05:43:38.112 Private enc 0 2022-02-08 05:43:38.281 Private enc 0 2022-02-08 05:43:38.451 Private enc 0 2022-02-08 05:43:38.959 Repairing IMEI B... 2022-02-08 05:43:39.137 Private enc 0 2022-02-08 05:43:39.645 Resetting your device 2022-02-08 05:43:40.158 2022-02-08 05:43:40.335 Repair Info done. 2022-02-08 05:43:40.511 Performed by 1.2.8 Software version. | |
The Following User Says Thank You to tdhmh For This Useful Post: |
