11-20-2022, 12:58 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | huawei aqm-lx1 huawei id remove issue [Solved] To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: Job ID: 0000000001B69076 2022-11-20 11:54:34 Starting Reset Huawei ID Selected phone model: AQM-AL00 Selected method: Reset Huawei Id (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Reset Huawei ID failed. Performed by 1.3.3 Software version. |
11-21-2022, 10:35 | #4 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | after select STK-LX1 operation done 2022-11-21 08:20:17 Starting Reset Huawei ID Selected phone model: STK-LX1 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: HYJNW18A27001862 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: AQM-LX1 System: AQM-L21A 12.0.0.226(C185E3R4P1) Android Version: 10 Base Version: AQM-LGRP2-OVS 102.0.0.226 Custom Version: AQM-L21A-CUST 102.0.0.3(C185) Preload Version: AQM-L21A-PRELOAD 102.0.0.1(C185R4) C_Version: C185 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: AQM-LX1 System: AQM-L21A 12.0.0.226(C185E3R4P1) Resetting Huawei ID... Rebooting device... Warning: Please perform "Clear data" manually via Recovery Mode, if your device doesn`t start properly! Reset Huawei ID done. Performed by 1.3.3 Software version. but now phone state "your device won't work properly because the chip is demage." .... |
11-22-2022, 08:04 | #5 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello Please, choose AQM-AL00 in tab ''Phone model'' and try to perform ''Restore Chip is damaged'' operation. Thereafter, please inform us about result, we will check it. |
11-22-2022, 10:58 | #6 (permalink) | |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | Quote:
Writing XLOADER partition... in 90% now phone with red screen after flashed with 6 files via factory mode Aquaman-L21MEA 10.1.0.156(C185E2R7P1)_Firmware_EMUI10.1.0_05017BC [/QUOTE]Job ID: 0000000001BC4FC7 2022-11-22 09:41:11 Starting Write Firmware(Factory mode) Selected phone model: INE-LX1 PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: HYJNW18A27001862 Device Model: AQM-LX1 System: AQM-L21A 12.0.0.226(C185E3R4P1) Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Writing PTABLE partition... Writing PTABLE partition... Writing XLOADER partition... Writing FASTBOOT partition... Writing HHEE partition... Writing DTS partition... Writing TRUSTFIRMWARE partition... Writing FW_LPM3 partition... Writing DTO partition... Writing KERNEL partition... Writing TEEOS partition... Writing ISP_FIRMWARE partition... Writing VECTOR partition... Writing SENSORHUB partition... Writing FW_HIFI partition... Writing VBMETA partition... Writing MODEMNVM_UPDATE partition... Writing MODEMNVM_CUST partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VENDOR partition... Writing RECOVERY_VBMETA partition... Writing PREAS partition... Writing PREAVS partition... Writing ERECOVERY_KERNEL partition... Writing ERECOVERY_RAMDISK partition... Writing ERECOVERY_VENDOR partition... Writing ERECOVERY_VBMETA partition... Writing ENG_VENDOR partition... Writing ENG_SYSTEM partition... Writing CACHE partition... Writing RAMDISK partition... Writing SUPER partition... Writing 1 chunk from 8... Writing 2 chunk from 8... Writing 3 chunk from 8... Writing 4 chunk from 8... Writing 5 chunk from 8... Writing 6 chunk from 8... Writing 7 chunk from 8... Writing 8 chunk from 8... Writing VBMETA_SYSTEM partition... Writing VBMETA_VENDOR partition... Writing VBMETA_ODM partition... Writing VBMETA_HW_PRODUCT partition... Writing VBMETA_CUST partition... Writing MODEM_FW partition... Writing HISEE_IMG partition... Writing HISEE_FS partition... Writing VERSION partition... Writing PRELOAD partition... Writing PATCH partition... Writing USERDATA partition... Writing VERSION partition... Warning: Writing VERSION partition failed Writing VERSION partition... Warning: Writing VERSION partition failed Error: Writing VERSION partition failed Writing PRELOAD partition... Warning: Writing PRELOAD partition failed Writing PRELOAD partition... Warning: Writing PRELOAD partition failed Error: Writing PRELOAD partition failed Write Firmware(Factory mode) done. Performed by 1.3.3 Software version. [/QUOTE] | |
11-22-2022, 11:11 | #7 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | with upgrade mode also give error Job ID: 0000000001B73B9C 2022-11-22 10:09:24 Starting Switch Fastboot to Update mode Selected phone model: AQM-AL00 Searching Fastboot devices... Found android device: HYJNW18A27001862 Device Model: AQM-LX1 System: AQM-L21A 12.0.0.226(C185E3R4P1) Initializing remote service connection... Switching to Upgrade Mode... Writing ERECOVERY files... Successfully switched to update mode. Switch Fastboot to Update mode done. Performed by 1.3.3 Software version. Job ID: 00000000018EF8ED 2022-11-22 10:10:20 Starting Write Firmware(Upgrade mode) Selected phone model: AQM-AL00 PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Checking firmware package type Searching device in Upgrade mode... Detected DBAdapter Reserved Interface port Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Error: Failed write BASE_VERLIST partition Write Firmware(Upgrade mode) failed. Performed by 1.3.3 Software version. |
11-23-2022, 11:42 | #10 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | write back up with error Welcome to Octoplus Huawei Software v.1.3.3 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: Job ID: 0000000001B7A8D7 2022-11-23 10:19:22 Starting Write Backup Selected phone model: HRY-LX1 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: HYJNW18A27001862 Device Model: AQM-LX1 System: AQM-L21A 12.0.0.226(C185E3R4P1) Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Verifying backup files Writing BOOTFAIL_INFO partition... Writing CACHE partition... Writing CERTIFICATION partition... Warning: Writing certification partition failed Writing CUST partition... Writing DDR_PARA partition... Writing DFX partition... Writing DTO partition... Writing DTS partition... Writing ENG_SYSTEM partition... Writing ENG_VENDOR partition... Writing ERECOVERY_KERNEL partition... Writing ERECOVERY_RAMDISK partition... Writing ERECOVERY_VBMETA partition... Writing ERECOVERY_VENDOR partition... Writing FASTBOOT partition... Writing FRP partition... Writing FW_HIFI partition... Writing FW_LPM3 partition... Writing HDCP partition... Warning: Writing hdcp partition failed Writing HHEE partition... Writing HIBENCH_DATA partition... Writing HISEE_ENCOS partition... Writing HISEE_FS partition... Writing HISEE_IMG partition... Writing ISP_BOOT partition... Writing ISP_FIRMWARE partition... Writing KERNEL partition... Writing KPATCH partition... Writing MISC partition... Writing MODEM_DRIVER partition... Writing MODEM_FW partition... Writing MODEM_OM partition... Writing MODEM_PATCH_NV partition... Writing MODEM_SECURE partition... Writing MODEMNVM_BACKUP partition... Writing MODEMNVM_CUST partition... Writing MODEMNVM_FACTORY partition... Writing MODEMNVM_IMG partition... Writing MODEMNVM_UPDATE partition... Writing NVME partition... Warning: Writing nvme partition failed Writing ODM partition... Writing OEMINFO partition... Writing PATCH partition... Writing PERSIST partition... Writing PREAS partition... Writing PREAVS partition... Writing PRELOAD partition... Warning: Writing preload partition failed Writing PRODUCT partition... Writing PTABLE partition... Writing RAMDISK partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VBMETA partition... Writing RECOVERY_VENDOR partition... Writing RESERVED1 partition... Writing RESERVED4 partition... Writing RESERVED6 partition... Writing RESERVED7 partition... Writing RRECORD partition... Writing SECURE_STORAGE partition... Writing SENSORHUB partition... Writing SPLASH2 partition... Writing SUPER partition... Writing 1 chunk from 9... Writing 2 chunk from 9... Writing 3 chunk from 9... Writing 4 chunk from 9... Writing 5 chunk from 9... Writing 6 chunk from 9... Writing 7 chunk from 9... Writing 8 chunk from 9... Writing 9 chunk from 9... Writing TEEOS partition... Writing TRUSTFIRMWARE partition... Writing VBMETA partition... Writing VBMETA_CUST partition... Writing VBMETA_HW_PRODUCT partition... Writing VBMETA_ODM partition... Writing VBMETA_SYSTEM partition... Writing VBMETA_VENDOR partition... Writing VECTOR partition... Writing VENDOR partition... Warning: Writing vendor partition failed Writing VERITYKEY partition... Writing VERSION partition... Writing VRL partition... Writing VRL_BACKUP partition... Writing XLOADER partition... Rebooting device... Write Backup done. Performed by 1.3.3 Software version. |
11-24-2022, 13:21 | #11 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello Try firstly, write this board firmware (Aquaman-AL00B-BD 1.0.0.27_Board Software_general_9.1.0_r1_EMUI9.1.1_05022SKX.rar) via factory mode. Path: /Huawei/Huawei Board Firmware/A-series/AQM-LX1/ Then, try to write this stock firmware version (AQM-LX1 10.1.0.203(C185E3R8P1)_Firmware_EMUI10.1.0_05016RV U.zip) via upgrade mode. Path: /Huawei/Huawei Update firmwares (Offilne)/A-series/AQM-LX1/ Thereafter, please send us result. |
11-24-2022, 16:49 | #12 (permalink) | |
Job ID: 00000000018FEE74 2022-11-24 15:03:49 Starting Write Firmware(Factory mode) Selected phone model: MAR-AL00 Error: Please select download xml firmware file! Selected file: C:/Users/biNA/Downloads/Aquaman-AL00B-BD 1.0.0.27_Board Software_general_9.1.0_r1_EMUI9.1.1_05022SKX/Software/AQM-BD_1.0.0.27_Download.xml Selected Full flashing mode! Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Loading firmware configuaration file... Initializing remote service connection... Downloading resource... Writing bootloader AQM-BD 1.0.0.27... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Bootloader firmware files has been written successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: HYJNW18A27001862 Device Model: AQM-LX1 System: AQM-L21A 12.0.0.226(C185E3R4P1) Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Erasing MODEMNVM_BACKUP partition.. Erasing MODEMNVM_FACTORY partition.. Erasing CUST partition.. Erasing MISC partition.. Erasing BOOTFAIL_INFO partition.. Erasing DFX partition.. Erasing RRECORD partition.. Erasing HISEE_ENCOS partition.. Writing XLOADER partition... Writing PTABLE partition... Writing FASTBOOT partition... Writing VECTOR partition... Writing DTS partition... Writing DTO partition... Writing FW_LPM3 partition... Writing SENSORHUB partition... Writing FW_HIFI partition... Writing TEEOS partition... Writing ENG_SYSTEM partition... Writing ENG_VENDOR partition... Writing PRELOAD partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VENDOR partition... Writing RECOVERY_VBMETA partition... Writing CACHE partition... Writing KERNEL partition... Writing HHEE partition... Writing VBMETA partition... Writing ODM partition... Erasing NVME partition.. Writing NVME partition... Writing TRUSTFIRMWARE partition... Writing MODEM_FW partition... Writing MODEMNVM_UPDATE partition... Writing MODEMNVM_CUST partition... Writing MODEMNVM_IMG partition... Writing ISP_FIRMWARE partition... Erasing USERDATA partition.. Writing USERDATA partition... Writing SYSTEM partition... Writing 1 chunk from 4... Writing 2 chunk from 4... Writing 3 chunk from 4... Writing 4 chunk from 4... Writing VENDOR partition... Erasing PRODUCT partition.. Writing PRODUCT partition... Writing 1 chunk from 2... Writing 2 chunk from 2... Erasing VERSION partition.. Writing VERSION partition... Writing SPLASH2 partition... Writing FRP partition... Erasing OEMINFO partition.. Writing OEMINFO partition... Writing SECURE_STORAGE partition... Writing MODEM_SECURE partition... Writing HISEE_IMG partition... Writing HISEE_FS partition... Erasing HIBENCH_DATA partition.. Writing HIBENCH_DATA partition... Writing HIBENCH_IMG partition... Writing EFUSE partition... Writing PATCH partition... Writing UFS_FW partition... Note: After successful reflash the phone in Board Firmware mode, for a correct work of the device, you need to reflash it in Upgrade mode! Write Firmware(Factory mode) done. Performed by 1.3.3 Software version. | |
11-24-2022, 16:53 | #13 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | Job ID: 0000000001BD2F13 2022-11-24 15:50:06 Starting Switch Fastboot to Update mode Selected phone model: MAR-AL00 Searching Fastboot devices... Found android device: 0123456789ABCDEF Warning: Reading product model failed Warning: oem get-build-number failed Initializing remote service connection... Switching to Upgrade Mode... Writing ERECOVERY files... Successfully switched to update mode. Switch Fastboot to Update mode done. Performed by 1.3.3 Software version. Job ID: 00000000018FF353 2022-11-24 15:50:34 Starting Write Firmware(Upgrade mode) Selected phone model: MAR-AL00 Selected base ptable file: C:/Users/biNA/Downloads/AQM-LX1 10.1.0.203(C185E3R8P1)_Firmware_EMUI10.1.0_05016RV U (1)/Software/dload/update_sd_base/PTABLE.APP Selected cust ptable file: C:/Users/biNA/Downloads/AQM-LX1 10.1.0.203(C185E3R8P1)_Firmware_EMUI10.1.0_05016RV U (1)/Software/dload/update_sd_cust_AQM-L21A_hw_meafnaf/PTABLE.APP Selected preload ptable file: C:/Users/biNA/Downloads/AQM-LX1 10.1.0.203(C185E3R8P1)_Firmware_EMUI10.1.0_05016RV U (1)/Software/dload/update_sd_preload_AQM-L21A_hw_meafnaf_R8/PTABLE.APP Selected base update file: C:/Users/biNA/Downloads/AQM-LX1 10.1.0.203(C185E3R8P1)_Firmware_EMUI10.1.0_05016RV U (1)/Software/dload/update_sd_base/UPDATE.APP Selected cust update file: C:/Users/biNA/Downloads/AQM-LX1 10.1.0.203(C185E3R8P1)_Firmware_EMUI10.1.0_05016RV U (1)/Software/dload/update_sd_cust_AQM-L21A_hw_meafnaf/UPDATE.APP Selected preload base file: C:/Users/biNA/Downloads/AQM-LX1 10.1.0.203(C185E3R8P1)_Firmware_EMUI10.1.0_05016RV U (1)/Software/dload/update_sd_preload_AQM-L21A_hw_meafnaf_R8/UPDATE.APP PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Checking firmware package type Searching device in Upgrade mode... Error: No devices in Upgarde mode found Write Firmware(Upgrade mode) failed. Performed by 1.3.3 Software version. |
11-25-2022, 13:45 | #14 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | Again Phone with red screen after flash with this fimware AQM-LX1 10.1.0.203(C185E3R8P1) and factory mode... Now how to repair this Phone usine octoplus huawei tool?? |
11-28-2022, 08:57 | #15 (permalink) | |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello As we can see from software log, you didn't flash stock firmware. Quote:
