04-22-2022, 13:49 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Kenya
Member: 2531008 Status: Offline Thanks Meter: 15 | huawei cam al00 any solution [Answered] 2022-04-22 12:21:11.969 Refreshing serial ports list 2022-04-22 12:21:11.989 Found COM ports: 2022-04-22 12:21:12.729 Welcome to Octoplus Huawei Software v.1.2.8 2022-04-22 12:21:12.729 2022-04-22 12:21:12.729 To enable 'Manufacture' mode dial 2022-04-22 12:21:12.729 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2022-04-22 12:21:12.729 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2022-04-22 12:21:12.729 - for MTK based models: *#*#14789632#*#* 2022-04-22 12:21:12.729 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2022-04-22 12:21:12.729 2022-04-22 12:21:12.729 To enable 'Fastboot' mode 2022-04-22 12:21:12.729 1. Power off the phone. Remove SD and SIM cards 2022-04-22 12:21:12.729 2. Press 'Vol-' and insert USB cable 2022-04-22 12:21:12.729 3. Wait until phone enters 'Fastboot' mode 2022-04-22 12:21:12.729 2022-04-22 12:21:12.729 To enable 'Upgrade' mode 2022-04-22 12:21:12.729 1. Power off the phone. Remove SD and SIM cards 2022-04-22 12:21:12.729 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2022-04-22 12:21:12.729 3. Wait until phone enters 'Upgrade mode' 2022-04-22 12:21:14.099 Refreshing serial ports list 2022-04-22 12:21:14.099 Found COM ports: 2022-04-22 12:21:14.229 Init finished 2022-04-22 12:26:05.929 Job ID: 0000000001A8E414 2022-04-22 12:26:08.110 2022-04-22 12:26:08 2022-04-22 12:26:09.300 Starting Repair Info 2022-04-22 12:26:10.220 Selected phone model: CAM-AL00 2022-04-22 12:26:11.010 Detected DBAdapter Reserved Interface port 2022-04-22 12:26:18.466 Connecting to server... 2022-04-22 12:26:19.082 Check auth 0 2022-04-22 12:26:20.509 Authorization confirmation failed. Status byte doesn't match. 2022-04-22 12:26:20.992 Device firmware is currently not supported 2022-04-22 12:26:21.510 2022-04-22 12:26:21.993 Repair Info failed. 2022-04-22 12:26:22.481 Performed by 1.2.8 Software version. 2022-04-22 12:26:55.005 Job ID: 0000000001A8E44F 2022-04-22 12:26:55.920 2022-04-22 12:26:55 2022-04-22 12:26:56.368 Starting Repair Info 2022-04-22 12:26:56.843 Selected phone model: CAM-AL00 2022-04-22 12:26:57.351 Detected DBAdapter Reserved Interface port 2022-04-22 12:27:06.025 Connecting to server... 2022-04-22 12:27:06.671 Check auth 0 2022-04-22 12:27:08.125 Authorization confirmation failed. Status byte doesn't match. 2022-04-22 12:27:08.588 Device firmware is currently not supported 2022-04-22 12:27:09.055 2022-04-22 12:27:09.520 Repair Info failed. 2022-04-22 12:27:10.222 Performed by 1.2.8 Software version. 2022-04-22 12:29:43.880 Your balance: 0 credit(s) 2022-04-22 12:31:58.739 Job ID: 0000000001A8E5BF 2022-04-22 12:31:59.151 2022-04-22 12:31:59 2022-04-22 12:31:59.355 Starting Repair Info 2022-04-22 12:31:59.554 Selected phone model: CAM-AL00 2022-04-22 12:31:59.793 Detected DBAdapter Reserved Interface port 2022-04-22 12:32:02.727 Connecting to server... 2022-04-22 12:32:02.947 Check auth 0 2022-04-22 12:32:03.593 Authorization confirmation failed. Status byte doesn't match. 2022-04-22 12:32:03.804 Device firmware is currently not supported 2022-04-22 12:32:04.010 2022-04-22 12:32:04.243 Repair Info failed. 2022-04-22 12:32:04.447 Performed by 1.2.8 Software version. 2022-04-22 12:32:40.348 Job ID: 0000000001A8E5F2 2022-04-22 12:32:41.258 2022-04-22 12:32:41 2022-04-22 12:32:41.717 Starting Repair Info 2022-04-22 12:32:42.174 Selected phone model: Qualcomm Android Device 2022-04-22 12:32:42.730 Detected DBAdapter Reserved Interface port 2022-04-22 12:32:49.654 Connecting to server... 2022-04-22 12:32:50.137 Check auth 0 2022-04-22 12:32:51.509 Authorization confirmation failed. Status byte doesn't match. 2022-04-22 12:32:53.728 Device firmware is currently not supported 2022-04-22 12:32:54.240 2022-04-22 12:32:54.753 Repair Info failed. 2022-04-22 12:32:55.273 Performed by 1.2.8 Software version. |
