09-14-2020, 15:40 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | BGO-LD09 frp done To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM27 USB Serial Port 2020-09-14 14:36:30 GMT ------------------------------------------------- Starting Reset FRP (ADB Interface) Reset FRP (ADB Interface) is not supported for this device. Performed by 1.2.1 Software version. 2020-09-14 14:36:55 GMT ------------------------------------------------- Starting Reset FRP (ADB Interface) Reset FRP (ADB Interface) is not supported for this device. Performed by 1.2.1 Software version. 2020-09-14 14:37:01 GMT ------------------------------------------------- Starting Connect Selected phone model: BGO-DL09 Connect is not supported for this device. Performed by 1.2.1 Software version. 2020-09-14 14:37:16 GMT ------------------------------------------------- Starting Auto detect No devices in manufacture mode detected Auto detect failed. Performed by 1.2.1 Software version. Found COM ports: 1: COM1 Communications Port 2: COM27 USB Serial Port 2020-09-14 14:37:35 GMT ------------------------------------------------- Starting Reset FRP (ADB Interface) Reset FRP (ADB Interface) is not supported for this device. Performed by 1.2.1 Software version. 2020-09-14 14:38:06 GMT ------------------------------------------------- Starting Reset FRP (Fastboot Mode) Searching Fastboot devices... Found a fastboot device: 8QKDU17921002111 System: escue:BGO-DL09C199B006 Connecting to server... Writing Reset FRP data... Reset FRP (Fastboot Mode) done. Performed by 1.2.1 Software version. |
The Following User Says Thank You to Yasir Ali For This Useful Post: |
