ine lx1 read write question [Answered] hello ine lx1 8 version but still read write cert fail here,s the logs Welcome to Octoplus Huawei Software v.1.2.8 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM17 USB Serial Port 2: COM105 HUAWEI USB COM 1.0 Job ID: 00000000021C2678 2022-01-14 06:35:29 Starting Read Cert Selected phone model: INE-LX1 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: Detected Android Sooner Single ADB Interface port Device Model: INE-LX1 System: INE-LX1 8.2.0.137(C432) MEID: IMEI A: IMEI B: S/N: Reading certificate files... Reading certificate for IMEI A... Error: Can't get current certificate file! Warning: Skipping read certificate for IMEI A Reading certificate for IMEI B... Error: Can't get current certificate file! Warning: Skipping read certificate for IMEI B Rebooting device... Read Cert done. Performed by 1.2.8 Software version. |
Hello. Please, send us your "modem_secure" file. We will check it. |
What is state of phone now? The IMEI of the device okay? |
ok listen imei etc showing ok but read write cert was not working so i even wipe oem and write board rom but still prob remain |
The software is working properly. There are no cert files from your device in this partition, which means that they are corrupted. For the same reason, you can't perform Read Cert operation. |
if cert part is empty then i try to write cert but its also not workable so what,s the reason of this or how to solve it? |
and i tried 2 differnt board roms from your support but this error Job ID: 0 2022-01-15 06:15:49 Starting Write Firmware(Factory mode) Selected phone model: INE-LX2 Selected file: C:/Users/unnam/Desktop/Software/IVY-BD_1.0.0.27_Download.xml Selected Full flashing mode! Loading firmware configuaration file... Initializing remote service connection... Error: This firmware version is not currently supported! Please, use a different firmware version or download the firmware from the support area! Write Firmware(Factory mode) failed. Performed by 1.2.8 Software version. |
now see this team its write cert and even in logs showing my changed imei but in device its not showing the real imei still old imei Job ID: 2022-01-15 07:02:16 Starting Write Cert Selected phone model: INE-LX2 Username: Default_user Connecting to the credit server... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: Detected Android Sooner Single ADB Interface port Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Device Model: INE-LX1 System: INE-LX1 8.2.0.106(C432) MEID: A00000 IMEI A: 86xx IMEI B: 86xx S/N: Saving backup of MODEM_SECURE... Saving backup of OEMINFO... Reading secure data... Writing certificate files... Rebooting device... Write Cert done. Performed by 1.2.8 Software version. |
Try to perform Factory Reset and check IMEI status on your device one more time. |
bro i write sec backup from another device then imei changed to another device after that i was successfuly able to read cert but when i writed another imei its still showing of another device IMEI even i write again another board from your support but still another device imei its basiclly changed imei when i change sec backup even now fix read cert but after write old imei why? let me add some more logs Device Model: INE-LX1 System: INE-LX1 8.2.0.106(C432) MEID: IMEI A: 86xxxxxxxxxxxxxx IMEI B: 86xxxxxxxxxxxxxx S/N: xxxxxxxxxxxxxx Warning: The VRL file was not found Writing MODEM_SECURE partition... Writing MODEMNVM_BACKUP partition... Writing MODEMNVM_CUST_A partition... Writing MODEMNVM_FACTORY partition... Writing MODEMNVM_IMG partition... Writing MODEMNVM_UPDATE_A partition... Writing OEMINFO partition... Rebooting device... Write Backup done. Performed by 1.2.8 Software version. Job ID: 2022-01-15 08:11:10 Starting Read Cert Selected phone model: INE-LX2 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: TGDDU16831005180 Detected Android Sooner Single ADB Interface port Device Model: INE-LX1 System: Chipset-miami 8.2.0.001(01S9) MEID: 00000000000000 IMEI A: 86xxxxxxxxxxxxxx IMEI B: 86xxxxxxxxxxxxxx S/N: xxxxxxxxxxxxxxxxxx Reading certificate files... Reading certificate for IMEI A... Reading certificate for IMEI B... Rebooting device... Read Cert done. Performed by 1.2.8 Software version. Selected IMEI_B file: C:/Users/unnam/Desktop/huawei cert/xxx-L21_IMEI_SLOT_2_8xxxxxxxxxxxxx.obf Job ID: 2022-01-15 08:32:36 Starting Write Cert Selected phone model: INE-LX2 Username: Default_user Connecting to the credit server... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: TGDDU16831005180 Detected Android Sooner Single ADB Interface port Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Device Model: INE-LX1 System: Chipset-miami 8.2.0.001(01S9) MEID: 00000000000000 IMEI A: 86xxxxxxxxxxxxxx IMEI B: 86xxxxxxxxxxxxxx S/N: Saving backup of MODEM_SECURE... Saving backup of OEMINFO... Reading secure data... Writing certificate files... Rebooting device... Write Cert done. Performed by 1.2.8 Software version. Job ID: 2022-01-15 08:39:29 Starting Update OEMINFO Selected phone model: INE-LX2 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: xxxxxxxxxxxxxxxxx Device Model: INE-LX1 System: Chipset-miami 8.2.0.001(01S9) MEID: 00000000000000 IMEI A: 86xxxxxxxxxxxxxx IMEI B: 86xxxxxxxxxxxxxx S/N: Update OEMINFO done. Performed by 1.2.8 Software version. |
We will send this information to our developers to find a solution to your issue. We'll try to give you an answer on Monday. |
hope i get reply today i,m still wait for you |
Hello. Please, explain one more time and more detail. What exactly do you need to do with your device? Also, after write backup, you always need to perform Factory Reset. You have completed Factory Reset in the previous steps? |
can you come to skype so we,ll chat live with ss |
