06-17-2021, 12:54 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | LYA-AL00 - FRP not removed [Solved] I tried to remove FRP but failed. Here is the log ( IMEI removed) Starting Reset FRP (Factory Mode) Selected phone model: LYA-AL00 Username: Default_user Connecting to the credit server... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN980_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found a fastboot device: 7N5PTR193M131128 Device Model: LYA-AL00 System: LYA-AL00L 10.1.0.165(C00E164R2P8) Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: LYA-AL00 System: LYA-AL00L 10.1.0.165(C00E164R2P8) MEID: A00000A72C1.... IMEI A: 86....... IMEI B: 86....... Resetting FRP... Writing FRP partition.. Rebooting device... Reset FRP (Factory Mode) done. Performed by 1.2.4 Software version. but FRP is still there. What should I do? Thanks for help |
06-17-2021, 13:06 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,160 | Hello. Please, download and install latest Octoplus Huawei Software version 1.2.5 and repeat Reset FRP operation once again. Then post here results. We will check it. |
06-17-2021, 14:00 | #3 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Here is the log. The porblem remains - FRP NOT REMOVED Welcome to Octoplus Huawei Software v.1.2.5 2021-06-17 12:54:55 GMT ------------------------------------------------- Starting Reset FRP (Factory Mode) Selected phone model: LYA-AL00 Username: Default_user Connecting to the credit server... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN980_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found a fastboot device: 7N5PTR193M131128 Device Model: LYA-AL00 System: LYA-AL00L 10.1.0.165(C00E164R2P8) Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: LYA-AL00 System: LYA-AL00L 10.1.0.165(C00E164R2P8) MEID: A00.... IMEI A: 86.... IMEI B: 86..... Resetting FRP... Writing FRP partition.. Rebooting device... Reset FRP (Factory Mode) done. Performed by 1.2.5 Software version. |
06-17-2021, 15:35 | #5 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | I am sorry.I checked again and it was HUAWEI ID that caused the problem. Now it was removed successfully Thanks again for your time and help |
The Following User Says Thank You to Jane1 For This Useful Post: |
