02-13-2022, 12:24 | #1 (permalink) |
Insane Poster Join Date: Apr 2014 Location: yem
Member: 2172436 Status: Offline Sonork: lololo Thanks Meter: 2 | MAR-LX1A Factory Mode Question [Answered] To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM3 USB Serial Port 3: COM15 HUAWEI USB COM 1.0 Job ID: 00000000023D9BE2 2022-02-13 11:13:02 Starting ON/OFF Factory Mode Selected phone model: MAR-LX1A To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: QTCDU19703024033 Detected Android Sooner Single ADB Interface port Device Model: MAR-LX1A System: MAR-L21MEB 9.1.0.241(C185E2R3P1) Removing firmware protection... ON/OFF Factory Mode failed. Performed by 1.2.8 Software version. Job ID: 00000000023D9C80 2022-02-13 11:15:28 Starting Read Info Selected phone model: MAR-LX1A Searching Fastboot devices... Found android device: QTCDU19703024033 Detected Android Sooner Single ADB Interface port Device Model: MAR-L21MEB System: MAR-L21MEB 9.1.0.241(C185E2R3P1) Android Version: 9 Base Version: MAR-LGRP2-OVS 9.1.0.241 Custom Version: MAR-L21MEB-CUST 9.1.0.2(C185) Preload Version: MAR-LX1A-PRELOAD 9.1.0.1(C185R3) C_Version: C185 D_Version: D000 Read Info done. Performed by 1.2.8 Software version. Job ID: 00000000023D9CB4 2022-02-13 11:16:17 Starting ON/OFF Factory Mode Selected phone model: MAR-LX1A To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching Fastboot devices... Found android device: QTCDU19703024033 Detected Android Sooner Single ADB Interface port Device Model: MAR-LX1A System: MAR-L21MEB 9.1.0.241(C185E2R3P1) Removing firmware protection... ON/OFF Factory Mode failed. Performed by 1.2.8 Software version. Job ID: 00000000023D9D03 2022-02-13 11:17:24 Starting ON/OFF Factory Mode Selected phone model: MAR-LX1A To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: QTCDU19703024033 Detected Android Sooner Single ADB Interface port Device Model: MAR-LX1A System: MAR-L21MEB 9.1.0.241(C185E2R3P1) Removing firmware protection... ON/OFF Factory Mode failed. Performed by 1.2.8 Software version. Job ID: 00000000023D9E1A 2022-02-13 11:21:52 Starting Reset FRP Selected phone model: MAR-LX1A Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: QTCDU19703024033 Detected Android Sooner Single ADB Interface port Device Model: MAR-LX1A System: MAR-L21MEB 9.1.0.241(C185E2R3P1) Android Version: 9 Base Version: MAR-LGRP2-OVS 9.1.0.241 Custom Version: MAR-L21MEB-CUST 9.1.0.2(C185) Preload Version: MAR-LX1A-PRELOAD 9.1.0.1(C185R3) C_Version: C185 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: baq50 Checking balance... Your balance: 100 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Removing firmware protection... Reset FRP failed. Performed by 1.2.8 Software version. |
02-14-2022, 10:08 | #3 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,160 | Hello. Please make sure that your device is fully charged and the battery is connected during the operation. Also, contact us in Telegram we will check where can be the problem in more detail. Last edited by Octopus support; 02-14-2022 at 10:21. |
