MGA-LX9 fail to load factory mode [Answered] Found android device: KDSBB22610202642 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: MGA-L29 System: MGA-L29 12.0.0.190(C185E8R1P2) Android Version: 10 Base Version: MGA-LGRP2-OVS 102.0.0.190 Custom Version: MGA-L29-CUST 102.0.0.8(C185) Preload Version: MGA-L29-PRELOAD 102.0.0.2(C185R1) C_Version: C185 D_Version: D000 Read Info done. itry POT-LX1 and PPA-LX2 fail to load factory mode 022-12-04 18:50:49.783 To enable 'Upgrade' mode 2022-12-04 18:50:49.783 1. Power off the phone. Remove SD and SIM cards 2022-12-04 18:50:49.783 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2022-12-04 18:50:49.783 3. Wait until phone enters 'Upgrade mode' 2022-12-04 18:50:51.151 Refreshing serial ports list 2022-12-04 18:50:51.155 Found COM ports: 2022-12-04 18:50:51.155 1: COM1 Communications Port 2022-12-04 18:50:51.155 2: COM5 HUAWEI USB COM 1.0 2022-12-04 18:50:51.155 3: COM22 USB Serial Port 2022-12-04 18:50:51.243 Init finished 2022-12-04 18:51:02.146 Job ID: 0000000001C0719A 2022-12-04 18:51:02.738 2022-12-04 18:51:02 2022-12-04 18:51:02.746 Starting Reset Huawei ID 2022-12-04 18:51:02.746 Selected phone model: POT-LX1 2022-12-04 18:51:04.034 Searching HUAWEI USB COM 1.0 port... 2022-12-04 18:51:04.038 Detected HUAWEI USB COM 1.0 port 2022-12-04 18:51:04.048 Phone connect successfully 2022-12-04 18:51:04.053 Writing bootloader KIRIN710_V1... 2022-12-04 18:51:04.057 Initializing remote service connection... 2022-12-04 18:51:04.342 Writing XLOADER partition... 2022-12-04 18:51:07.106 Writing UCE partition... 2022-12-04 18:51:12.122 Write start command failed 2022-12-04 18:51:39.774 Write start command failed 2022-12-04 18:52:04.892 Write start command failed 2022-12-04 18:52:30.011 Write start command failed 2022-12-04 18:52:55.129 Write start command failed 2022-12-04 18:53:20.255 Write start command failed 2022-12-04 18:53:45.372 Write start command failed 2022-12-04 18:54:10.490 Write start command failed 2022-12-04 18:54:35.631 Write start command failed 2022-12-04 18:55:00.748 Write start command failed 2022-12-04 18:55:25.938 Write start command failed 2022-12-04 18:55:46.047 Reset Huawei ID failed. 2022-12-04 18:55:46.051 Performed by 1.3.3 Software version. 2022-12-04 18:56:03.098 Job ID: 0000000001939B63 2022-12-04 18:56:03.291 2022-12-04 18:56:03 2022-12-04 18:56:03.296 Starting Reset Huawei ID 2022-12-04 18:56:03.300 Selected phone model: PPA-LX2 2022-12-04 18:56:32.782 Searching HUAWEI USB COM 1.0 port... 2022-12-04 18:56:32.787 Detected HUAWEI USB COM 1.0 port 2022-12-04 18:56:32.798 Phone connect successfully 2022-12-04 18:56:32.804 Writing bootloader KIRIN710A_V3... 2022-12-04 18:56:32.809 Initializing remote service connection... 2022-12-04 18:56:33.072 Writing XLOADER partition... 2022-12-04 18:56:33.573 Writing UCE partition... 2022-12-04 18:57:05.181 Writing FASTBOOT partition... 2022-12-04 18:57:32.294 Operation in progress. Please wait for instructions... 2022-12-04 18:57:44.314 Bootloader Update successfully 2022-12-04 18:57:44.314 Rebooting to fastboot mode... 2022-12-04 18:57:57.772 Searching Fastboot devices... 2022-12-04 18:58:48.059 Fastboot devices not found 2022-12-04 18:58:48.067 Reset Huawei ID failed. 2022-12-04 18:58:48.071 Performed by 1.3.3 Software version. 2022-12-04 19:00:15.210 Job ID: 0000000001C071E3 2022-12-04 19:00:15.765 2022-12-04 19:00:15 2022-12-04 19:00:15.765 Starting Reset Huawei ID 2022-12-04 19:00:15.780 Selected phone model: STK-L21 2022-12-04 19:00:17.134 Searching HUAWEI USB COM 1.0 port... 2022-12-04 19:00:17.144 Detected HUAWEI USB COM 1.0 port 2022-12-04 19:00:17.160 Phone connect successfully 2022-12-04 19:00:17.168 Writing bootloader KIRIN710_V1... 2022-12-04 19:00:17.176 Initializing remote service connection... 2022-12-04 19:00:17.420 Writing XLOADER partition... 2022-12-04 19:00:20.174 Writing UCE partition... 2022-12-04 19:00:25.191 Write start command failed 2022-12-04 19:00:52.845 Write start command failed 2022-12-04 19:01:17.963 Write start command failed 2022-12-04 19:01:43.081 Write start command failed 2022-12-04 19:02:08.201 Write start command failed 2022-12-04 19:02:33.322 Write start command failed 2022-12-04 19:02:58.469 Write start command failed 2022-12-04 19:03:23.589 Write start command failed 2022-12-04 19:03:30.297 Canceling... Please be patient! 2022-12-04 19:03:34.388 Reset Huawei ID failed. 2022-12-04 19:03:34.397 Performed by 1.3.3 Software version. 2022-12-04 20:13:50.085 Job ID: 0000000001939E32 2022-12-04 20:13:50.273 2022-12-04 20:13:50 2022-12-04 20:13:50.281 Starting Reset Huawei ID 2022-12-04 20:13:50.289 Selected phone model: INE-LX1 2022-12-04 20:13:51.781 Searching HUAWEI USB COM 1.0 port... 2022-12-04 20:14:14.699 Detected HUAWEI USB COM 1.0 port 2022-12-04 20:14:14.717 Phone connect successfully 2022-12-04 20:14:14.731 Writing bootloader KIRIN710_V1... 2022-12-04 20:14:14.741 Initializing remote service connection... 2022-12-04 20:14:14.986 Writing XLOADER partition... 2022-12-04 20:14:17.859 Writing UCE partition... 2022-12-04 20:14:22.884 Write start command failed 2022-12-04 20:14:50.546 Write start command failed 2022-12-04 20:15:15.664 Write start command failed 2022-12-04 20:15:40.824 Write start command failed 2022-12-04 20:16:05.944 Write start command failed 2022-12-04 20:16:31.066 Write start command failed 2022-12-04 20:16:56.185 Write start command failed 2022-12-04 20:17:21.303 Write start command failed 2022-12-04 20:17:46.438 Write start command failed 2022-12-04 20:18:11.555 Write start command failed 2022-12-04 20:18:36.680 Write start command failed 2022-12-04 20:18:49.847 Reset Huawei ID failed. 2022-12-04 20:18:49.861 Performed by 1.3.3 Software version. 2022-12-04 20:19:22.843 Job ID: 0000000001BBE8C6 2022-12-04 20:19:23.076 2022-12-04 20:19:23 2022-12-04 20:19:23.087 Starting Reset Huawei ID 2022-12-04 20:19:23.097 Selected phone model: POT-LX1 2022-12-04 20:19:24.555 Reset Huawei ID canceled. 2022-12-04 20:19:24.568 Performed by 1.3.3 Software version. 2022-12-04 20:19:43.411 Job ID: 0000000001939E5A 2022-12-04 20:19:43.605 2022-12-04 20:19:43 2022-12-04 20:19:43.615 Starting Reset Huawei ID 2022-12-04 20:19:43.626 Selected phone model: PPA-L02 2022-12-04 20:19:44.878 Searching HUAWEI USB COM 1.0 port... 2022-12-04 20:19:44.889 Detected HUAWEI USB COM 1.0 port 2022-12-04 20:19:44.910 Phone connect successfully 2022-12-04 20:19:44.922 Writing bootloader KIRIN710A_V3... 2022-12-04 20:19:44.934 Initializing remote service connection... 2022-12-04 20:19:45.173 Writing XLOADER partition... 2022-12-04 20:19:45.707 Writing UCE partition... 2022-12-04 20:20:17.342 Writing FASTBOOT partition... 2022-12-04 20:20:44.998 Operation in progress. Please wait for instructions... 2022-12-04 20:20:57.004 Bootloader Update successfully 2022-12-04 20:20:57.016 Rebooting to fastboot mode... 2022-12-04 20:21:02.125 Searching Fastboot devices... 2022-12-04 20:21:52.233 Fastboot devices not found 2022-12-04 20:21:52.241 Reset Huawei ID failed. 2022-12-04 20:21:52.253 Performed by 1.3.3 Software version. 2022-12-04 20:24:47.695 Job ID: 0000000001BBE8F5 2022-12-04 20:24:47.971 2022-12-04 20:24:47 2022-12-04 20:24:47.983 Starting Reset Huawei ID 2022-12-04 20:24:47.995 Selected phone model: PPA-L02 2022-12-04 20:24:51.372 Searching HUAWEI USB COM 1.0 port... 2022-12-04 20:24:51.386 Detected HUAWEI USB COM 1.0 port 2022-12-04 20:24:51.406 Phone connect successfully 2022-12-04 20:24:51.421 Writing bootloader KIRIN710A_V3... 2022-12-04 20:24:51.434 Initializing remote service connection... 2022-12-04 20:24:51.659 Writing XLOADER partition... 2022-12-04 20:24:52.297 Writing UCE partition... 2022-12-04 20:25:23.906 Writing FASTBOOT partition... 2022-12-04 20:25:49.657 Operation in progress. Please wait for instructions... 2022-12-04 20:26:01.696 Bootloader Update successfully 2022-12-04 20:26:01.710 Rebooting to fastboot mode... 2022-12-04 20:33:35.372 Reset Huawei ID canceled. 2022-12-04 20:33:35.404 Performed by 1.3.3 Software version. 2022-12-04 20:34:49.272 Job ID: 0000000001939EBF 2022-12-04 20:34:49.492 2022-12-04 20:34:49 2022-12-04 20:34:49.508 Starting Reset Huawei ID 2022-12-04 20:34:49.520 Selected phone model: AKA-L29 2022-12-04 20:34:50.853 Searching HUAWEI USB COM 1.0 port... 2022-12-04 20:34:50.868 Detected HUAWEI USB COM 1.0 port 2022-12-04 20:34:50.891 Phone connect successfully 2022-12-04 20:34:50.907 Writing bootloader KIRIN710A_V3... 2022-12-04 20:34:50.922 Initializing remote service connection... 2022-12-04 20:34:51.147 Writing XLOADER partition... 2022-12-04 20:34:51.644 Writing UCE partition... 2022-12-04 20:35:23.285 Writing FASTBOOT partition... 2022-12-04 20:35:50.561 Operation in progress. Please wait for instructions... 2022-12-04 20:36:02.560 Bootloader Update successfully 2022-12-04 20:36:02.566 Rebooting to fastboot mode... 2022-12-04 20:36:47.089 Searching Fastboot devices... 2022-12-04 20:37:37.334 Fastboot devices not found 2022-12-04 20:37:37.350 Reset Huawei ID failed. 2022-12-04 20:37:37.362 Performed by 1.3.3 Software version. 2022-12-04 20:48:28.642 Job ID: 0000000001C0751A 2022-12-04 20:48:29.382 2022-12-04 20:48:29 2022-12-04 20:48:29.414 Starting Reset Huawei ID 2022-12-04 20:48:29.446 Selected phone model: POT-LX2 2022-12-04 20:49:30.991 Searching HUAWEI USB COM 1.0 port... 2022-12-04 20:50:31.004 HUAWEI USB COM 1.0 port not found 2022-12-04 20:50:31.040 Searching Fastboot devices... 2022-12-04 20:50:45.641 Canceling... Please be patient! 2022-12-04 20:50:47.749 Reset Huawei ID canceled. 2022-12-04 20:50:47.781 Performed by 1.3.3 Software version. 2022-12-04 20:50:50.856 Job ID: 0000000001BBE9C4 2022-12-04 20:50:51.124 2022-12-04 20:50:51 2022-12-04 20:50:51.156 Starting Reset Huawei ID 2022-12-04 20:50:51.188 Selected phone model: POT-LX2 2022-12-04 20:50:52.593 Searching HUAWEI USB COM 1.0 port... 2022-12-04 20:50:52.629 Detected HUAWEI USB COM 1.0 port 2022-12-04 20:50:52.679 Phone connect successfully 2022-12-04 20:50:52.715 Writing bootloader KIRIN710_V1... 2022-12-04 20:50:52.751 Initializing remote service connection... 2022-12-04 20:50:52.934 Writing XLOADER partition... 2022-12-04 20:50:55.699 Writing UCE partition... 2022-12-04 20:51:00.719 Write start command failed 2022-12-04 20:51:28.368 Write start command failed 2022-12-04 20:51:53.487 Write start command failed 2022-12-04 20:52:18.607 Write start command failed 2022-12-04 20:52:43.726 Write start command failed 2022-12-04 20:53:09.101 Write start command failed 2022-12-04 20:53:34.218 Write start command failed 2022-12-04 20:53:59.509 Write start command failed 2022-12-04 20:54:24.627 Write start command failed 2022-12-04 20:54:49.801 Write start command failed 2022-12-04 20:55:14.971 Write start command failed 2022-12-04 20:55:35.117 Reset Huawei ID failed. 2022-12-04 20:55:35.153 Performed by 1.3.3 Software version. 2022-12-04 21:09:34.827 Job ID: 0000000001C075B8 2022-12-04 21:09:35.319 2022-12-04 21:09:35 2022-12-04 21:09:35.351 Starting Reset Huawei ID 2022-12-04 21:09:35.383 Selected phone model: MAR-LX1A 2022-12-04 21:10:00.086 Searching HUAWEI USB COM 1.0 port... 2022-12-04 21:10:00.134 Detected HUAWEI USB COM 1.0 port 2022-12-04 21:10:00.183 Phone connect successfully 2022-12-04 21:10:00.220 Writing bootloader KIRIN710_V1... 2022-12-04 21:10:00.256 Initializing remote service connection... 2022-12-04 21:10:00.546 Writing XLOADER partition... 2022-12-04 21:10:03.252 Writing UCE partition... 2022-12-04 21:10:08.272 Write start command failed 2022-12-04 21:10:35.936 Write start command failed 2022-12-04 21:11:01.054 Write start command failed 2022-12-04 21:11:26.172 Write start command failed 2022-12-04 21:11:51.291 Write start command failed 2022-12-04 21:12:16.410 Write start command failed 2022-12-04 21:12:41.528 Write start command failed 2022-12-04 21:13:06.646 Write start command failed 2022-12-04 21:13:31.768 Write start command failed 2022-12-04 21:13:45.635 Canceling... Please be patient! 2022-12-04 21:13:46.789 Reset Huawei ID failed. 2022-12-04 21:13:46.826 Performed by 1.3.3 Software version. 2022-12-04 21:18:18.033 Smart Card not found |
Hello Please, check whether Fastboot drivers are installed. Also, please make sure that battery is connected. |
Fastboot drivers is ok and battery is full charged |
