01-23-2023, 20:24 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: POLAND Age: 43
Member: 99605 Status: Offline Thanks Meter: 70 | P40 Lite JNY-LX1 Huawei ID Question [Solved] 2023-01-23 19:19:37 Starting Read Info Selected phone model: JNY-LX1 Searching Fastboot devices... Found android device: EPHUT20506022696 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: JNY-L21 System: JNY-L21 12.0.0.259(C432E5R2P2) Android Version: 10 Base Version: JNY-LGRP2-OVS 102.0.0.259 Custom Version: JNY-L21-CUST 102.0.0.5(C432) Preload Version: JNY-L21-PRELOAD 102.0.0.2(C432R2) C_Version: C432 D_Version: D000 Read Info done. Performed by 1.3.3 Software version. posible to reset huawei id ? |
01-24-2023, 08:34 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello As we can see from software log, your device's firmware is too high You need to downgrade firmware version to 220 to perform operation successfuly. You can try to downgrade with this firmware version Jenny-L21A 102.0.0.220(C432E5R6P2) Firmware EMUI12.0.0 05016PMS.rar which you can find on support area. You should downgrade device via factory mode. Also, all operation with flashing firmware you do at your own risk |
01-25-2023, 22:31 | #3 (permalink) |
Member: 99605 Status: Offline Thanks Meter: 70 | when i try backup : Job ID: 0000000001A5C31E 2023-01-25 21:25:06 Starting Read Info Selected phone model: JNY-LX1 Selected method: Read Info (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Downloading resource... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Error: Fastboot devices not found Read Info failed. Performed by 1.3.3 Software version. Job ID: 0000000001A2F9E0 2023-01-25 21:27:56 Starting Backup Firmware Selected phone model: JNY-LX1 Selected method: Read backup (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Canceling... Please be patient! Backup Firmware failed. Performed by 1.3.3 Software version. Job ID: 0000000001CDEDFC 2023-01-25 21:30:33 Starting Backup Firmware Selected phone model: JNY-LX1 Selected method: Read backup (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... and hang |
01-25-2023, 22:53 | #4 (permalink) |
Member: 99605 Status: Offline Thanks Meter: 70 | Job ID: 0000000001A2FAFE 2023-01-25 21:47:00 Starting Backup Firmware Selected phone model: JNY-LX1 Selected method: Read backup (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: EPHUT20506022696 Device Model: JNY-LX1 System: JNY-L21 12.0.0.259(C432E5R2P2) Error: Bootloader check failed. Connect your phone via Factory mode and perform the operation again. Backup Firmware failed. Performed by 1.3.3 Software version. |
01-26-2023, 18:18 | #7 (permalink) |
Member: 99605 Status: Offline Thanks Meter: 70 | no you don't understand phone full working and is in good condition. I ask how to do downgrade ? how is procedure to downgrade. 2023-01-25 21:24:55.040 Loading application settings 2023-01-25 21:24:55.058 Refreshing serial ports list 2023-01-25 21:24:55.070 Found COM ports: 2023-01-25 21:24:55.071 1: COM1 Port komunikacyjny 2023-01-25 21:24:55.071 2: COM13 USB Serial Port 2023-01-25 21:24:55.071 3: COM8 HUAWEI USB COM 1.0 2023-01-25 21:24:55.591 Welcome to Octoplus Huawei Software v.1.3.3 2023-01-25 21:24:55.592 2023-01-25 21:24:55.592 To enable 'Manufacture' mode dial 2023-01-25 21:24:55.592 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2023-01-25 21:24:55.592 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2023-01-25 21:24:55.593 - for MTK based models: *#*#14789632#*#* 2023-01-25 21:24:55.593 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2023-01-25 21:24:55.593 2023-01-25 21:24:55.593 To enable 'Fastboot' mode 2023-01-25 21:24:55.594 1. Power off the phone. Remove SD and SIM cards 2023-01-25 21:24:55.594 2. Press 'Vol-' and insert USB cable 2023-01-25 21:24:55.594 3. Wait until phone enters 'Fastboot' mode 2023-01-25 21:24:55.594 2023-01-25 21:24:55.594 To enable 'Upgrade' mode 2023-01-25 21:24:55.595 1. Power off the phone. Remove SD and SIM cards 2023-01-25 21:24:55.595 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2023-01-25 21:24:55.595 3. Wait until phone enters 'Upgrade mode' 2023-01-25 21:24:56.585 Refreshing serial ports list 2023-01-25 21:24:56.588 Found COM ports: 2023-01-25 21:24:56.588 1: COM1 Port komunikacyjny 2023-01-25 21:24:56.588 2: COM13 USB Serial Port 2023-01-25 21:24:56.589 3: COM8 HUAWEI USB COM 1.0 2023-01-25 21:24:56.638 Init finished 2023-01-25 21:25:05.816 Job ID: 0000000001A5C31E 2023-01-25 21:25:06.044 2023-01-25 21:25:06 2023-01-25 21:25:06.046 Starting Read Info 2023-01-25 21:25:06.049 Selected phone model: JNY-LX1 2023-01-25 21:25:06.073 Selected method: Read Info (EMUI12/Harmony) 2023-01-25 21:25:08.937 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:25:08.940 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:25:08.947 Phone connect successfully 2023-01-25 21:25:08.950 Writing bootloader KIRIN810_V3... 2023-01-25 21:25:08.953 Initializing remote service connection... 2023-01-25 21:25:10.740 Downloading resource... 2023-01-25 21:25:12.910 Writing XLOADER partition... 2023-01-25 21:25:13.463 Writing UCE partition... 2023-01-25 21:25:45.064 Writing FASTBOOT partition... 2023-01-25 21:26:06.568 Operation in progress. Please wait for instructions... 2023-01-25 21:26:18.600 Bootloader Update successfully 2023-01-25 21:26:18.600 Rebooting to fastboot mode... 2023-01-25 21:26:38.339 Searching Fastboot devices... 2023-01-25 21:27:28.319 Fastboot devices not found 2023-01-25 21:27:28.319 Read Info failed. 2023-01-25 21:27:28.319 Performed by 1.3.3 Software version. 2023-01-25 21:27:56.033 Job ID: 0000000001A2F9E0 2023-01-25 21:27:56.236 2023-01-25 21:27:56 2023-01-25 21:27:56.236 Starting Backup Firmware 2023-01-25 21:27:56.236 Selected phone model: JNY-LX1 2023-01-25 21:27:56.252 Selected method: Read backup (EMUI12/Harmony) 2023-01-25 21:27:56.252 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:27:59.408 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:28:02.549 Phone connect successfully 2023-01-25 21:28:02.549 Writing bootloader KIRIN810_V3... 2023-01-25 21:28:02.549 Initializing remote service connection... 2023-01-25 21:28:02.690 Writing XLOADER partition... 2023-01-25 21:30:18.780 Canceling... Please be patient! 2023-01-25 21:30:23.686 Backup Firmware failed. 2023-01-25 21:30:23.686 Performed by 1.3.3 Software version. 2023-01-25 21:30:33.366 Job ID: 0000000001CDEDFC 2023-01-25 21:30:33.850 2023-01-25 21:30:33 2023-01-25 21:30:33.850 Starting Backup Firmware 2023-01-25 21:30:33.866 Selected phone model: JNY-LX1 2023-01-25 21:30:33.866 Selected method: Read backup (EMUI12/Harmony) 2023-01-25 21:30:33.881 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:30:37.007 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:30:40.147 Phone connect successfully 2023-01-25 21:30:40.147 Writing bootloader KIRIN810_V3... 2023-01-25 21:30:40.147 Initializing remote service connection... 2023-01-25 21:30:40.272 Writing XLOADER partition... 2023-01-25 21:32:48.124 Canceling... Please be patient! 2023-01-25 21:32:51.218 Backup Firmware failed. 2023-01-25 21:32:51.218 Performed by 1.3.3 Software version. 2023-01-25 21:33:06.546 Job ID: 0000000001A5C392 2023-01-25 21:33:06.796 2023-01-25 21:33:06 2023-01-25 21:33:06.796 Starting Reset FRP 2023-01-25 21:33:06.796 Selected phone model: JNY-LX1 2023-01-25 21:33:06.827 Selected method: Reset Frp (EMUI12/Harmony) 2023-01-25 21:33:09.731 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:33:12.874 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:33:16.057 Phone connect successfully 2023-01-25 21:33:16.064 Writing bootloader KIRIN810_V3... 2023-01-25 21:33:16.070 Initializing remote service connection... 2023-01-25 21:33:16.198 Writing XLOADER partition... 2023-01-25 21:36:37.259 Reset FRP failed. 2023-01-25 21:36:37.266 Performed by 1.3.3 Software version. 2023-01-25 21:36:45.358 Job ID: 0000000001A2FA66 2023-01-25 21:36:45.518 2023-01-25 21:36:45 2023-01-25 21:36:45.525 Starting Read Info 2023-01-25 21:36:45.531 Selected phone model: JNY-LX1 2023-01-25 21:36:45.567 Selected method: Read Info (EMUI12/Harmony) 2023-01-25 21:36:49.015 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:36:52.138 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:36:55.307 Phone connect successfully 2023-01-25 21:36:55.314 Writing bootloader KIRIN810_V3... 2023-01-25 21:36:55.322 Initializing remote service connection... 2023-01-25 21:36:55.445 Writing XLOADER partition... 2023-01-25 21:37:30.603 Canceling... Please be patient! 2023-01-25 21:37:35.558 Read Info failed. 2023-01-25 21:37:35.565 Performed by 1.3.3 Software version. 2023-01-25 21:38:58.659 Job ID: 0000000001A5C3FD 2023-01-25 21:38:58.951 2023-01-25 21:38:58 2023-01-25 21:38:58.958 Starting Backup Firmware 2023-01-25 21:38:58.966 Selected phone model: JNY-LX1 2023-01-25 21:38:58.977 Selected method: Read backup (EMUI12/Harmony) 2023-01-25 21:38:58.985 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:38:59.019 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:38:59.053 Phone connect successfully 2023-01-25 21:38:59.062 Writing bootloader KIRIN810_V3... 2023-01-25 21:38:59.070 Initializing remote service connection... 2023-01-25 21:38:59.174 Writing XLOADER partition... 2023-01-25 21:38:59.722 Writing UCE partition... 2023-01-25 21:39:31.336 Writing FASTBOOT partition... 2023-01-25 21:39:52.857 Operation in progress. Please wait for instructions... 2023-01-25 21:40:04.889 Bootloader Update successfully 2023-01-25 21:40:04.889 Rebooting to fastboot mode... 2023-01-25 21:40:13.467 Searching Fastboot devices... 2023-01-25 21:41:03.486 Fastboot devices not found 2023-01-25 21:41:03.486 Backup Firmware failed. 2023-01-25 21:41:03.501 Performed by 1.3.3 Software version. 2023-01-25 21:43:17.958 Job ID: 0000000001A2FACD 2023-01-25 21:43:18.114 2023-01-25 21:43:18 2023-01-25 21:43:18.114 Starting Backup Firmware 2023-01-25 21:43:18.130 Selected phone model: JNY-LX1 2023-01-25 21:43:18.145 Selected method: Read backup (EMUI12/Harmony) 2023-01-25 21:43:18.145 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:43:18.177 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:43:18.224 Phone connect successfully 2023-01-25 21:43:18.224 Writing bootloader KIRIN810_V3... 2023-01-25 21:43:18.239 Initializing remote service connection... 2023-01-25 21:43:18.333 Writing XLOADER partition... 2023-01-25 21:43:18.895 Writing UCE partition... 2023-01-25 21:43:50.495 Writing FASTBOOT partition... 2023-01-25 21:44:12.000 Operation in progress. Please wait for instructions... 2023-01-25 21:44:24.047 Bootloader Update successfully 2023-01-25 21:44:24.047 Rebooting to fastboot mode... 2023-01-25 21:45:47.622 Searching Fastboot devices... 2023-01-25 21:46:37.668 Fastboot devices not found 2023-01-25 21:46:37.668 Backup Firmware failed. 2023-01-25 21:46:37.683 Performed by 1.3.3 Software version. 2023-01-25 21:47:00.016 Job ID: 0000000001A2FAFE 2023-01-25 21:47:00.329 2023-01-25 21:47:00 2023-01-25 21:47:00.329 Starting Backup Firmware 2023-01-25 21:47:00.344 Selected phone model: JNY-LX1 2023-01-25 21:47:00.360 Selected method: Read backup (EMUI12/Harmony) 2023-01-25 21:47:00.375 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:47:00.407 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:47:00.438 Phone connect successfully 2023-01-25 21:47:00.454 Writing bootloader KIRIN810_V3... 2023-01-25 21:47:00.469 Initializing remote service connection... 2023-01-25 21:47:00.563 Writing XLOADER partition... 2023-01-25 21:47:01.110 Writing UCE partition... 2023-01-25 21:47:32.709 Writing FASTBOOT partition... 2023-01-25 21:47:54.231 Operation in progress. Please wait for instructions... 2023-01-25 21:48:06.294 Bootloader Update successfully 2023-01-25 21:48:06.294 Rebooting to fastboot mode... 2023-01-25 21:51:28.722 Searching Fastboot devices... 2023-01-25 21:51:30.766 Total interfaces: 1 2023-01-25 21:51:30.766 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#ephut20506022696#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2023-01-25 21:51:30.766 Found android device: EPHUT20506022696 2023-01-25 21:51:30.766 Reading product model 2023-01-25 21:51:32.766 Reading build number 2023-01-25 21:51:34.781 Device Model: JNY-LX1 2023-01-25 21:51:34.781 System: JNY-L21 12.0.0.259(C432E5R2P2) 2023-01-25 21:51:39.783 Bootloader check failed. Connect your phone via Factory mode and perform the operation again. 2023-01-25 21:51:39.783 Current key version: huawei_key_v1 2023-01-25 21:51:39.783 Backup Firmware failed. 2023-01-25 21:51:39.799 Performed by 1.3.3 Software version. 2023-01-25 21:54:13.764 Job ID: 0000000001CDEF47 2023-01-25 21:54:14.264 2023-01-25 21:54:14 2023-01-25 21:54:14.280 Starting Backup Firmware 2023-01-25 21:54:14.296 Selected phone model: JNY-LX1 2023-01-25 21:54:14.311 Selected method: Read backup (EMUI12/Harmony) 2023-01-25 21:54:14.327 Searching HUAWEI USB COM 1.0 port... 2023-01-25 21:54:14.358 Detected HUAWEI USB COM 1.0 port 2023-01-25 21:54:14.405 Phone connect successfully 2023-01-25 21:54:14.421 Writing bootloader KIRIN810_V3... 2023-01-25 21:54:14.436 Initializing remote service connection... 2023-01-25 21:54:14.530 Writing XLOADER partition... 2023-01-25 21:54:15.077 Writing UCE partition... 2023-01-25 21:54:46.676 Writing FASTBOOT partition... 2023-01-25 21:55:08.196 Operation in progress. Please wait for instructions... 2023-01-25 21:55:20.228 Bootloader Update successfully 2023-01-25 21:55:20.228 Rebooting to fastboot mode... 2023-01-25 21:55:28.385 Searching Fastboot devices... 2023-01-25 21:55:30.354 Total interfaces: 1 2023-01-25 21:55:30.354 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#ut7tsx2058021459#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2023-01-25 21:55:30.354 Found android device: UT7TSX2058021459 2023-01-25 21:55:30.354 Reading product model 2023-01-25 21:55:32.354 Reading build number 2023-01-25 21:55:34.354 Device Model: JNY-LX1 2023-01-25 21:55:34.354 System: JNY-L21 12.0.0.259(C432E5R2P2) 2023-01-25 21:55:39.354 Removing firmware protection... 2023-01-25 21:55:39.698 Connecting to server... 2023-01-25 21:55:40.682 Private enc 0 2023-01-25 21:55:40.854 Waiting for a response from the server... 2023-01-25 21:55:45.854 Writing sign buf data 2023-01-25 21:55:47.281 FB Lock State: UNLOCKED 2023-01-25 21:55:47.296 User Lock State: LOCKED 2023-01-25 21:55:47.311 Creating a list of partitions... 2023-01-25 21:55:47.326 Response contains FAIL! 2023-01-25 21:55:47.326 invalid command 2023-01-25 21:55:47.345 Return FAIL 2023-01-25 21:55:47.401 Detected UFS partition table 2023-01-25 21:56:01.713 Backuping partition BATT_TP_PARA... 2023-01-25 21:56:01.786 Backuping partition BL2... 2023-01-25 21:56:02.047 Backuping partition BOOT... 2023-01-25 21:56:03.631 Backuping partition BOOTFAIL_INFO... 2023-01-25 21:56:03.772 Backuping partition CACHE... 2023-01-25 21:56:10.350 Backuping partition DDR_PARA... 2023-01-25 21:56:10.413 Backuping partition DFX... 2023-01-25 21:56:11.569 Backuping partition ENG_SYSTEM... 2023-01-25 21:56:12.210 Backuping partition ENG_VENDOR... 2023-01-25 21:56:13.491 Backuping partition ERECOVERY... 2023-01-25 21:56:16.335 Backuping partition ERECOVERY_RAMDISK... 2023-01-25 21:56:18.382 Backuping partition ERECOVERY_VBMETA... 2023-01-25 21:56:18.507 Backuping partition ERECOVERY_VENDOR... 2023-01-25 21:56:19.538 Backuping partition FASTBOOT... 2023-01-25 21:56:20.554 Backuping partition FRP... 2023-01-25 21:56:20.585 Backuping partition FW_HIFI... 2023-01-25 21:56:21.116 Backuping partition FW_LPM3... 2023-01-25 21:56:21.179 Backuping partition HDCP... 2023-01-25 21:56:21.257 Backuping partition HHEE... 2023-01-25 21:56:21.554 Backuping partition HISEE_FS... 2023-01-25 21:56:22.038 Backuping partition HISEE_IMG... 2023-01-25 21:56:22.288 Backuping partition ISP_BOOT... 2023-01-25 21:56:22.945 Backuping partition IVP... 2023-01-25 21:56:22.992 Backuping partition KPATCH... 2023-01-25 21:56:23.554 Backuping partition LOWPOWER_PARA... 2023-01-25 21:56:23.585 Backuping partition MISC... 2023-01-25 21:56:23.663 Backuping partition MODEM_DRIVER... 2023-01-25 21:56:24.929 Backuping partition MODEM_FW... 2023-01-25 21:56:28.492 Backuping partition MODEM_SECURE... 2023-01-25 21:56:29.039 Backuping partition MODEMNVM_BACKUP... 2023-01-25 21:56:30.054 Backuping partition MODEMNVM_CUST... 2023-01-25 21:56:31.070 Backuping partition MODEMNVM_FACTORY... 2023-01-25 21:56:32.117 Backuping partition MODEMNVM_IMG... 2023-01-25 21:56:34.381 Backuping partition MODEMNVM_UPDATE... 2023-01-25 21:56:35.568 Backuping partition NVME... 2023-01-25 21:56:35.725 Backuping partition OEMINFO... 2023-01-25 21:56:41.980 Backuping partition PATCH... 2023-01-25 21:56:44.012 Backuping partition PERSIST... 2023-01-25 21:56:44.559 Backuping partition PREAS... 2023-01-25 21:57:50.593 Backuping partition PREAVS... 2023-01-25 21:57:52.734 Backuping partition PRELOAD... 2023-01-25 21:59:06.201 Backuping partition PTABLE... 2023-01-25 21:59:06.248 Backuping partition RAMDISK... 2023-01-25 21:59:06.553 Backuping partition RECOVERY... 2023-01-25 21:59:09.233 Backuping partition RECOVERY_RAMDISK... 2023-01-25 21:59:11.283 Backuping partition RECOVERY_VBMETA... 2023-01-25 21:59:11.908 Backuping partition RECOVERY_VENDOR... 2023-01-25 21:59:12.565 Backuping partition RESERVED1... 2023-01-25 21:59:12.611 Backuping partition RRECORD... 2023-01-25 21:59:13.549 Backuping partition SECURE_STORAGE... 2023-01-25 21:59:15.605 Backuping partition SENSORHUB... 2023-01-25 21:59:16.636 Backuping partition SPLASH2... 2023-01-25 21:59:21.719 Backuping partition SUPER... 2023-01-25 22:06:03.704 Backuping partition TEEOS... 2023-01-25 22:06:04.220 Backuping partition TRUSTFIRMWARE... 2023-01-25 22:06:04.548 Backuping partition USERDATA... 2023-01-26 00:04:41.060 Backuping partition VBMETA... 2023-01-26 00:04:41.322 Backuping partition VBMETA_CUST... 2023-01-26 00:04:41.394 Backuping partition VBMETA_HW_PRODUCT... 2023-01-26 00:04:41.467 Backuping partition VBMETA_ODM... 2023-01-26 00:04:41.538 Backuping partition VBMETA_SYSTEM... 2023-01-26 00:04:41.608 Backuping partition VBMETA_VENDOR... 2023-01-26 00:04:41.683 Backuping partition VECTOR... 2023-01-26 00:04:41.981 Backuping partition VERITYKEY... 2023-01-26 00:04:42.023 Backuping partition VERSION... 2023-01-26 00:04:44.175 Backuping partition VRL... 2023-01-26 00:04:44.217 Backuping partition VRL_BACKUP... 2023-01-26 00:04:44.257 Backuping partition XLOADER... 2023-01-26 00:04:44.327 Rebooting device... 2023-01-26 00:04:44.348 Backup Firmware done. 2023-01-26 00:04:44.370 Performed by 1.3.3 Software version. |
01-26-2023, 18:57 | #8 (permalink) |
Member: 99605 Status: Offline Thanks Meter: 70 | why do not downgrade ? Job ID: 0000000001A345BC 2023-01-26 17:37:29 Starting Write Firmware(Factory mode) Selected phone model: JNY-LX1 Selected base ptable file: D:/GSM/Flashe/Huawei/l21A 102.0.0.200/PTABLE.APP Selected base update file: D:/GSM/Flashe/Huawei/l21A 102.0.0.200/UPDATE.APP PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Selected method: Write firmware (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: UT7TSX2058021459 Device Model: JNY-LX1 System: JNY-L21 12.0.0.259(C432E5R2P2) Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Writing PTABLE partition... Writing PTABLE partition... Writing XLOADER partition... Writing FASTBOOT partition... Writing BOOT partition... Writing DTBO partition... Writing VECTOR partition... Writing FW_LPM3 partition... Writing HHEE partition... Writing VBMETA partition... Writing TEEOS partition... Writing TRUSTFIRMWARE partition... Writing SENSORHUB partition... Writing FW_HIFI partition... Writing MODEMNVM_UPDATE partition... Writing MODEMNVM_CUST partition... Writing MODEM_DRIVER partition... Writing RECOVERY partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VENDOR partition... Writing RECOVERY_VBMETA partition... Writing ERECOVERY partition... Writing ERECOVERY_RAMDISK partition... Writing ERECOVERY_VENDOR partition... Writing ERECOVERY_VBMETA partition... Writing PREAS partition... Writing PREAVS partition... Writing ENG_VENDOR partition... Writing ENG_SYSTEM partition... Writing CACHE partition... Writing RAMDISK partition... Writing SUPER partition... Writing 1 chunk from 2... Writing 2 chunk from 2... Writing SUPER partition... Writing 1 chunk from 9... Writing 2 chunk from 9... Writing 3 chunk from 9... Writing 4 chunk from 9... Writing 5 chunk from 9... Writing 6 chunk from 9... Writing 7 chunk from 9... Writing 8 chunk from 9... Writing 9 chunk from 9... Writing METADATA partition... Writing VBMETA_SYSTEM partition... Writing VBMETA_VENDOR partition... Writing VBMETA_ODM partition... Writing VBMETA_HW_PRODUCT partition... Writing VBMETA_CUST partition... Writing ISP_FIRMWARE partition... Writing MODEM_FW partition... Writing NPU partition... Writing HISEE_IMG partition... Writing VERSION partition... Writing PRELOAD partition... Writing PATCH partition... Writing USERDATA partition... Write Firmware(Factory mode) done. Performed by 1.3.3 Software version. Job ID: 0000000001A34727 2023-01-26 17:54:07 Starting Read Info Selected phone model: JNY-LX1 Searching Fastboot devices... Found android device: UT7TSX2058021459 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: JNY-L21 System: JNY-L21 12.0.0.259(C432E5R2P2) Android Version: 10 Base Version: JNY-LGRP2-OVS 102.0.0.259 Custom Version: JNY-L21-CUST 102.0.0.5(C432) Preload Version: JNY-L21-PRELOAD 102.0.0.2(C432R2) C_Version: C432 D_Version: D000 Read Info done. Performed by 1.3.3 Software version. |
01-26-2023, 18:58 | #9 (permalink) |
01-26-2023, 19:15 | #10 (permalink) |
Member: 99605 Status: Offline Thanks Meter: 70 | many minutes later Job ID: 0000000001A34727 2023-01-26 17:54:07 Starting Read Info Selected phone model: JNY-LX1 Searching Fastboot devices... Found android device: UT7TSX2058021459 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: JNY-L21 System: JNY-L21 12.0.0.259(C432E5R2P2) Android Version: 10 Base Version: JNY-LGRP2-OVS 102.0.0.259 Custom Version: JNY-L21-CUST 102.0.0.5(C432) Preload Version: JNY-L21-PRELOAD 102.0.0.2(C432R2) C_Version: C432 D_Version: D000 Read Info done. Performed by 1.3.3 Software version. Job ID: 0000000001A347E7 2023-01-26 18:03:49 Starting ON/OFF Factory Mode Selected phone model: JNY-LX1 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V4... Initializing remote service connection... Downloading resource... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Error: Fastboot devices not found ON/OFF Factory Mode canceled. Performed by 1.3.3 Software version. Job ID: 0000000001A613AC 2023-01-26 18:05:53 Starting Reset Huawei ID Selected phone model: JNY-LX1 Selected method: Reset Huawei Id (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: UT7TSX2058021459 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: JNY-LX1 System: JNY-LGRP2-OVS 12.0.0.220 Android Version: 10 Base Version: JNY-LGRP2-OVS 102.0.0.259 Custom Version: JNY-L21-CUST 102.0.0.5(C432) Preload Version: JNY-L21-PRELOAD 102.0.0.2(C432R2) C_Version: C432 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: JNY-LX1 System: JNY-LGRP2-OVS 12.0.0.220 MEID: A00000B7158D2F IMEI A: 863204044893968 IMEI B: 863204044933970 Writing secure data... Resetting Huawei ID... Reset Huawei ID done. Performed by 1.3.3 Software version. and done thanks for help |
The Following User Says Thank You to siudziu For This Useful Post: |
01-27-2023, 20:50 | #11 (permalink) | |
Freak Poster Join Date: May 2006 Location: Slovakia
Member: 272319 Status: Offline Thanks Meter: 99 | how did you solve hang on xloader? i have 3 pcs where i cant boot device corectly, hangs on 93/94% Writing XLOADER partition... i try 3 computers, downgraded using usb to 102.0.0.220 C432, but still cand boot to remove huawei id Quote:
01-30-2023, 17:35 | #13 (permalink) |
Member: 272319 Status: Offline Thanks Meter: 99 | But it doesnt go to promt when it ask to reconect, it doesnt write Xloader right after it corecctly detect HUAWEI USB COM 1.0... Hangs on 93/94% and then reset huawei id failed... Others devices i reseted previously, have dont have this type of issue. |
04-28-2023, 17:13 | #15 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: Here
Member: 2102546 Status: Offline Thanks Meter: 480 | Quote:
version is JNY-L21 12.0.0.268(C432E5R2P2) Best Regards | Yoba | |
