02-08-2022, 16:21 | #1 (permalink) |
Insane Poster Join Date: Nov 2012 Location: Algeria
Member: 1841732 Status: Offline Thanks Meter: 25 | P40 Lite JNY-Lx1 Huawei ID Remove Done To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM3 USB Serial Port 2: COM128 Exynos USB Device Job ID: 0000000002381C8C 2022-02-08 14:12:20 Starting Read Info Selected phone model: JNY-LX1 Searching Fastboot devices... Found android device: EPHUT20C22024182 Detected Android Sooner Single ADB Interface port Device Model: JNY-L21 System: JNY-L21 10.1.0.316(C432E1R6P1) Android Version: 10 Base Version: JNY-LGRP2-OVS 10.1.0.316 Custom Version: JNY-L21-CUST 10.1.0.1(C432) Preload Version: JNY-L21-PRELOAD 10.1.0.1(C432R6) C_Version: C432 D_Version: D000 Read Info done. Performed by 1.2.8 Software version. Job ID: 0000000002381CEC 2022-02-08 14:13:22 Starting ON/OFF Factory Mode Selected phone model: JNY-LX1 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching Fastboot devices... Found android device: EPHUT20C22024182 Detected Android Sooner Single ADB Interface port Device Model: JNY-LX1 System: JNY-L21 10.1.0.316(C432E1R6P1) Removing firmware protection... Connecting to server... Error: Data encryption failed ON/OFF Factory Mode failed. Performed by 1.2.8 Software version. Job ID: 0000000002381D4B 2022-02-08 14:14:21 Starting ON/OFF Factory Mode Selected phone model: JNY-LX1 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching Fastboot devices... Found android device: EPHUT20C22024182 Detected Android Sooner Single ADB Interface port Device Model: JNY-LX1 System: JNY-L21 10.1.0.316(C432E1R6P1) Removing firmware protection... Connecting to server... Error: Data encryption failed ON/OFF Factory Mode failed. Performed by 1.2.8 Software version. Job ID: 0000000002382912 2022-02-08 14:44:29 Starting Reset Huawei ID Selected phone model: JNY-LX1 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN810_V2... Initializing remote service connection... Downloading additional resources... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: UT7TSX2115007787 Detected Android Sooner Single ADB Interface port Device Model: JNY-LX1 System: JNY-L21 10.1.0.316(C432E1R6P1) Android Version: 10 Base Version: JNY-LGRP2-OVS 10.1.0.316 Custom Version: JNY-L21-CUST 10.1.0.1(C432) Preload Version: JNY-L21-PRELOAD 10.1.0.1(C432R6) C_Version: C432 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: ########### Checking balance... Your balance: ### credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: JNY-LX1 System: JNY-L21 10.1.0.316(C432E1R6P1) Resetting Huawei ID... Formatting secure data... Rebooting device... Reset Huawei ID done. Performed by 1.2.8 Software version. |
The Following 2 Users Say Thank You to yahia80yassine For This Useful Post: |
