09-22-2020, 02:37 | #1 (permalink) |
Freak Poster Join Date: Mar 2016
Member: 2542848 Status: Offline Thanks Meter: 80 | P9 Lite not go usb com1.0 [Answered] need fix. here logs Welcome to Octoplus Huawei Software v.1.2.1.1 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM3 USB Serial Port 2020-09-22 01:28:04 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: VNS-L31 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! Performing OFF Factory Mode operation... Searching Fastboot devices... Found a fastboot device: FUH0216A11003538 System: VNS-L31C636B100 IMEI A: 863066035235198 S/N: FUH0216A11003538 Using the following method... Error: Reading partition xloader failed! ON/OFF Factory Mode failed. Performed by 1.2.1.1 Software version. 2020-09-22 01:29:01 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: VNS-L31 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! Performing OFF Factory Mode operation... Searching Fastboot devices... Found a fastboot device: FUH0216A11003538 System: VNS-L31C636B100 IMEI A: 863066035235198 S/N: FUH0216A11003538 Using the following method... Error: Reading partition xloader failed! ON/OFF Factory Mode failed. Performed by 1.2.1.1 Software version. Loading the latest update news.. |
09-22-2020, 08:17 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. Please put the phone into Upgrade mode (press and hold Vol+ and Vol- buttons, connect USB cable), then do "ON/OFF Factory Mode" operation. |
09-22-2020, 13:23 | #3 (permalink) | |
Member: 2542848 Status: Offline Thanks Meter: 80 | Quote:
I try with your instruction but not working. I hope you will fix it as soon as possible. here logs, Welcome to Octoplus Huawei Software v.1.2.1.1 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM3 USB Serial Port 3: COM5 Android Adapter PCUI 4: COM6 DBAdapter Reserved Interface 5: COM7 HUAWEI Mobile Connect - Fake Acm Interface 2020-09-22 12:20:37 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: VNS-L31 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! Performing ON Factory Mode operation... Checking firmware package type Initializing remote service connection... Downloading patch files from server... Error: Downloading files from server failed! Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.1.1 Software version. 2020-09-22 12:21:07 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: VNS-L31 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! Performing ON Factory Mode operation... Checking firmware package type Initializing remote service connection... Downloading patch files from server... Error: Downloading files from server failed! Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.1.1 Software version. | |
