Please I need urgent help [Answered] Welcome to Octoplus Huawei Software v.1.2.5 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 2021-09-23 12:30:35 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: MRD-LX1 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Checking the existence of the auto firmware file... Performing ON Factory Mode operation... Initializing remote service connection... Checking firmware package type Searching device in Upgrade mode... Detected DBAdapter Reserved Interface port Connecting to phone.. Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.5 Software version. 2021-09-23 12:30:41 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: MRD-LX1 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Checking the existence of the auto firmware file... Performing ON Factory Mode operation... Initializing remote service connection... Checking firmware package type Searching device in Upgrade mode... Detected DBAdapter Reserved Interface port Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Error: Failed write BASE_VERLIST partition and Now the phone is stuck eRecovery plz octoplus team help me |
Hello. You can try to flash your device via upgrade mode to the same firmware or higher. Also, perform Read Info operation via Fastboot mode and post here results. |
MODEL : MRD-LX1F BULID : MRD-L21A 9.1.0.268(C431E5) PSID : FAILED (remote: Command not allowed) VERSION : FAILED (remote: invald oeminforead sub cmd) Country : hw/meafnaf FB:user Lock state is lock fbLock state is lock USER:user Lock state is lock fbLock state is lock Bootloader state:locked |
Starting Read Info (Fastboot Mode) Selected phone model: MRD-LX1 Searching Fastboot devices... Found a fastboot device: 4C5QPQ18CD150214 Product Model: MRD-LX1F Build Number: MRD-L21A 9.1.0.268(C431E5) Region Code: C431E5 Android Version: 9 Base Version: JAT-LGRP1-CHN 9.1.0.260 Custom Version: JAT-AL00-CUST 9.1.0.120(C00) Preload Version: JAT-AL00-PRELOAD 9.0.1.9(C00R1) C_Version: C00 D_Version: D000 DeviceName: MRD-L41A Read Info (Fastboot Mode) done. Performed by 1.2.5 Software version. |
how can fix imei plz |
