01-20-2022, 08:06 | #1 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | SNE-LX1 FRp failed [Solved] Welcome to Octoplus Huawei Software v.1.2.8 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM4 USB Serial Port 2: COM1 İletişim Bağlantı Noktası Job ID: 000000000222DC63 2022-01-20 06:59:55 Starting Reset FRP Selected phone model: SNE-LX1 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Reset FRP failed. Performed by 1.2.8 Software version. |
01-20-2022, 08:21 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. Use device with the battery connected and use USB cable directly into the USB port on the motherboard. Repeat operation once again and post here results. We'll check it. |
The Following User Says Thank You to Octopus support For This Useful Post: |
01-20-2022, 08:28 | #3 (permalink) | |
Member: 194907 Status: Offline Thanks Meter: 114 | Quote:
Job ID: 000000000222E138 2022-01-20 07:23:26 Starting Reset FRP Selected phone model: SNE-LX1 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: HVYDU19412005701 Detected Android Sooner Single ADB Interface port Device Model: SNE-LX1 System: SNE-LX1 10.0.0.288(C432E12R1P1) Android Version: 10 Base Version: SNE-LGRP2-OVS 10.0.0.288 Custom Version: SNE-LX1-CUST 10.0.0.12(C432) Preload Version: SNE-LX1-PRELOAD 10.0.0.1(C432R1) C_Version: C432 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: SNE-LX1 System: SNE-LX1 10.0.0.288(C432E12R1P1) Resetting FRP... Writing FRP partition.. Rebooting device... Reset FRP done. Performed by 1.2.8 Software version. | |
The Following User Says Thank You to leventc For This Useful Post: |
