04-18-2021, 18:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | stk-l21mdv failed factory mode off [Solved] Found COM ports: 1: COM12 HUAWEI USB COM 1.0 2: COM50 USB Serial Port 3: COM10 USB Serial Port 2021-04-18 15:59:49 GMT ------------------------------------------------- Starting Reset FRP (Factory Mode) Selected phone model: STK-L21 Username: elpringy Connecting to the credit server... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Error: Failed to open COM port COM12 Error: Connecting to COM12 failed Reset FRP (Factory Mode) failed. Performed by 1.2.5 Software version. 2021-04-18 16:01:06 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: STK-L21 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Error: Failed to open COM port COM12 Error: Connecting to COM12 failed ON/OFF Factory Mode failed. Performed by 1.2.5 Software version. 2021-04-18 16:03:42 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: STK-L21 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching HUAWEI USB COM 1.0 port... Error: Serial port HUAWEI USB COM 1.0 is not available at the moment! Error: Failed to open COM port COM12 Error: Connecting to COM12 failed ON/OFF Factory Mode failed. Performed by 1.2.5 Software version. 2021-04-18 16:03:45 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: STK-L21 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Canceling... Please be patient! ON/OFF Factory Mode failed. Performed by 1.2.5 Software version. 2021-04-18 17:11:15 GMT ------------------------------------------------- Starting Reset FRP (Factory Mode) Selected phone model: STK-L21 Username: elpringy Connecting to the credit server... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found a fastboot device: 2ABVB20512001784 Device Model: STK-L21 System: STK-L21MDV 10.0.0.191(C185E3R3P1) Checking balance... Your balance: 100 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Removing firmware protection... Reset FRP (Factory Mode) failed. Performed by 1.2.5 Software version. 2021-04-18 17:13:30 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: STK-L21 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found a fastboot device: 2ABVB20512001784 Detected Android Sooner Single ADB Interface port Device Model: STK-L21 System: STK-L21MDV 10.0.0.191(C185E3R3P1) Removing firmware protection... ON/OFF Factory Mode failed. Performed by 1.2.5 Software version. 2021-04-18 17:14:50 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: STK-L21 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found a fastboot device: 2ABVB20512001784 Detected Android Sooner Single ADB Interface port Device Model: STK-L21 System: STK-L21MDV 10.0.0.191(C185E3R3P1) Removing firmware protection... ON/OFF Factory Mode failed. Performed by 1.2.5 Software version. |
04-18-2021, 18:43 | #2 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | now done Device Model: STK-L21 System: STK-L21MDV 10.0.0.191(C185E3R3P1) Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Writing secure data... Rebooting device... ON/OFF Factory Mode done. Performed by 1.2.5 Software version. |
The Following User Says Thank You to elpring For This Useful Post: |
04-18-2021, 18:53 | #3 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | ON/OFF Factory Mode done. Performed by 1.2.5 Software version. 2021-04-18 17:49:47 GMT ------------------------------------------------- Starting Reset FRP (Factory Mode) Selected phone model: STK-L21 Username: elpringy Connecting to the credit server... Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found a fastboot device: 2ABVB20512001784 Device Model: STK-L21 System: STK-LGRP3-OVS 10.0.0.191 Checking balance... Your balance: 100 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: STK-L21 System: STK-LGRP3-OVS 10.0.0.191 Resetting FRP... Writing FRP partition.. Rebooting device... Reset FRP (Factory Mode) done. Performed by 1.2.5 Software version. |
04-18-2021, 18:53 | #4 (permalink) |
