07-05-2018, 12:28 | #3 (permalink) |
No Life Poster Join Date: Feb 2010 Location: TURKEY
Member: 1245396 Status: Offline Sonork: BR*BY*PROF*47*47* Thanks Meter: 109 | Phone Nokia 5 I want to do all the way closed and 1024 device imei repair way tied to how I'm going to connect Tool can't connect call imei repair for |
07-05-2018, 14:26 | #5 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,151 | still can't understand anything if your phone is in EDL mode, NTool do not support phones in EDL mode. if your phone normally working and NTool can't detect phone, then run Drivers\setup.exe as administrator |
07-05-2018, 20:27 | #7 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,151 | setup drivers from ntool\drivers folder press desired operation connect powered off phone most probably, windows using other drivers for your phone manually change drivers for fastboot device to drivers from HMD or use clean OS |
The Following User Says Thank You to the_laser For This Useful Post: |
