06-10-2018, 11:40 | #1 (permalink) |
Junior Member Join Date: May 2012 Location: algeria
Member: 1763771 Status: Offline Thanks Meter: 2 | nokia ta-1035 can not connect to the software !! help plz !! |
06-10-2018, 13:36 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | NTool will only detect phone if original HMD drivers installed. 100% that phone using other Fastboot drivers, so you have several options - use clean OS, install drivers from NTool package and use NTool - manually select proper fastboot drivers, when phone connected in fastboot mode. ( Driver provider : HMD global, driver version : 1.0.0.0 ) ps. NTool do not work with phones with damaged boot ( EDL mode, BROM mode ) |
06-12-2018, 15:01 | #5 (permalink) |
Member: 1763771 Status: Offline Thanks Meter: 2 | Code: 10/06/2018 15:27:52 RUNNING NTool 0.029 10/06/2018 15:27:58 SERVER CREDITS LEFT/USED: 20/0 10/06/2018 15:27:58 Elapsed: 0 secs. 10/06/2018 15:29:45 PHONE "E1MGA2E7A2613903" CONNECTED 10/06/2018 15:29:45 model : E1M 10/06/2018 15:29:45 sub_model : none 10/06/2018 15:29:45 software version : E1M-037C-0-00WW-B03 10/06/2018 15:29:45 SW model : 00WW 10/06/2018 15:29:45 build number : B03 10/06/2018 15:29:45 hardware version : 3.0 10/06/2018 15:29:46 RF band id : 10/06/2018 15:29:46 NKNOWN 10/06/2018 15:29:46 chip version : none 10/06/2018 15:29:46 MCP info : none 10/06/2018 15:29:46 EMMC version : Hynix 5.1 8GB 10/06/2018 15:29:46 SIM : 2 10/06/2018 15:29:46 secure:yes 10/06/2018 15:29:46 Bootloader type : commercial 10/06/2018 15:29:46 Max chunk size : 00000250 mB 10/06/2018 15:29:46 Elapsed: 99 secs. 10/06/2018 15:30:33 10/06/2018 15:30:33 SELECT FIRMWARE PACKAGE 10/06/2018 15:30:39 Will flash : E1M-064D-0-00WW-B01.NBx 10/06/2018 15:30:39 PLEASE CONNECT POWERED OFF PHONE 10/06/2018 15:35:43 PROCEDURE STOPPED BY USER 10/06/2018 15:35:43 Elapsed: 310 secs. 10/06/2018 15:36:45 PHONE "E1MGA2E7A2613903" CONNECTED 10/06/2018 15:36:46 model : E1M 10/06/2018 15:36:46 sub_model : none 10/06/2018 15:36:46 software version : E1M-037C-0-00WW-B03 10/06/2018 15:36:46 SW model : 00WW 10/06/2018 15:36:46 build number : B03 10/06/2018 15:36:46 hardware version : 3.0 10/06/2018 15:36:46 RF band id : 10/06/2018 15:36:46 NKNOWN 10/06/2018 15:36:46 chip version : none 10/06/2018 15:36:46 MCP info : none 10/06/2018 15:36:46 EMMC version : Hynix 5.1 8GB 10/06/2018 15:36:46 SIM : 2 10/06/2018 15:36:46 secure:yes 10/06/2018 15:36:46 Bootloader type : commercial 10/06/2018 15:36:46 Max chunk size : 00000250 mB 10/06/2018 15:36:46 Elapsed: 9 secs. 10/06/2018 15:37:09 10/06/2018 15:37:09 SELECT FIRMWARE PACKAGE 10/06/2018 15:37:12 Will flash : E1M-064D-0-00WW-B01.NBx 10/06/2018 15:37:12 PLEASE CONNECT POWERED OFF PHONE 10/06/2018 15:37:19 PHONE "E1MGA2E7A2613903" CONNECTED 10/06/2018 15:37:20 model : E1M 10/06/2018 15:37:20 sub_model : none 10/06/2018 15:37:20 software version : E1M-037C-0-00WW-B03 10/06/2018 15:37:20 SW model : 00WW 10/06/2018 15:37:20 build number : B03 10/06/2018 15:37:20 hardware version : 3.0 10/06/2018 15:37:20 RF band id : 10/06/2018 15:37:20 NKNOWN 10/06/2018 15:37:20 chip version : none 10/06/2018 15:37:20 MCP info : none 10/06/2018 15:37:20 EMMC version : Hynix 5.1 8GB 10/06/2018 15:37:20 SIM : 2 10/06/2018 15:37:20 secure:yes 10/06/2018 15:37:20 Bootloader type : commercial 10/06/2018 15:37:21 Max chunk size : 00000250 mB 10/06/2018 15:37:22 BOOTLOADER AUTH PASSED 10/06/2018 15:37:22 Flash "E1M-0-064D-emmc_appsboot_service.zip" to "aboot" 10/06/2018 15:37:24 PHONE "E1MGA2E7A2613903" REMOVED 10/06/2018 15:37:27 PHONE "E1MGA2E7A2613903" CONNECTED 10/06/2018 15:37:27 Perform auth routine 10/06/2018 15:37:27 Security version : 0004 10/06/2018 15:37:27 ProjectCode : E1M 10/06/2018 15:37:27 UID : 97126b1aa0083d87f2d3f9dd41b5a8a29f4421c9 10/06/2018 15:37:27 Waiting for calculation process ... 10/06/2018 15:37:27 RESPONSE: "SUCCESS" [256] 10/06/2018 15:37:27 SERVICE AUTH PASSED 10/06/2018 15:37:27 Flash "E1M-0-064D-gpt_both0.bin" to "partition" 10/06/2018 15:37:28 Skip flashing "E1M-0-064D-emmc_appsboot_service.mbn" 10/06/2018 15:37:28 Skip flashing "E1M-0-064D-emmc_appsboot_service.mbn" 10/06/2018 15:37:28 Flash "E1M-0-064D-emmc_appsboot_service.zip" to "aboot" 10/06/2018 15:37:28 Flash "E1M-0-064D-emmc_appsboot_service.zip" to "abootbak" 10/06/2018 15:37:28 Flash "E1M-0-064D-rpm.mbn" to "rpm" 10/06/2018 15:37:28 Flash "E1M-0-064D-rpm.mbn" to "rpmbak" 10/06/2018 15:37:28 Flash "E1M-0-064D-multi-sbl1.img" to "sbl1_all" 10/06/2018 15:37:28 Flash "E1M-0-064D-multi-sbl1.img" to "sbl1bak_all" 10/06/2018 15:37:28 Flash "E1M-0-064D-tz.mbn" to "tz" 10/06/2018 15:37:28 Flash "E1M-0-064D-tz.mbn" to "tzbak" 10/06/2018 15:37:28 Flash "E1M-0-064D-cmnlib.mbn" to "cmnlib" 10/06/2018 15:37:29 Flash "E1M-0-064D-cmnlib.mbn" to "cmnlibbak" 10/06/2018 15:37:29 Flash "E1M-0-064D-keymaster.mbn" to "keymaster" 10/06/2018 15:37:29 Flash "E1M-0-064D-keymaster.mbn" to "keymasterbak" 10/06/2018 15:37:29 Perform fastboot command "reboot-bootloader" 10/06/2018 15:37:29 PHONE "E1MGA2E7A2613903" REMOVED 10/06/2018 15:37:32 PHONE "E1MGA2E7A2613903" CONNECTED 10/06/2018 15:37:32 Perform auth routine 10/06/2018 15:37:32 Security version : 0004 10/06/2018 15:37:32 ProjectCode : E1M 10/06/2018 15:37:32 UID : 97126b1aa0083d87f2d3f9dd41b5a8a29f4421c9 10/06/2018 15:37:32 Waiting for calculation process ... 10/06/2018 15:37:32 RESPONSE: "SUCCESS" [256] 10/06/2018 15:37:33 SERVICE AUTH PASSED 10/06/2018 15:37:33 Flash "E1M-00WW-021-splash.img" to "splash" 10/06/2018 15:37:33 Flash "E1M-0-064D-ftm.img" to "ftm" 10/06/2018 15:37:34 Flash "E1M-0-064D-00WW-boot.img" to "boot" 10/06/2018 15:37:36 Flash "E1M-0-064D-00WW-system.img" to "system" 10/06/2018 15:41:13 Flash "userdata" 10/06/2018 15:41:33 Flash "E1M-0-064D-00WW-recovery.img" to "recovery" 10/06/2018 15:41:35 Flash "E1M-0-064D-0001-persist.img" to "persist" 10/06/2018 15:41:36 Erase "cache" 10/06/2018 15:41:36 Flash "E1M-00WW-001-sutinfo.img" to "sutinfo" 10/06/2018 15:41:36 Flash "E1M-0-064D-NON-HLOS.bin" to "modem" 10/06/2018 15:41:43 Flash "E1M-0-0030-0001-hidden.img.ext4" to "hidden" 10/06/2018 15:41:46 Flash "E1M-00WW-021-cda.img" to "cda" 10/06/2018 15:41:47 Flash "fver" to "systeminfo" 10/06/2018 15:41:47 Flash "E1M-0-0010-0001-userdata-ftm.img.ext4" to "ftmlog" 10/06/2018 15:41:50 Flash "E1M-0-064D-emmc_appsboot.mbn" to "aboot" 10/06/2018 15:41:50 Flash "E1M-0-064D-emmc_appsboot.mbn" to "abootbak" 10/06/2018 15:41:50 Flash "md5.dat" to "md5" 10/06/2018 15:42:55 FINISHED 10/06/2018 15:42:55 Elapsed: 335 secs. Last edited by the_laser; 06-12-2018 at 16:54. |
06-12-2018, 16:55 | #6 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | try different firmware version, E1M-115B-0-00WW-B01.NBx.zip show flashing log, please use [code] tag - it keep log readable and forum tidy it is also worth to use "service" and just rewrite same values |
06-13-2018, 14:48 | #7 (permalink) |
Member: 1763771 Status: Offline Thanks Meter: 2 | When I try to flash E1M-115B-0-00WW-B01.NBx.zip it remains stuck on write system every time it remains stuck at a different stage of the previous one is more advanced or less but still in the step write system |
06-16-2018, 11:40 | #9 (permalink) |
Member: 1763771 Status: Offline Thanks Meter: 2 | Code: 13/06/2018 17:09:07 RUNNING NTool 0.029 13/06/2018 17:09:12 SERVER CREDITS LEFT/USED: 10/10 13/06/2018 17:09:12 Elapsed: 0 secs. 13/06/2018 17:09:15 13/06/2018 17:09:15 SELECT FIRMWARE PACKAGE 13/06/2018 17:09:23 Will flash : E1M-115B-0-00WW-B01.NBx 13/06/2018 17:09:23 PLEASE CONNECT POWERED OFF PHONE 13/06/2018 17:10:14 PHONE "E1MGA2E7A2613903" CONNECTED 13/06/2018 17:10:14 ReadCommBlock : Un périphérique attaché au système ne fonctionne pas correctement 13/06/2018 17:10:14 FATAL ERROR: oem getversions : L’opération a réussi 13/06/2018 17:10:15 Elapsed: 0 secs. 13/06/2018 17:16:04 13/06/2018 17:16:04 SELECT FIRMWARE PACKAGE 13/06/2018 17:16:12 Will flash : E1M-115B-0-00WW-B01.NBx 13/06/2018 17:16:12 PLEASE CONNECT POWERED OFF PHONE 13/06/2018 17:16:18 PHONE "E1MGA2E7A2613903" CONNECTED 13/06/2018 17:16:19 model : E1L 13/06/2018 17:16:19 sub_model : none 13/06/2018 17:16:19 software version : E1M-064D-0-00WW-B01 13/06/2018 17:16:19 SW model : 00WW 13/06/2018 17:16:19 build number : B01 13/06/2018 17:16:19 hardware version : 3.0 13/06/2018 17:16:19 RF band id : 13/06/2018 17:16:19 _850_900_1800_1900^W_1_2_4_5_8^L_2_3_4_5_7_12_17_28_38 13/06/2018 17:16:19 chip version : none 13/06/2018 17:16:19 MCP info : none 13/06/2018 17:16:19 EMMC version : Hynix 5.1 8GB 13/06/2018 17:16:19 SIM : 2 13/06/2018 17:16:19 secure:yes 13/06/2018 17:16:19 Bootloader type : service 13/06/2018 17:16:20 Max chunk size : 00000250 mB 13/06/2018 17:16:21 Security version : 0004 13/06/2018 17:16:21 ProjectCode : E1M 13/06/2018 17:16:21 UID : 97126b1aa0083d87f2d3f9dd41b5a8a29f4421c9 13/06/2018 17:16:21 Waiting for calculation process ... 13/06/2018 17:16:21 RESPONSE: "SUCCESS" [256] 13/06/2018 17:16:22 SERVICE AUTH PASSED 13/06/2018 17:16:23 Perform auth routine 13/06/2018 17:16:23 Flash "E1M-0-115B-gpt_both0.bin" to "partition" 13/06/2018 17:16:23 Skip flashing "E1M-0-115B-emmc_appsboot_service.mbn" 13/06/2018 17:16:23 Flash "E1M-0-115B-emmc_appsboot_service.zip" to "aboot" 13/06/2018 17:16:23 Flash "E1M-0-115B-rpm.mbn" to "rpm" 13/06/2018 17:16:23 Flash "E1M-0-115B-rpm.mbn" to "rpmbak" 13/06/2018 17:16:23 Flash "E1M-0-115B-multi-sbl1.img" to "sbl1_all" 13/06/2018 17:16:23 Flash "E1M-0-115B-multi-sbl1.img" to "sbl1bak_all" 13/06/2018 17:16:23 Flash "E1M-0-115B-tz.mbn" to "tz" 13/06/2018 17:16:24 Flash "E1M-0-115B-tz.mbn" to "tzbak" 13/06/2018 17:16:24 Flash "E1M-0-115B-cmnlib.mbn" to "cmnlib" 13/06/2018 17:16:24 Flash "E1M-0-115B-cmnlib.mbn" to "cmnlibbak" 13/06/2018 17:16:24 Flash "E1M-0-115B-keymaster.mbn" to "keymaster" 13/06/2018 17:16:24 Flash "E1M-0-115B-keymaster.mbn" to "keymasterbak" 13/06/2018 17:16:24 Perform fastboot command "reboot-bootloader" 13/06/2018 17:16:24 PHONE "E1MGA2E7A2613903" REMOVED 13/06/2018 17:16:27 PHONE "E1MGA2E7A2613903" CONNECTED 13/06/2018 17:16:27 Perform auth routine 13/06/2018 17:16:27 Security version : 0004 13/06/2018 17:16:27 ProjectCode : E1M 13/06/2018 17:16:27 UID : 97126b1aa0083d87f2d3f9dd41b5a8a29f4421c9 13/06/2018 17:16:27 Waiting for calculation process ... 13/06/2018 17:16:27 RESPONSE: "SUCCESS" [256] 13/06/2018 17:16:27 SERVICE AUTH PASSED 13/06/2018 17:16:27 Flash "E1M-00WW-025-splash.img" to "splash" 13/06/2018 17:16:28 Flash "E1M-0-115B-ftm.img" to "ftm" 13/06/2018 17:16:43 WriteCommBlockInt : Le délai de temporisation de sémaphore a expiré 13/06/2018 17:16:43 WriteCommBlock blk write fail 13/06/2018 17:16:43 FATAL ERROR: write error while downloading "ftm" 13/06/2018 17:16:43 Elapsed: 24 secs. 13/06/2018 17:20:28 SERVER CREDITS LEFT/USED: 10/10 13/06/2018 17:20:28 Elapsed: 0 secs. 13/06/2018 17:20:30 13/06/2018 17:20:30 SELECT FIRMWARE PACKAGE 13/06/2018 17:20:39 Will flash : E1M-115B-0-00WW-B01.NBx 13/06/2018 17:20:39 PLEASE CONNECT POWERED OFF PHONE 13/06/2018 17:20:45 PHONE "E1MGA2E7A2613903" CONNECTED 13/06/2018 17:20:46 model : E1L 13/06/2018 17:20:46 sub_model : none 13/06/2018 17:20:46 software version : E1M-064D-0-00WW-B01 13/06/2018 17:20:46 SW model : 00WW 13/06/2018 17:20:46 build number : B01 13/06/2018 17:20:46 hardware version : 3.0 13/06/2018 17:20:46 RF band id : 13/06/2018 17:20:46 _850_900_1800_1900^W_1_2_4_5_8^L_2_3_4_5_7_12_17_28_38 13/06/2018 17:20:46 chip version : none 13/06/2018 17:20:46 MCP info : none 13/06/2018 17:20:46 EMMC version : Hynix 5.1 8GB 13/06/2018 17:20:46 SIM : 2 13/06/2018 17:20:46 secure:yes 13/06/2018 17:20:46 Bootloader type : service 13/06/2018 17:20:47 Max chunk size : 00000250 mB 13/06/2018 17:20:47 ReadCommBlock : Un périphérique attaché au système ne fonctionne pas correctement 13/06/2018 17:20:47 FATAL ERROR: oem getversions 13/06/2018 17:20:47 Elapsed: 1 secs. 13/06/2018 17:21:37 13/06/2018 17:21:37 SELECT FIRMWARE PACKAGE 13/06/2018 17:21:42 Will flash : E1M-115B-0-00WW-B01.NBx 13/06/2018 17:21:42 PLEASE CONNECT POWERED OFF PHONE 13/06/2018 17:21:48 PHONE "E1MGA2E7A2613903" CONNECTED 13/06/2018 17:21:49 model : E1L 13/06/2018 17:21:49 sub_model : none 13/06/2018 17:21:49 software version : E1M-064D-0-00WW-B01 13/06/2018 17:21:49 SW model : 00WW 13/06/2018 17:21:49 build number : B01 13/06/2018 17:21:49 hardware version : 3.0 13/06/2018 17:21:49 RF band id : 13/06/2018 17:21:49 _850_900_1800_1900^W_1_2_4_5_8^L_2_3_4_5_7_12_17_28_38 13/06/2018 17:21:49 chip version : none 13/06/2018 17:21:49 MCP info : none 13/06/2018 17:21:49 EMMC version : Hynix 5.1 8GB 13/06/2018 17:21:49 SIM : 2 13/06/2018 17:21:49 secure:yes 13/06/2018 17:21:49 Bootloader type : service 13/06/2018 17:21:49 Max chunk size : 00000250 mB 13/06/2018 17:21:50 Security version : 0004 13/06/2018 17:21:50 ProjectCode : E1M 13/06/2018 17:21:50 UID : 97126b1aa0083d87f2d3f9dd41b5a8a29f4421c9 13/06/2018 17:21:51 Waiting for calculation process ... 13/06/2018 17:21:51 RESPONSE: "SUCCESS" [256] 13/06/2018 17:21:51 SERVICE AUTH PASSED 13/06/2018 17:21:52 Perform auth routine 13/06/2018 17:21:52 Flash "E1M-0-115B-gpt_both0.bin" to "partition" 13/06/2018 17:21:52 Skip flashing "E1M-0-115B-emmc_appsboot_service.mbn" 13/06/2018 17:21:52 Flash "E1M-0-115B-emmc_appsboot_service.zip" to "aboot" 13/06/2018 17:21:53 Flash "E1M-0-115B-rpm.mbn" to "rpm" 13/06/2018 17:21:53 Flash "E1M-0-115B-rpm.mbn" to "rpmbak" 13/06/2018 17:21:53 Flash "E1M-0-115B-multi-sbl1.img" to "sbl1_all" 13/06/2018 17:21:53 Flash "E1M-0-115B-multi-sbl1.img" to "sbl1bak_all" 13/06/2018 17:21:53 Flash "E1M-0-115B-tz.mbn" to "tz" 13/06/2018 17:21:53 Flash "E1M-0-115B-tz.mbn" to "tzbak" 13/06/2018 17:21:53 Flash "E1M-0-115B-cmnlib.mbn" to "cmnlib" 13/06/2018 17:21:53 Flash "E1M-0-115B-cmnlib.mbn" to "cmnlibbak" 13/06/2018 17:21:53 Flash "E1M-0-115B-keymaster.mbn" to "keymaster" 13/06/2018 17:21:53 Flash "E1M-0-115B-keymaster.mbn" to "keymasterbak" 13/06/2018 17:21:53 Perform fastboot command "reboot-bootloader" 13/06/2018 17:21:54 PHONE "E1MGA2E7A2613903" REMOVED 13/06/2018 17:21:56 PHONE "E1MGA2E7A2613903" CONNECTED 13/06/2018 17:21:56 Perform auth routine 13/06/2018 17:21:56 Security version : 0004 13/06/2018 17:21:56 ProjectCode : E1M 13/06/2018 17:21:56 UID : 97126b1aa0083d87f2d3f9dd41b5a8a29f4421c9 13/06/2018 17:21:56 Waiting for calculation process ... 13/06/2018 17:21:57 RESPONSE: "SUCCESS" [256] 13/06/2018 17:21:57 SERVICE AUTH PASSED 13/06/2018 17:21:57 Flash "E1M-00WW-025-splash.img" to "splash" 13/06/2018 17:21:57 Flash "E1M-0-115B-ftm.img" to "ftm" 13/06/2018 17:21:59 Flash "E1M-0-115B-00WW-boot.img" to "boot" 13/06/2018 17:22:00 Flash "E1M-0-115B-00WW-system.img" to "system" 13/06/2018 17:27:00 Flash "userdata" 13/06/2018 17:27:22 Flash "E1M-0-115B-00WW-recovery.img" to "recovery" 13/06/2018 17:27:24 Flash "E1M-0-115B-0001-persist.img" to "persist" 13/06/2018 17:27:25 Erase "cache" 13/06/2018 17:27:25 Flash "E1M-00WW-001-sutinfo.img" to "sutinfo" 13/06/2018 17:27:25 Flash "E1M-0-115B-NON-HLOS.bin" to "modem" 13/06/2018 17:27:32 Flash "E1M-0-0030-0001-hidden.img.ext4" to "hidden" 13/06/2018 17:27:35 Flash "E1M-00WW-025-cda.img" to "cda" 13/06/2018 17:27:36 Flash "fver" to "systeminfo" 13/06/2018 17:27:36 Flash "E1M-0-0010-0001-userdata-ftm.img.ext4" to "ftmlog" 13/06/2018 17:27:38 Flash "E1M-0-115B-emmc_appsboot.mbn" to "aboot" 13/06/2018 17:27:39 Flash "E1M-0-115B-emmc_appsboot.mbn" to "abootbak" 13/06/2018 17:27:39 Flash "md5.dat" to "md5" 13/06/2018 17:28:46 FINISHED 13/06/2018 17:28:46 Elapsed: 418 secs. 13/06/2018 17:57:20 SERVER CREDITS LEFT/USED: 10/10 13/06/2018 17:57:20 Elapsed: 0 secs. |
06-16-2018, 15:06 | #11 (permalink) |
Member: 1763771 Status: Offline Thanks Meter: 2 | after having managed to flash it I find it without IMEI, when I want to repair it it does not pass it remains stuck on "REBOOT TO FACTORY MODE ..." and the phone reboots itself |
06-17-2018, 13:22 | #12 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | reflash phone and try again if phone can't reboot to factory mode after reflash - it means modem security zone damaged, NTool for a moment can only service phones with valid security zone. |
06-18-2018, 17:57 | #13 (permalink) |
Member: 1763771 Status: Offline Thanks Meter: 2 | can not install the driver for "FACTORY MODE" Code: USB\VID_0489&PID_C02E&REV_0318&MI_00 USB\VID_0489&PID_C02E&REV_0318&MI_01 USB\VID_0489&PID_C02E&REV_0318&MI_02 |
06-19-2018, 11:42 | #15 (permalink) |
Member: 1763771 Status: Offline Thanks Meter: 2 | Code: PLEASE CONNECT POWERED OFF PHONE PHONE "E1MGA2E7A2613903" CONNECTED ProjectCode : E1M model : E1L sub_model : none software version : E1M-115B-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 3.0 RF band id : _850_900_1800_1900^W_1_2_4_5_8^L_2_3_4_5_7_12_17_28_38 chip version : none MCP info : none EMMC version : Hynix 5.1 8GB SIM : 2 secure : yes Bootloader type : commercial Download size : 00000250 mB Security version : 0004 Challenge : 6c51c6d201a8ccaa80871bb974f4989d243d4563 Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "E1M-0-1140-emmc_appsboot_service.zip" to "aboot" PHONE "E1MGA2E7A2613903" REMOVED PHONE "E1MGA2E7A2613903" CONNECTED Security version : 0004 ProjectCode : E1M UID : 97126b1aa0083d87f2d3f9dd41b5a8a29f4421c9 Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Perform auth routine Flash "E1M-0-1140-ftm.img" to "ftm" Flash "E1M-0-1140-emmc_appsboot.mbn" to "aboot" REBOOT TO FACTORY MODE ... FATAL ERROR: Shell(): unknown status, got: 4C494146) Elapsed: 40 secs. |
