11-21-2018, 16:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Europe Age: 39
Member: 51989 Status: Offline Sonork: 1575109 Thanks Meter: 145 | How use Ktester function? (A built in temperature tester function that can accurately and efficiently measure solder iron and hot air temperature (Measurement range: -125 - 1200 ℃, Tolerance: ± 1 ℃) in real time . This way you can be sure your rework tools are correctly calibrated and working at peak performance) I try calibrate, but irework show stange number, it is bug in firmware or device? This is my video: https://youtu . be/DqX1cYdIsEE Last edited by stylius; 11-21-2018 at 16:40. |
11-23-2018, 18:01 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,025 | Quote:
Something wrong , can you adjust your iron like 100 degrees and test it if working , maybe this sensor wire connected opposite ! inside box there is 1 red / 1 black wire on the board ! thanks | |
