Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 04-16-2021, 21:55   #1 (permalink)
Member: 617539
Thanks Meter: 64
dead redmi 9c after flash,help! [Answered]
Please help flashing redmi 9c by checking all options and now it does not turn on nor can I re-flash.
ow To Boot : Power off phone
15:22:13 : * BROM Mode : Press VOL + or Press VOL -+
15:22:13 : * Preloader Mode : Just Insert cable
15:22:13 :
15:22:14 : Searching for MTK Device...
15:22:14 : Found
15:22:14 : Port Identification :
15:22:14 : Flashmode BROM
15:22:14 : FriendlyName :
15:22:14 : MediaTek USB Port (COM33)
15:22:14 : SymbolicName :
15:22:14 : \??\USB#VID_0E8D&PID_0003#5&3279cb56&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
15:22:14 : Driver Ver :
15:22:14 : 01/22/2016,3.2
15:22:14 :
15:22:14 :
15:22:14 :
15:22:14 : Reading Device UniqueID, RAM and Flash Chip Info...
15:22:14 : UNIQUE ID :
15:22:14 : E2C45D5B1E8614D252363070F9235281
15:22:14 : ERAM Size :
15:22:14 : 0x000000000003A000
15:22:14 : -232 KB
15:22:14 : IRAM Size :
15:22:14 : 0x0000000080000000
15:22:14 : -2 GB
15:22:14 : eMMC BOOT1 :
15:22:14 : 0x0000000000400000
15:22:14 : -4 MB
15:22:14 : eMMC BOOT2 :
15:22:14 : -4 MB
15:22:14 : eMMC RPMB :
15:22:15 : 0x0000000000400000
15:22:15 : -4 MB
15:22:15 : eMMC USER :
15:22:15 : 0x0000000747C00000
15:22:15 : -29.121 GB
15:22:15 : eMMC CID :
15:22:15 : 150100424A54443452090211488877D9
15:22:15 : - BJTD4R
15:22:15 :
15:22:15 : Reading GPT
15:22:15 : -EMMC
15:22:15 : [0x00008000]
15:22:15 : 130 Items
15:22:15 :
15:22:15 : Flashing Selected Partitions....
15:22:15 : -
15:22:15 : preloader
15:22:15 : [preloader_k65v1_64_bsp.bin]
15:22:15 : 256 KB
15:22:15 : Erasing..
15:22:16 : Ok
15:22:17 : Flash ->
15:22:17 : =
15:22:17 : Ok
15:22:17 : -
15:22:17 : recovery
15:22:18 : [recovery.img]
15:22:18 : 64 MB
15:22:18 : Erasing..
15:22:19 : Ok
15:22:19 : Flash ->
15:22:24 : =
15:22:24 : Ok
15:22:24 : -
15:22:24 : cust
15:22:24 : [cust.img]
15:22:24 : 832 MB
15:22:24 : Erasing..
15:22:25 : Ok
15:22:25 : Flash ->
15:22:25 : ERROR : ACK : 0xC0020005[STATUS_SEC_IMG_TOO_LARGE]
15:22:25 : =
15:22:25 : Failed
15:22:25 :
15:22:25 : Rebooting Device
15:22:25 : [Reboot To Normal]
15:22:26 : Reboot Done!!
15:22:26 : =====================================
15:22:26 :
try again and drop this error,
SYNC
15:25:36 : Mode :
15:25:36 : brom
15:25:36 : Preloader Initialization...
15:25:36 : Parsing
15:25:36 : preloader_k65v1_64_bsp.bin
15:25:36 : Init :
15:25:39 : Accepted
15:25:39 :
15:25:39 : Execute Secondary Loader
15:25:39 : Init :
15:25:39 : Loader [2]
15:25:39 : Executing :
15:25:39 : [STATUS_DA_HASH_MISMATCH]
15:25:39 : Denied
15:25:39 : ========================================
15:25:39 : Some reasons it fails due to the following:
15:25:39 : 1. Download Agent not match with the phone
15:25:39 : 2. Hardware issues, Please check the phone.
15:25:39 : 3. Please connect your cable directly to usb port.
15:25:40 : =====================================
15:25:40 :
15:25:40 : Elapsed Time : 00:00:17
15:25:40 :
help help
Old 04-16-2021, 22:03   #2 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello,
Log is not clear, Please post a screen shot.
Best Regards | Hydra Team
Old 04-16-2021, 22:14   #3 (permalink)
Member: 617539
Thanks Meter: 64
here I try to read and it boots error, in the third image it reads it tries to flash but it stays there ...
https://ibb.co/bXq8BW8
https://ibb.co/yP52TRy
https://ibb.co/hWQRYSr
Old 04-17-2021, 03:58   #4 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,623
After checking your screen short, I can guess that your Device might have hardware problem. Hydra Tool already warned you stop flashing! "Phone is not responding with synchronization command, Hydra detected that your phone has hardware issue/problem. Do you want to continue booting ?" In such a case you have to stop flashing!
Please check for hardware first and try to flash later.
( Después de revisar su pantalla breve, puedo adivinar que su dispositivo podría tener un problema de hardware. ¡Hydra Tool ya te advirtió que dejes de parpadear! "El teléfono no responde con el comando de sincronización, Hydra detectó que su teléfono tiene un problema / problema de hardware. ¿Desea continuar iniciando?" En tal caso, ¡debe dejar de parpadear!
por favor Primero verifique el hardware e intente flashear más tarde. )
Dipendra Pathak
Old 04-17-2021, 17:56   #5 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
What was your phone`s problem before flashing??
Old 04-17-2021, 21:04   #6 (permalink)
Member: 617539
Thanks Meter: 64
the problem was to recover the second imei, since it only showed the first imei, then I proceeded to flash, and it did not finish ... but well thanks for answering ... the only thing I can say is that I already solved
The Following User Says Thank You to alexgatin For This Useful Post:
Page generated in 0.16314 seconds with 8 queries
