09-06-2022, 12:34 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Failed to decode pattern.Failed oppo a37 Windows 10 (Version 1903, OS Build 18362.30, 64-bit Edition) Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz NVIDIA GeForce GT 710 Ram Installed : 8 GB Windows Access Right : Admin Software Run As Admnistrator PreOperation Configuration Brand : OPPO Model : A33 2020 (CPH2137) Storage : Auto Loader: c:\hydra tool\hfirehose\007050e10029001e_cc3153a80293939b_a e162be1_asus_qualcomm_peek_8916.fhprg Port : Auto Searching for Qualcomm 9008 Device...Found FriendlyName :Qualcomm HS-USB QDLoader 9008 (COM14) SymbolicName :\??\USB#VID_05C6&PID_9008#5&53c06f5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver Ver :05/29/2019,2.1.3.7 Getting device info..Ok Device MODE : Firehose Connecting to Firehose... Ping.. Ok Configuration....... Identifying Chip.... Ok Chip Configuration : MemoryName : eMMC MaxPayloadSizeToTargetInBytes : 16384 MaxPayloadSizeToTargetInBytesSupported : 16384 MaxPayloadSizeFromTargetInBytes : 4096 MaxXMLSizeInBytes : 4096 TargetName : 8916 Version : 1 Protocol : Universal Running : Ok Reading GPT[3] Drive [0] 40 Items Drive [1] 0 Items Drive [2] 4 Items Phone Information..... Brand : OPPO Vendor : OPPO Model : A37f ID : LMY47V SDK : 22 Release : 5.1.1 ABI : arm64-v8a CPU abilist : arm64-v8a,armeabi-v7a,armeabi Description : msm8916_64-user 5.1.1 LMY47V eng.root.20190711.032745 release-keys Board : msm8916 Display ID : A37fEX_11_190711 Security Patch : 2018-03-01 Platform : msm8916 FRPPST : /dev/block/bootdevice/by-name/config Operation : ScreenLock Security Read Pattern Processing... Trying to search : gatekeeper.pattern.key Trying to search : personalpattern.key Trying to search : cm_gesture.key Trying to search : gesture.key FOUND Gesture Data : 856DB02FF09312E1214274219C38120CC4F15ECE Bruteforcing pattern hash..Please wait for few seconds Failed to decode pattern.Failed Elapsed Time : 00:00:02 Hydra Qualcomm Tool Ver 1.0.3.50 Windows 10 (Version 1903, OS Build 18362.30, 64-bit Edition) Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz NVIDIA GeForce GT 710 Ram Installed : 8 GB Windows Access Right : Admin Software Run As Admnistrator PreOperation Configuration Brand : OPPO Model : A33 2020 (CPH2137) Storage : Auto Loader: c:\hydra tool\hfirehose\007050e10029001e_cc3153a80293939b_a e162be1_asus_qualcomm_peek_8916.fhprg Port : Auto Searching for Qualcomm 9008 Device...Found FriendlyName :Qualcomm HS-USB QDLoader 9008 (COM14) SymbolicName :\??\USB#VID_05C6&PID_9008#5&53c06f5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver Ver :05/29/2019,2.1.3.7 Getting device info..Ok Device MODE : Firehose Connecting to Firehose... Ping.. Ok Configuration....... Identifying Chip.... Ok Chip Configuration : MemoryName : eMMC MaxPayloadSizeToTargetInBytes : 16384 MaxPayloadSizeToTargetInBytesSupported : 16384 MaxPayloadSizeFromTargetInBytes : 4096 MaxXMLSizeInBytes : 4096 TargetName : 8916 Version : 1 Protocol : Universal Running : Ok Reading GPT[3] Drive [0] 40 Items Drive [1] 0 Items Drive [2] 4 Items Phone Information..... Brand : OPPO Vendor : OPPO Model : A37f ID : LMY47V SDK : 22 Release : 5.1.1 ABI : arm64-v8a CPU abilist : arm64-v8a,armeabi-v7a,armeabi Description : msm8916_64-user 5.1.1 LMY47V eng.root.20190711.032745 release-keys Board : msm8916 Display ID : A37fEX_11_190711 Security Patch : 2018-03-01 Platform : msm8916 FRPPST : /dev/block/bootdevice/by-name/config Operation : ScreenLock Security Remove Lock Without Data Loss Processing... .. Searching possible patching addressFailed Elapsed Time : 00:00:02 |
09-10-2022, 07:03 | #3 (permalink) |
Product Manager Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Hello, You Userdata is not Encrypted, You can using Read Pattern Function, Please post feedback with a clear screen shot, Thank you. Best Regards | Hydra Team |
