Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 11 / iPhone 11 Pro / iPhone 11 Pro Max
Old 02-13-2021, 07:06   #1 (permalink)
Member: 787357
Thanks Meter: 2
iphone 11 restarting solution please..
water damage phone 11,
separated and fixed everything is ok but restarting after some time,
The Following 2 Users Say Thank You to satyacellular For This Useful Post:
Old 02-25-2021, 16:44   #2 (permalink)
Member: 2330242
Thanks Meter: 3
same problem complete changed
Old 03-11-2021, 14:15   #3 (permalink)
Member: 787357
Thanks Meter: 2
Secondary mic issue problem solved..
Sent from my SM-G975F using Tapatalk
Old 04-02-2021, 01:52   #4 (permalink)
Member: 2882830
And what you do? Ic or change cable
Thank you
Old 09-26-2021, 17:32   #5 (permalink)
Member: 601591
Thanks Meter: 86
Firstly Switch on your phone and remove the ear peace flex if not working change the charging flex cable with original one it can be from iCloud phone that you trust is not restarting lastly if persists flash your phone 100% working. Pls once is done don't forget to press the thanks button.
The Following User Says Thank You to baloo2000 For This Useful Post:
Old 12-03-2021, 10:04   #6 (permalink)
Member: 1834146
Sonork: closed
Thanks Meter: 12
Upper flex! change then done.
Sent from my iPhone using Tapatalk
Old 12-03-2021, 10:35   #7 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 253
did someone her knows panic log analizer?it can help you to determine what cause the restart..
Old 12-20-2021, 11:34   #8 (permalink)
nelsky_1974's Avatar
Member: 1352482
Thanks Meter: 24
iphone 11
hi bro good day!
please try to desconnect the charging cable from the mother broad.
and try to use..
tnx
Old 12-20-2021, 13:32   #9 (permalink)
Member: 2524994
ear speaker strip change
Old 12-20-2021, 15:28   #10 (permalink)
Member: 2140712
Thanks Meter: 40
check your phone data analysis in setting
Page generated in 0.15544 seconds with 8 queries
