10-15-2019, 12:29 | #16 (permalink) |
No Life Poster Join Date: Mar 2019 Location: saturn
Member: 2901996 Status: Offline Thanks Meter: 917 | Code: Device : A310F Operation : Reset FRP - ADB Method Searching for Device...Found :) Brand : samsung Model : SM-J250F Product : j2y18lte Device : j2y18lte Andriod Ver. : 7.1.1 Patch Level : 2019-08-01 PDA : J250FXWS2ASI3 Bootloader : FA71_J250FXXU2ARC2 Build ID : NMF26X.J250FXWS2ASI3 Build Date : Mon Sep 16 22:03:28 KST 2019 Checking Root Status...OK Root : No Root Resetting FRP Lock...OK Finished Succesfully. Elapsed Time: 00:27 GSMShield Samsung 1.0 |
The Following 4 Users Say Thank You to Titan_GSM For This Useful Post: |
10-16-2019, 14:12 | #17 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Oppo A57 Frp Remove Done Very Easy By Gsm Shield Box Br amn32 |
The Following 3 Users Say Thank You to amn32 For This Useful Post: |
10-17-2019, 16:33 | #19 (permalink) |
Member: 2901996 Status: Offline Thanks Meter: 917 | Gionee P7 MT6737T Read Info/pattern/FRP reset Done By GSMSHIELD MTK Tool read info: Code: Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: GSMSHIELD MTK 1.0 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM9) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x513832334d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100513832334D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM17) Display ID: amigo3.2.0 Build ID: MRA58K Version: 6.0 FRP partition: /dev/block/platform/mtk-msdc.0/11230000.msdc0/by-name/frp Mediatek Version Release: alps-mp-m0.mp1-V2.115_gionee6737t.66.m0_P271 Brand: GIONEE Device: GIONEE_WBL7365 Manufacturer: GIONEE Model: GIONEE P7 This phone have FRP partition. IMEI[1]: 861969xxxxxxxx IMEI[2]: 861969xxxxxxxx Wait untill phone will start charging. [0]All done. Format: Code: Action : Format UserData. Selected 0-By CPU:ELBRUS Exe version: GSMSHIELD MTK 1.0 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM9) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x513832334d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100513832334D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM17) Detecting format adress....wait! Starting generic userdata format...! Partition: cache begin: 0x10b000000 length: 0x19000000 Partition: userdata begin: 0x124000000 length: 0x27ed80000 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. Wait untill phone will start charging. [0]All done. Code: Exe version: GSMSHIELD MTK 1.0 Selected model: 0-By CPU ELBRUS [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM9) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x513832334d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100513832334D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Checking data, wait... Writing FRP, wait... FRP Reset Done. Wait untill phone will start charging. [0]All done. Regards. |
The Following 3 Users Say Thank You to Titan_GSM For This Useful Post: |
