02-15-2023, 19:26 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Huawei Y6P MED-LX9 Repair imei Done One Click By GsmShield Box Exe version: GSMSHIELD MTK 2.5 Selected phone: MT6765 Action : IMEI REPAIR. Phone must be off with battery inside. Battery must be charged Please insert USB cable now... Keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(17) : MediaTek USB Port (COM17) [17] \\?\usb#vid_0e8d&pid_0003#6&1c34a361&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3e800]Dumping phone preloader. Preloader: C:\GSMShield\MTK_Gsmshield_Backup_Folder\preloader _backup\preloader_k62v1_64_mex_a32.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(17) : MediaTek USB Port (COM17) [17] \\?\usb#vid_0e8d&pid_0003#6&1c34a361&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A68433861 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe91000000 [58.266 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(18) : MediaTek DA USB VCOM (Android) (COM18) [18] \\?\usb#vid_0e8d&pid_2001#6&1c34a361&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Reading imei IMEI[1]: 86xxxxxxxxxxxx IMEI[2]: 86xxxxxxxxxxxx Backup saved: C:\GSMShield\MTK_Gsmshield_Backup_Folder\nvram_bac kup\FLASH_MODE_NVRAM_MT6765_xxxxxxxxxx_02_15_2023_ 20_47_34.zip Writing imei [helio]IMEI[1] TO UPDATE: 86222xxxxxxxxx1 [helio]IMEI[2] TO UPDATE: 86222xxxxxxxxx9 Generic IMEI OK Writing imei in proinfo file. Write proinfo ok. [helio]Processing dinamic imei. [helio]IMEI[1] TO UPDATE: 86222xxxxxxxxx1 [helio]IMEI[2] TO UPDATE: 86222xxxxxxxxx9 Write done [helio]Wait untill phone will start charging. [0]All done. A Very Big Thanks To Nck Team |
The Following User Says Thank You to amn32 For This Useful Post: |
