09-21-2020, 05:26 | #17 (permalink) |
Banned Join Date: Mar 2019 Location: Gsm-Boss Age: 46
Member: 2902804 Status: Offline Sonork: 100.1660513 Thanks Meter: 928 | amazing eMMc ISP Realme 5i RMX2030 Read Info/ Disable Screen Lock Without Data Loss/ Safe-Deep Fs Format/Remove FRP OPPO A1k CPH1923 Read Info/ Disable Screen Lock Without Data Loss/ Safe-Deep Fs Format/Remove FRP OPPO A3s CPH1853 Read Info/ Disable Screen Lock Without Data Loss/ Safe-Deep Fs Format/Remove FRP OPPO A5 CPH1809 Read Info/ Disable Screen Lock Without Data Loss/ Safe-Deep Fs Format/Remove FRP OPPO F5 CPH1723 Read Info/ Disable Screen Lock Without Data Loss/ Safe-Deep Fs Format/Remove FRP OPPO F5 CPH1725 Read Info/ Disable Screen Lock Without Data Loss/ Safe-Deep Fs Format/Remove FRP OPPO A37F Neo9 Read Info/ Disable Screen Lock Without Data Loss/ Safe-Deep Fs Format/Remove FRP MI Redmi Mi4x Read Info/ Disable Screen Lock Without Data Loss/ Safe-Deep Fs Format/Remove FRP |
The Following User Says Thank You to Gsm-Boss. For This Useful Post: |
09-23-2020, 06:10 | #23 (permalink) | |
Freak Poster Join Date: Jun 2014 Location: Ghana - Mozano
Member: 2203321 Status: Offline Thanks Meter: 46 | Quote:
Oppo A3S CPH1803 in EDL or jtag? Does it work in EDL mode or we have to connect in jtagging? | |
09-25-2020, 03:49 | #28 (permalink) |
Junior Member Join Date: Sep 2020 Location: China Age: 33
Member: 2968509 Status: Offline Thanks Meter: 1 | Redmi 6 pro flash authorization failure 10:42:04 - Warning : This Device Requires Xiaomi Authorization! 10:42:04 - Initializing MI Offline Server.. 10:42:04 - Requesting Auth Signature.. 10:42:06 - MI-Offline Phone Authorization Failed.. 10:42:06 - Please Try Using Non-Auth Loader and Repeat Process! 10:42:06 - Finished with Error! |
09-25-2020, 12:49 | #29 (permalink) | |
Freak Poster Join Date: Apr 2017 Location: China
Member: 2711124 Status: Offline Thanks Meter: 44 | Quote:
09-25-2020, 16:05 | #30 (permalink) |
Member: 2711124 Status: Offline Thanks Meter: 44 | The phone log of XIAOMI MI8 was changed to the computer and did not keep it. Today, I tested a redmi 3 flashing machine and prompted a driver error, but I used miflash flashing machine without prompting an error. 23:01:52 - Initializing.. 23:01:55 - Token ID : 130B1A110D0A053E 23:01:55 - Serial : XXXXXX 23:01:56 - Detecting Device Interface.. 23:01:56 - Interface : Qualcomm HS-USB QDLoader 9008 (COM87) 23:01:56 - Driver Description :Qualcomm HS-USB QDLoader 9008 23:01:56 - Driver :Qualcomm Incorporated 23:01:56 - Switching Phone Mode.. 23:01:56 - Preparing Device Comunication.. 23:01:56 - Failed to Switch Phone to Desired Mode.. 23:01:56 - Please Put Phone in Edl Mode and Try Again.. 23:01:56 - Make Sure Correct Edl Drivers are Correctly Installed.. 23:01:56 - Finished with Error! |
