09-26-2020, 14:08 | #1 (permalink) | |
No Life Poster Join Date: Aug 2008 Location: Spain
Member: 840762 Status: Offline Thanks Meter: 166 | WOW Fix redmi 7a system destroyed by Aqua dongle flash with offline authorization *Need: edl testpoint and offline server aqua Tab Qualcomm, all model in auto mode, check: rawprogram file: rawprogram0.xml patch file: patch0.xml check "write firmware" Quote:
*note: the xiaomi tab, not work property, by flash bat, not found files and by factory flash mode "no job" fail. Please check this support. BR | |
The Following User Says Thank You to NEOCRIVI For This Useful Post: |
09-26-2020, 23:47 | #2 (permalink) |
Insane Poster Join Date: Oct 2018 Location: Atlantis
Member: 2870784 Status: Offline Thanks Meter: 759 | Thank you for report We will make xiaomi tab more easy in next update You can join our telegram group and be a beta tester Regards |
The Following User Says Thank You to AquaDongle For This Useful Post: |
09-27-2020, 17:34 | #3 (permalink) |
Freak Poster Join Date: Apr 2017 Location: China
Member: 2711124 Status: Offline Thanks Meter: 44 | I haven’t successfully flashed the Mi option by flash bat. Press by flash ZIP. There should be a problem with the Mi option flashing. |
The Following User Says Thank You to du10086 For This Useful Post: |
09-28-2020, 04:37 | #4 (permalink) |
Member: 2711124 Status: Offline Thanks Meter: 44 | mi 8 上午 10:51:07 - Initializing.. 上午 10:51:13 - Token ID : 130B1A110D0A053E 上午 10:51:13 - Serial : xxxxxxx 上午 10:51:15 - Detecting Device Interface.. 上午 10:51:15 - Interface : Qualcomm HS-USB QDLoader 9008 (COM4) 上午 10:51:15 - Driver Description :Qualcomm HS-USB QDLoader 9008 上午 10:51:15 - Driver :Qualcomm Incorporated 上午 10:51:15 - Switching Phone Mode.. 上午 10:51:15 - Preparing Device Comunication.. 上午 10:51:15 - Serial : 29DEDF1C 上午 10:51:15 - Hw Id :000027001E0B8000 上午 10:51:15 - Oem Hash : c924a35f39ce1cdd1b8d5a9f3b8e3c51317930431d7a9dd5a5 5028cf6965fe65 上午 10:51:15 - Warning : New Type of Variant Found! 上午 10:51:15 - SBl : 00000001 上午 10:51:15 - Sending Loader.. 上午 10:51:16 - Hash : B7CD103D356103AFF7858C5B80E5EA08D611EA7E 上午 10:51:20 - Sending Ping.. 上午 10:51:20 - Binary Build : Oct 23 2019 @ 23:19:25 上午 10:51:20 - Chip Serial : 702471964 (0x29dedf1c) 上午 10:51:22 - Warning : This Device Requires Xiaomi Authorization! 上午 10:51:22 - Initializing MI Offline Server.. 上午 10:51:22 - Requesting Auth Signature.. 上午 10:51:24 - Phone Authorization okay.. 上午 10:51:27 - Version : 1 上午 10:51:27 - Max XML : 4096 上午 10:51:27 - Memory type :UFS 上午 10:51:27 - Write Buffer : 0 上午 10:51:27 - ***New Type of Loader Detected*** 上午 10:51:27 - Please eMail this Loader to : [email protected] 上午 10:51:27 - Adding Loader to Local Database.. 上午 10:51:27 - Please eMail this Loader For Auto Support in Next Update.. 上午 10:51:29 - Updating Loader Details in Server Database.. 上午 10:51:30 - Starting Write Process.. 上午 10:51:30 - Writing Partition [switch] -> [dummy.img] |
10-02-2020, 03:58 | #6 (permalink) | |
Member: 2711124 Status: Offline Thanks Meter: 44 | Quote:
19:07:45-Token ID: 130B1A110D0A053E 19:07:45-Serial: xxxxxx 19:07:47-Detecting Device Interface.. 19:07:47-Interface: Qualcomm HS-USB QDLoader 9008 (COM22) 19:07:47-Driver Description :Qualcomm HS-USB QDLoader 9008 19:07:47-Driver :Qualcomm Incorporated 19:07:47-Switching Phone Mode.. 19:07:47-Preparing Device Comunication.. 19:07:47-Serial: 51F2D207 19:07:47-Hw Id :000027001E0BD000 19:07:47-Oem Hash: c924a3Bkquxud8JdwBQ9sHt62CpYzBZyLsKdBUw0431d7a9dd5 a55028cf6965fe65 19:07:47-Warning: New Type of Variant Found! 19:07:47-SBl: 00000001 19:07:47-Sending Loader.. 19:07:47-Hash: CC71F7CD8B2C32630782BF8D2432B1867DDC5167 19:07:51-Sending Ping.. 19:07:51-Binary Build: Sep 26 2019 @ 01:58:18 19:07:51-Chip Serial: 1374867975 (0x51f2d207) 19:07:54-Warning: This Device Requires Xiaomi Authorization! 19:07:54-Initializing MI Offline Server.. 19:07:54-Requesting Auth Signature.. 19:07:56-MI-Offline Phone Authorization Failed.. 19:07:56-Please Try Using Non-Auth Loader and Repeat Process! 19:07:56-Starting Write Process.. 19:07:56-Writing Partition [switch] -> [dummy.img] | |
