ipad air 2 A1567 error 14 ??? hi , i have ipad air 2 ios 13.6 i try shift + update to ios 14.2 then i got itunes error 14 itry 3utools and get error 20 how to fix my problem by magico diag tool please help asap:confused::confused::confused::confused: |
please need help :rolleyes::rolleyes::rolleyes::rolleyes: |
Step 1 : Connect Magico Diag Tool,Enter purple screen mode Step 2: Click "Backup SYSCFG." to backup hard disk data Step 3:Click "Clear All Date" to clear the hard disk data Step 4: Click "Exit recovery mode, Exit diagnosis" to exit the purple screen, When you see a white apple on the screen, remove the Magico Diag Tool. Step 5: Connect Linghtning USB Cable, Restore with iTunes,it Will report error 53 Step 6: Connect Magico Diag Tool,Enter purple screen mode Step 7: Click "Wr.backup SYS." to write backup data Step 8: Click "Exit recovery mode, Exit diagnosis" to exit the purple screen, When you see a white apple on the screen, remove the Magico Diag Tool. Step 9 : Connect Linghtning USB Cable, Restore with iTunes,Done |
i do steps from 1 to 4 step 5 when restoring i got same error 14 by iTunes 3utools stuck at 20% writing file system ?????:confused::confused::confused::confused: now ipad stuck at recovery mode |
did you try to change sn??? |
no , my device is 4g support sim not wifi only |
no answer admin @MagicoTeam |
what is device history? |
I do update with retain data via 3utools and update failed at20% I try via itunes and got error 14 I try fresh restore but same error |
HI 1)itunes update last version 2)use other PC |
I try with different pc and laptop and macbook but same error??? |
itry all same problem |
