Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Magico Box Team > Magico Diag Tool
Old 12-20-2020, 13:24   #1 (permalink)
Member: 1275819
Thanks Meter: 12
ipad air 2 A1567 error 14 ???
hi , i have ipad air 2 ios 13.6
i try shift + update to ios 14.2 then i got itunes error 14
itry 3utools and get error 20
how to fix my problem by magico diag tool
please help asap
Old 12-20-2020, 21:27   #2 (permalink)
Member: 1275819
Thanks Meter: 12
please help asap
please need help
Old 12-21-2020, 07:47   #3 (permalink)
Member: 1963632
Thanks Meter: 264
Step 1 : Connect Magico Diag Tool,Enter purple screen mode
Step 2: Click "Backup SYSCFG." to backup hard disk data
Step 3:Click "Clear All Date" to clear the hard disk data
Step 4: Click "Exit recovery mode, Exit diagnosis" to exit the purple screen, When you see a white apple on the screen, remove the Magico Diag Tool.
Step 5: Connect Linghtning USB Cable, Restore with iTunes,it Will report error 53
Step 6: Connect Magico Diag Tool,Enter purple screen mode
Step 7: Click "Wr.backup SYS." to write backup data
Step 8: Click "Exit recovery mode, Exit diagnosis" to exit the purple screen, When you see a white apple on the screen, remove the Magico Diag Tool.
Step 9 : Connect Linghtning USB Cable, Restore with iTunes,Done
Old 12-21-2020, 08:58   #4 (permalink)
Member: 1275819
Thanks Meter: 12
i do steps from 1 to 4
step 5 when restoring i got same error 14 by iTunes
3utools stuck at 20% writing file system ?????
now ipad stuck at recovery mode
The Following User Says Thank You to zool2007 For This Useful Post:
Old 12-21-2020, 22:50   #5 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,816
tested 100% this procedure
Old 12-22-2020, 04:32   #6 (permalink)
Member: 1275819
Thanks Meter: 12
Not work for me same error 14
Old 12-22-2020, 15:21   #7 (permalink)
Member: 2374256
Thanks Meter: 1,453
did you try to change sn???
Old 12-22-2020, 16:22   #8 (permalink)
Member: 1275819
Thanks Meter: 12
no , my device is 4g support sim not wifi only
Old 12-23-2020, 16:19   #9 (permalink)
Member: 1275819
Thanks Meter: 12
no answer admin @MagicoTeam
Old 12-24-2020, 00:29   #10 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,816
product manager is offline because holiday
what is device history?
Old 12-25-2020, 23:56   #11 (permalink)
Member: 1275819
Thanks Meter: 12
Device working normal in ios 13
I do update with retain data via 3utools and update failed at20%
I try via itunes and got error 14
I try fresh restore but same error
Old 12-26-2020, 00:08   #12 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,816
try to restore without lcd
Old 12-26-2020, 10:48   #13 (permalink)
MagicoTeam's Avatar
Member: 2916325
Thanks Meter: 1,383
HI
1)itunes update last version
2)use other PC
Old 12-26-2020, 12:35   #14 (permalink)
Member: 1275819
Thanks Meter: 12
Itry same error
I try with different pc and laptop and macbook but same error???
Old 12-26-2020, 15:38   #15 (permalink)
Member: 1275819
Thanks Meter: 12
Originally Posted by MagicoTeam View Post
HI
2)use other PC
itry all
same problem
Page generated in 0.21693 seconds with 8 queries
