EME Mobile Tool (EMT) Official Support Section by EmeGSM Team |
03-15-2021, 20:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Redmi Note 9 Pro support in EDL mode [ANSWERED] I have Redmi Note 9 Pro - M2003J6B2G - that's stuck in bootloop. Customer bough it from China, then supposedly unlocked bootloader and wanted to flash global firmware. Phone is currently stuck in 1s bootloop with Redmi logo briefly displayed. I can't access recovery or fastboot mode. I don't see an unlocked padlock so i assume he flashed some firmware with lock bootlolader option set. When trying to flash it with other tools that i have, this model requires remote auth. I have login details to an account that was most likely used to bind the phone and unlock bootloader, but it also doesn't have authorization to flash this phone in EDL mode. Does EMT support this model correctly and have currently working auth servers? I'm asking specifically about this model because the other tool that has working auth servers doesn't work correctly with this one and errors out with "comm error 997" instead. What is the policy for credits usage? It's 8 credits per attempt, or i can use auth 2-3-4 times trying to find correct firmware? I'm currently not a user of EMT but consider buying it if it'll allow to be fix this phone. |
07-05-2021, 19:34 | #3 (permalink) |
Junior Member Join Date: May 2021 Location: mexico city
Member: 2988217 Status: Offline Thanks Meter: 0 | Hello, good afternoon. I'm talking to you from Mexico. I found a solution to remove the account of the model that I publish ............... I have the same problem ????? Any solution ??? |
07-06-2021, 15:38 | #4 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 43
Member: 50643 Status: Offline Thanks Meter: 117 | hello I made two of this model. completely dead emt supports this device.. but only server is down... You will need to flash software in edl mode (%100 solved) EMT Xiaomi (Qualcomm) Auth Server Status SERVER STATUS check find my device should be turned off (Applies to all tools) Do not forget also that there are two models that device |
07-08-2021, 00:34 | #5 (permalink) |
Member: 2988217 Status: Offline Thanks Meter: 0 | Hello Thank you very much for the prompt response ..... you can explain the steps of how I carry out the process with hydra since I have tried by various means are to be able to release the note 9 pro equipment |
07-08-2021, 12:01 | #6 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,491 | Quote:
Check EMT Xiaomi Auth Service API Status here first: https://forum.gsmhosting.com/vbb/f11...tatus-2934041/ You can flash phone in EDL mode after EMT xiaomi auth service working back. Best Regards EmeGSM Team | |
