01-02-2021, 12:46 | #1 (permalink) |
Product Manager Join Date: Jun 2020 Location: iraq Age: 49
Member: 2959521 Status: Offline Sonork: 100.1677600 Thanks Meter: 132 | How To Bypass FRP A107F with GSD Dongle 2. install Samsung Driver. (from Developer.Samsung) 3. Connect Your Device In Normally Mode. 4. Select Samsung Tab >> FRP DRK RMM Tab and click one scan then select your device com port 5. Select Your Model Number from Models list And Click One "RESET FRP (GSD METHOD)" 6. in this Step , GSD Installed New GSD Devices Driver On Your Computer and request from you to Disconnect device,In This case You Need To Disconnect device and reconnect again To Initializing New Driver 7. Click To Ok Button in GSD Dongle For Continue , GSD Send Shell On your Device and you can see View button On Your Phone Screen. 8. Click On View Button and Continue Frp Bypass Step. attention. 1. Make Sure Your windows driver signature is disabled. 2. if you dont see view button on your phone screen , close gsd dongle application and restart phone. 3. Make sure the installed driver is up to date and mtp is well detected. (Be sure to check device manager). Good Luck Last edited by gsd-dongle; 01-02-2021 at 13:11. |
The Following User Says Thank You to gsd-dongle For This Useful Post: |
