![]() | #1 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: May 2008 Location: Somewhere out there
Member: 782051 Status: Offline Thanks Meter: 10 | ![]() |
![]() | #2 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2015 Location: UKrainePH Age: 43
Member: 2418465 Status: Offline Thanks Meter: 48 | since you cannot find this model number, choose balckview a52 pro you can try to read info first, if you can read it..then there is a chance to remove it,, before erasing frp..backup first the firmware for safety purposes because they have similar chipset specs Unisoc Tiger T606 it involves trial and error method... Last edited by professorjazz; 05-23-2024 at 01:12. |
![]() | #5 (permalink) |
Member: 782051 Status: Offline Thanks Meter: 10 | Selected model: Blackview A52 Pro Operation: Read Flash Info Software version: 6.10 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX or PC] Connect phone in BROM mode. Use volume key buttons or testpoint. Waiting for device... OK Device found at COM6 Port: USB\VID_1782&PID_4D00\6&1DC3EBAB&0&2 Driver: [Spreadtrum Communication Inc.,SciU2S,SCI USB2Serial,SciU2S.sys,1.5.6.1] Port type: UBOOT Wrong USB mode. Use volume key buttons or testpoint. |
![]() | #6 (permalink) |
Member: 2418465 Status: Offline Thanks Meter: 48 | try to press volume up and down at the same time or press volume down only then insert usb cable or find testpoint (need to open, find one by one the TP area)....because this is not common brand...you cannot find it |
![]() | #8 (permalink) | |
Member: 782051 Status: Offline Thanks Meter: 10 | Quote:
Selected model: Blackview A52 Pro Operation: Erase FRP And Wipe Software version: 6.10 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX or PC] Connect phone in BROM mode. Use volume key buttons or testpoint. Waiting for device... OK Device found at COM9 Port: USB\VID_1782&PID_4D00\4908728053 Driver: [Spreadtrum Communication Inc.,SciU2S,SCI USB2Serial,SciU2S.sys,1.5.6.1] Port type: BROM Connecting to device... OK Selected processor: Tiger_T606_64 Load files... (universal) OK Connect preloader 1... error(22) Preloader error now team | |
![]() | #9 (permalink) |
Member: 782051 Status: Offline Thanks Meter: 10 | I used UMT to get into BROM mode. Phone remained connected to PC port so as to not lose BROM mode Could this be the problem? Must be connected to pandora type c port? When I pull from PC and connect to box port, receive this: Selected model: Blackview A52 Pro Operation: Read Flash Info Software version: 6.10 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX or PC] Connect phone in BROM mode. Use volume key buttons or testpoint. Waiting for device... OK Device found at COM8 Port: USB\VID_1782&PID_4D00\6&7AF759F&0&2 Driver: [Spreadtrum Communication Inc.,SciU2S,SCI USB2Serial,SciU2S.sys,1.5.6.1] Port type: UBOOT Wrong USB mode. Use volume key buttons or testpoint. |
![]() | #10 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,138 | Quote:
