Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 05-11-2024, 06:14   #1 (permalink)
austinejiasa's Avatar
Member: 1149419
Sonork: NIL
Thanks Meter: 58
Fix this bug z3x team
I HAVE TRIED SEVERALLY TO FORMAT OPPO A83 BUT I KEEP GETTING ERROR.
receive da sync signal... error(1)
Old 05-11-2024, 07:40   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,121
Hello. Provide log of operation.
Old 05-11-2024, 13:53   #3 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 58
Selected model: OPPO CPH1727 (OPPO F5)
Operation: Erase FRP And Wipe
Software version: 6.9
Erasing of partitions can damage your device.
Make sure that you have a backup created. Continue? YES
Work ID: 28073810
Connect phone in BROM Mode
Waiting for device... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM3 [BROM]
Open port... OK
Send start cmd... OK
Get HW code from device... 0690
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Get HW & SW version from device... OK
HW VER: CA01, SW VER: 0001, HW SUB CODE: 8A00
Detect chip [MT6763]
LibUSB installed
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Release testpoint, waiting 2 seconds
Advanced Bypass Security... error(13)
Operation: Wipe Data
There is a risk of data loss.
This procedure will erase all User Data
Work ID: 28073929
Open port... OK
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Advanced Bypass Security... OK
Open port... OK
Get sec config... OK [000000E0]
Active sec flags: []
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x8B211C94, 0x5BE0C9CB, 0x28B137E9, 0x0859BE7F
Get Chip ID... [MT6763]
Get SOC ID... [5F200AE7FCC8A2C63DC5E489BBDE668D238DE7F2E0F15914AE 0B5B6561985CCD]
Load DownloadAgent... OK
Search DA... OK [6]
Send preloader... OK
Start preloader... OK
Checking preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... error(1)
Old 05-11-2024, 14:02   #4 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 58
Selected model: OPPO CPH1827 (OPPO A83)
Work ID: 28075692
Open port... OK
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [6]
Old 05-11-2024, 15:15   #5 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,121
Delete and install again libusb and mtk driver. Also, try to hold tp longer/shorter time.
Old 05-11-2024, 16:30   #6 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 58
Selected model: OPPO CPH1729 (OPPO A83)
Work ID: 28097308
Connect phone in BROM/PRELOADER Mode
Open port... OK
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [6]
sdone all you instructed and still same
Old 05-14-2024, 10:48   #7 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 58
Z3x team its like this problem cannot be fixed
Old 05-14-2024, 11:24   #8 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,121
Phone powering on in this moment?
Download old firmware, choose preloader and repeat.
Page generated in 0.21296 seconds with 10 queries
