05-11-2024, 13:53 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Selected model: OPPO CPH1727 (OPPO F5) Operation: Erase FRP And Wipe Software version: 6.9 Erasing of partitions can damage your device. Make sure that you have a backup created. Continue? YES Work ID: 28073810 Connect phone in BROM Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0690 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA01, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6763] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... error(13) Selected model: OPPO CPH1727 (OPPO F5) Operation: Wipe Data Software version: 6.9 There is a risk of data loss. This procedure will erase all User Data Make sure that you have a backup created. Continue? YES Work ID: 28073929 Connect phone in BROM Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0690 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA01, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6763] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0690 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA01, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6763] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x8B211C94, 0x5BE0C9CB, 0x28B137E9, 0x0859BE7F Get Chip ID... [MT6763] Get SOC ID... [5F200AE7FCC8A2C63DC5E489BBDE668D238DE7F2E0F15914AE 0B5B6561985CCD] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [6] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... error(1) |
05-11-2024, 14:02 | #4 (permalink) |
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Selected model: OPPO CPH1827 (OPPO A83) Operation: Erase FRP And Wipe Software version: 6.9 Erasing of partitions can damage your device. Make sure that you have a backup created. Continue? YES Work ID: 28075692 Connect phone in BROM Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0690 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA01, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6763] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0690 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA01, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6763] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x8B211C94, 0x5BE0C9CB, 0x28B137E9, 0x0859BE7F Get Chip ID... [MT6763] Get SOC ID... [5F200AE7FCC8A2C63DC5E489BBDE668D238DE7F2E0F15914AE 0B5B6561985CCD] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [6] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... error(1) |
05-11-2024, 16:30 | #6 (permalink) |
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Selected model: OPPO CPH1729 (OPPO A83) Operation: Wipe Data Software version: 6.9 There is a risk of data loss. This procedure will erase all User Data Make sure that you have a backup created. Continue? YES Work ID: 28097308 Connect phone in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0690 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA01, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6763] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0690 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA01, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6763] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x8B211C94, 0x5BE0C9CB, 0x28B137E9, 0x0859BE7F Get Chip ID... [MT6763] Get SOC ID... [5F200AE7FCC8A2C63DC5E489BBDE668D238DE7F2E0F15914AE 0B5B6561985CCD] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [6] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... error(1) sdone all you instructed and still same |
