02-25-2022, 09:54 | #377 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Africa /Pakistan Age: 29
Member: 2555393 Status: Offline Thanks Meter: 268 | Selected model: Samsung SM-A325F (Galaxy A32) Operation: Remove KG Software version: 2.12 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM20 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM20 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x341FDADA, 0x32551E81, 0x3380937F, 0x96C51903 Get Chip ID... [MT6768] Get SOC ID... [C0848FF045EE29D98B2FCDD6145233E6493EF1F2A31DF8B1C0 2DAD177FC90319] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A39533910163D2B45986F Load EMI from phone... Skip Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [1] Trying EMI [72ECA8F6, 4C76F2A3, 1A304479, 154C2947, 8CE8F9F2, 7161197D, F1ADA01B, 4ECF8C5A] Init EXT RAM... error(2) |
02-28-2022, 04:02 | #380 (permalink) |
Freak Poster Join Date: Mar 2008 Location: australia
Member: 721542 Status: Offline Thanks Meter: 56 | Australian single sim OPPO A16s network unlock error Selected model: OPPO CPH2271 (Oppo A16s) Operation: Unlock network Software version: 2.12 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x2099EF29, 0x86DBA578, 0x6332E5B1, 0x38919889 Get Chip ID... [MT6765] Get SOC ID... [5136AE111891D50A02A8BA9D80D7CFDB912EAFD0D68AF138DE 711861CBFFC3A1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E0310058F0398D1 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E0310058F0398D1 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6765 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Thu Aug 26 18:25:56 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-08-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1629972801817 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(1) |
03-01-2022, 18:15 | #381 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Pakistan
Member: 2680797 Status: Offline Thanks Meter: 44 | Tecno CG6j (Camon 17) Read Flash Info Failed .... Tecno CG6j (Camon 17) Read Flash Info Failed .... Code: Selected model: Tecno CG6j (Camon 17) Operation: Read Flash Info :confused: :confused: Software version: 2.12 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM30 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xBC931853, 0x29B0FF30, 0xC8F8A6B8, 0x0A1B7834 Get Chip ID... [MT6768] Get SOC ID... [CEBF71D090152F576C55CB3F17A8CC268294E3FE866F35CA4895950CC1155EA6] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x15010033563643414202B2E0DCFF28D7 Load EMI from phone... Skip Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [1] Trying EMI [C41C94FB, 40457DA8, D8F5BD39, F83EEC01, AD4E4796, 4C76F2A3, 85DF9841, 154C2947, 1A304479, F1ADA01B, AF66D99A, 72ECA8F6] Init EXT RAM... error(2) |
03-08-2022, 03:12 | #387 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2688323 Status: Offline Sonork: 654321 Thanks Meter: 0 | ZTE M901C Q529T LG G3 These models worked in version 2.11, but not after update to 3.0 The last is such a reminder, hope to repair as soon as possible Load EMI from phone... OK Init DRAM... OK Enable DRAM... OK Sync with DA... Exception: Invalid pointer operation |
03-08-2022, 09:17 | #388 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2043898 Status: Offline Thanks Meter: 0 | Hello Pandora Box Dev Team, i need support for imei repair on mine realme x7 pro 5g // rmx2121 , it's already possible and supported? Last edited by adle18; 03-08-2022 at 09:27. |
