03-09-2022, 08:09 | #392 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Uzbekistan,Tashkent
Member: 2111301 Status: Offline Sonork: 1651880:UzjavaAzizbek Thanks Meter: 63 | after repair error not repaired and factory wipe data delete imei , error soft please fix this problem Selected model: Xiaomi M1804C3DG (Redmi 6) Operation: Repair Software version: 3.0 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM240 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xEEE55113, 0x6480235A, 0xD7BA5013, 0x46E62434 Get Chip ID... [MT6765] Get SOC ID... [B84FF17BA8407421E1C64C518EA3F685ECCE72685CF633F926 C33270A93CEB2E] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E53304A39423710062D82E085A7 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E53304A39423710062D82E085A7 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x00C0000000 (3,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : xiaomi Product Manufacturer : Xiaomi Product Model : Redmi 6 Product Name : cereus Product Device : cereus Board Platform : MT6765 Build ID : O11019 Build Date : Thu Dec 6 00:25:27 WIB 2018 Display ID : O11019 Security Patch : 2018-11-01 Version SDK : 27 Version Release : 8.1.0 Version Codename : REL Firmware Version : 8.12.6 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 00000000 IMEI 2: 000000000 Repairing IMEI... IMEI 1: 8634 IMEI 2: 8627 Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Now use "Patch Cert" option to comlete repair. |
03-13-2022, 10:21 | #397 (permalink) |
Junior Member Join Date: May 2019 Location: Quetta pakistan
Member: 2907982 Status: Offline Sonork: hammadjaan786 Thanks Meter: 3 | repairing redmi phones or some oppo phones giving this error Write partition "nvdata"... error(STATUS_SEC_WRITE_DATA_NOT_ALLOWED |
03-14-2022, 01:37 | #398 (permalink) |
Registered User Join Date: Apr 2015 Location: Cuba
Member: 2381725 Status: Offline Thanks Meter: 126 | Selected model: TCL A507DL (TCL A2) Operation: Unlock network Software version: 3.0 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x95665F6E, 0xDE21953D, 0x626B534F, 0xC9517253 Get Chip ID... [MT6761] Get SOC ID... [4446002998826CC5589748F55EB8076FB9AE7F7A9F5401A500 E21F6402F1828D] Get sec config... OK [000000E0] Get hw mode... OK Load DownloadAgent... OK Search DA... OK [5] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100474436424D42017FEDD28B2775 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100474436424D42017FEDD28B2775 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A500 (233.25Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : TCL Product Manufacturer : TCL Product Model : A507DL Product Name : A507DL Product Device : Seoul_TF Product Board : Seoul_TF Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Fri Jul 3 08:45:25 CST 2020 Display ID : QP1A.190711.020 release-keys Security Patch : 2020-07-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : vD7K-0 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(4) |
03-14-2022, 01:38 | #399 (permalink) |
Member: 2381725 Status: Offline Thanks Meter: 126 | Selected model: TCL A509DL (TCL A3) Operation: Unlock network Software version: 3.0 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xA5E3AB28, 0xB50A35DA, 0x5F788451, 0x0C369730 Get Chip ID... [MT6765] Get SOC ID... [09C3FBF8C00AB84E73711337AF172F0617F356DD13074ED0BC 41B758FA62DC69] Get sec config... OK [000000E0] Get hw mode... OK Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445836384D42094C28E4DF983F Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445836384D42094C28E4DF983F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : TCL Product Manufacturer : TCL Product Model : A509DL Product Name : A509DL Product Device : Bangkok_TF Product Board : bangkok_TF Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Wed Sep 29 17:40:42 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-10-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : vL7G Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(4) |
03-17-2022, 06:40 | #405 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MOON Age: 43
Member: 174173 Status: Offline Thanks Meter: 115 | Add flash brom samsung .tar .md5 Add repair imei Lg Add support for unlock REVVL 2 METRO TMOBILE REVVL 2 PLUS METRO TMOBILE 5032W 3V METRO TMOBILE 5002C AT&T CRICKET 5004C AT&T CRICKET 5005R AT&T CRICKET 5008R AT&T CRICKET 5002R AT&T CRICKET 5004R AT&T CRICKET REVVL 4 5007Z/5007W TMOBILE METRO 5087Z/5087W TCL 20 XE TMOBILE, METRO, BOOST TMOBILE REVVL V+ 5G WTCELERO5G CELERO 5G TMOBILE REVVL V CRICKET DREAM 5G EC211001 CRICKET SPLENDOR EC211002 AT&T RADIANT MAX 5G EA211001 AT&T MOTIVATE 2 EA211002 CRICKET OVATION 2 EC1002 AT&T MAESTRO MAX EA1002 NOKIA C2 TENNEN TAVA TA-1226 TA-1218 AT&T CRICKET NOKIA C5 ENDI TA-1222 AT&T CRICKET U304AA RADIANT CORE AT&T U325AC RADIANT CORE CRICKET U318AA RADIANT CORE AT&T U705AA RADIANT CORE AT&T U705AC RADIANT CORE CRICKET U202AA MAESTRO AT&T U202AAC CRICKET |
