11-13-2021, 10:35 | #272 (permalink) |
Insane Poster Join Date: Sep 2019 Location: pakistan
Member: 2927217 Status: Offline Thanks Meter: 13 | when will b fix jazz digit 4g unlock bugs fix ( after unlcok show craked software and shut down) but no updates also when formate oppo sets its stuck in recovery permonently and restart again and again lots of bugs @blang sir please pandora is new hardware and tool if u can solve these type of problems quickly ur project ill b dead and no one ill purchase take it serisuly, and i am waiting from 2 month of these type of problems , |
11-29-2021, 07:40 | #275 (permalink) |
Junior Member Join Date: Aug 2021 Location: karachi Age: 29
Member: 2995249 Status: Offline Sonork: zaheero.com Thanks Meter: 2 | plzz add oppo imei repair supprt oppo a1k oppo a5s oppo 12 oppo 15 etc |
The Following User Says Thank You to zaheero For This Useful Post: |
11-30-2021, 09:11 | #276 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | need oppo imi repair here log Selected model: OPPO CPH1723 (Oppo F5) Operation: Read IMEI Info Software version: 2.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM71 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM71 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xE1254337, 0x987F0BE7, 0x30FA34FD, 0xC569F4B7 Get Chip ID... [MT6765] Get SOC ID... [E6E81665AF124C314687CA53E36D718F26E87363451005DC84 CE83D1B21A7582] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK Code: EMMC_ID: 0x13014E47314A3952381013E8D970685B Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A3952381013E8D970685B EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6765 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Thu Jul 1 23:36:44 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-06-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1625153051407 Read partitions info from phone... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK IMEI 1: |gÃ͘,‹Pd5ì.¦ìÝ IMEI 2: ?ð-îŽ?èì˜I˜*u‘, Reading IMEI done! |
12-04-2021, 06:42 | #278 (permalink) |
Crazy Poster Join Date: Aug 2019 Location: Douala Age: 34
Member: 2921175 Status: Offline Sonork: lore Thanks Meter: 8 | Please team add oppo a9 imei repair almost 2month now am still waiting for team to add dis model Please add such that tool write new nvs while writing new imei cus I used tool to damage nv on phone. |
12-16-2021, 10:25 | #282 (permalink) |
Junior Member Join Date: Aug 2007 Location: Thailand Age: 36
Member: 562726 Status: Offline Thanks Meter: 43 | Hi, is it possible if you can add oppo unlock? what i attached is oppo a16 cph2269 network lock file is it possible if your team will add network unlock for pandora box and adding a model to your tool will be awesome https://drive.google.com/file/d/1ZZc...cr7Gk3gx9/view Last edited by nong; 12-16-2021 at 10:31. |
12-21-2021, 12:17 | #283 (permalink) |
Crazy Poster Join Date: Aug 2021 Location: Pakistan. Age: 32
Member: 2995638 Status: Offline Thanks Meter: 30 | please add LG k42 models. hi please add all LG MTK based models like LG k42 model = LM-K420EMW please sir add this model soon |
The Following User Says Thank You to naveid0700 For This Useful Post: |
12-23-2021, 09:34 | #284 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Germany, Munich Age: 33
Member: 1389024 Status: Offline Thanks Meter: 12 | Please ADD FileManager Manager for Partition Management. Also the ability to work with a dump. |
The Following User Says Thank You to 666SATAN666 For This Useful Post: |
