08-23-2022, 16:01 | #587 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2809428 Status: Offline Thanks Meter: 0 | Please Add HUAWEI And Honor New Model Like Honor BRT-W09 unlock bootloader When I Use Huawei Unknow give me error Selected model: Huawei DVC-AN20 (Enjoy 20 Pro 5G) Operation: Unlock bootloader Software version: 3.9 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM14 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xD26941F6, 0xAB5524F4, 0xBBAC7FC6, 0xFD8E2670 Get Chip ID... [MT6893] Get SOC ID... [1D29447081BBA7451AB268FD0B9B6A99399AC988325D8B425A B2FC7A20790636] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [19] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): SDINFDK4-128G (1270) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : SDINFDK4-128G UFS_FWVER : 1270 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCD800000 (119.21Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [B] Read product info... OK Product Brand : Honor Product Manufacturer : unknown Product Model : a55_a55 Product Name : a55_a55 Product Device : a55_a55 Build ID : RP1A.200720.011 Build Date : Thu Oct 14 16:58:12 CST 2021 Display ID : System 5.0.0.012(05UH) Security Patch : 2021-08-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : eng.root.20211014.165214 Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... OK Encrypt security data... OK Write security partition to phone... OK Read partitions info from phone... OK Read partitions from phone... OK Checking unlock possiblity... error(L4) Unlock bootloader done! |
08-26-2022, 03:56 | #588 (permalink) |
Junior Member Join Date: Dec 2018 Location: IMPERIAL
Member: 2882601 Status: Offline Thanks Meter: 2 | Need Help. Unlock U316AT Patch Security 2022-03-05 error reading OTP !! Check A/B state... OK Read product info... OK Product Brand : WIKO Product Manufacturer : TINNO Product Model : Wiko U316AT Product Name : U316AT Product Device : U316AT Product Board : U316AT Board Platform : -1 Build ID : RP1A.200720.011 Build Date : Tue Mar 1 22:49:00 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1646146140 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read OTP... error(7) Read OTP... error(1) Unlock... OK [DF1, DF2, GB1, GB2] Write lock info... error(ERR_COMP) |
08-27-2022, 10:20 | #589 (permalink) |
Crazy Poster Join Date: Aug 2019 Location: Douala Age: 34
Member: 2921175 Status: Offline Sonork: lore Thanks Meter: 8 | Hi Team add simunlock for TCL A508DL, no team support this model. Also fixed the issue with redmi after imei repair, bootlooping. Also Add option to force device into Broom mode and force exit broom mode. Thanks |
08-31-2022, 18:38 | #593 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | please add motorola mt devices moto e6 play moto g8 power lite moto e7 moto e6s moto g22 moto g31 frp, imei repair, flash firmware etc.... |
09-18-2022, 01:59 | #600 (permalink) |
Crazy Poster Join Date: Jul 2016 Location: syria
Member: 2597776 Status: Offline Sonork: theking_13 Thanks Meter: 37 | hi z3x team plz try to fix patch cert on some Xiaomi model like note 11 pro and note 11s and note 10 5G after patch cert phone hang on recovery nv data error ! and note 10 5G if patch cert done network not work stable .. plz add patch nvdata or repair network some note 10 5G after reapir imei will have network but can not call and plz add function to remove patch cert . can help without loss data some note 11s after repair imei . wil have imei but win read info imei will show null itry to repair imei and working done . but imei not change like samsung win have patch cert by another tool .. must remove patch cert before repair imei you the first tool do imei patch cert for must mtk phone but now need to fix some bug and do it more stable thanks z3x team . We trust you |
