02-11-2022, 16:59 | #361 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2638870 Status: Offline Thanks Meter: 1 | many tool bugs need to be fixed Selected model: OPPO CPH2269 (Oppo A16) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM11 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... error |
02-17-2022, 10:19 | #363 (permalink) |
No Life Poster Join Date: May 2008 Location: bhakkar Age: 38
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Selected model: Xiaomi M2006C3LG (Redmi 9A) Operation: Unlock bootloader Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x248480DC, 0xA1AEAD6F, 0xBBEB6047, 0x0E4EC16F Get Chip ID... [MT6765] Get SOC ID... [C4A382DF2EBBE1DEA9D8E4D7CAA8811768EEF9DB80974E9014 44DF4780730B09] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100424A54443452091423BA9BB787 Load EMI from phone... Skip Load EMI config from database [DB VER: 192 DB DATE: 01-21-2022] OK [1] Trying EMI [46F6F1CA, 22BA5289, 92392267, EB371E79, C3498624, 7770139F, C0129602, E6CB89A3, CB03FF37, 11593C4B, 33A1CDBE, 7805E65B, DB7E1DC4, E055C125, 6526FBD5] Init EXT RAM... error(2) i always facing this problem plz guide me how can we do it ok ? |
02-23-2022, 11:38 | #365 (permalink) |
Freak Poster Join Date: Dec 2011 Location: pakistan
Member: 1703671 Status: Offline Sonork: 100.1627623 Thanks Meter: 26 | cph1979 have error Selected model: OPPO CPH1979 (Oppo Reno Z) Operation: Read Flash Info Software version: 2.12 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM27 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM27 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x5DA0B7FA, 0xAFD35FEB, 0x187D372F, 0x75AB5BD4 Get Chip ID... [MT6779] Get SOC ID... [60A51624FC5A6206E99C21428BFA0ECDB9DA1F896EB1CFD572 0F165A9C1806E2] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... error(5) |
02-23-2022, 13:11 | #366 (permalink) |
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Selected model: Xiaomi M2006C3LG (Redmi 9A) Operation: Read PTT Software version: 2.12 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x9D67E111, 0x57B59D8C, 0x77E24992, 0x940135DA Get Chip ID... [MT6765] Get SOC ID... [655D5F91DDCAFB34F5BD9066004F974825FDD8B155EB977C5C BC0266AE3317C1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100424A5444345209CD104CD2B725 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100424A5444345209CD104CD2B725 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2006C3LG Product Name : dandelion_global Product Device : dandelion Product Board : dandelion Board Platform : MT6765 Build ID : QP1A.190711.020 Build Date : Tue Feb 23 20:49:04 CST 2021 Display ID : QP1A.190711.020 Security Patch : 2021-02-01 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : V12.0.11.0.QCDMIXM Read partition "preloader"... OK Read partition "pgpt"... OK Read partition "boot_para"... OK Read partition "recovery"... error(8), skip Read partition "para"... error(STATUS_UNSUPPORT_CMD), skip Read partition "expdb"... error(8), skip Read partition "gsort"... error(STATUS_UNSUPPORT_CMD), skip Read partition "ffu"... error(8), skip Read partition "cust"... error(STATUS_UNSUPPORT_CMD), skip Read partition "vbmeta_system"... OK Read partition "vbmeta_vendor"... error(8), skip Read partition "frp"... error(STATUS_UNSUPPORT_CMD), skip Read partition "nvcfg"... error(8), skip Read partition "nvdata"... error(STATUS_UNSUPPORT_CMD), skip Read partition "md_udc"... error(8), skip Read partition "metadata"... error(STATUS_UNSUPPORT_CMD), skip Read partition "protect1"... error(8), skip Read partition "protect2"... error(STATUS_UNSUPPORT_CMD), skip Read partition "seccfg"... OK Read partition "persist"... error(8), skip Read partition "sec1"... error(STATUS_UNSUPPORT_CMD), skip Read partition "proinfo"... OK Read partition "efuse"... OK Read partition "md1img"... error(8), skip Read partition "spmfw"... error(STATUS_UNSUPPORT_CMD), skip Read partition "scp1"... OK Read partition "scp2"... OK Read partition "sspm_1"... OK Read partition "sspm_2"... OK Read partition "gz1"... error(8), skip Read partition "gz2"... error(STATUS_UNSUPPORT_CMD), skip Read partition "nvram"... error(8), skip Read partition "lk"... error(STATUS_UNSUPPORT_CMD), skip Read partition "lk2"... OK Read partition "boot"... error(8), skip Read partition "logo"... error(STATUS_UNSUPPORT_CMD), skip Read partition "dtbo"... OK Read partition "tee1"... OK Read partition "tee2"... error(8), skip Read partition "super"... error(STATUS_UNSUPPORT_CMD), skip Read partition "vbmeta"... error(8), skip Read partition "cache"... error(STATUS_UNSUPPORT_CMD), skip Read partition "userdata"... error(8), skip Read partition "otp"... error(STATUS_UNSUPPORT_CMD), skip Read partition "flashinfo"... error(8), skip Read partition "sgpt"... error(STATUS_UNSUPPORT_CMD), skip Saved to C:/Users/JH%20MOBILE/Desktop/New%20folder%20(3)/DUMP_PARTITIONS_(2022-2-23_14-7-46)/ Dumping Partitions done! not reading file plz see it |
02-24-2022, 09:01 | #370 (permalink) |
Junior Member Join Date: Apr 2019 Location: pakistan punjab sahiwal
Member: 2906305 Status: Offline Thanks Meter: 2 | hello pandora team many people pandora share unlock bootloader other tool autho bypass use other tool untick box auth option start repair job don but plz stop sharing that should not be the case pandora box team need security high for stop sharing |
The Following User Says Thank You to Gsm aliimran For This Useful Post: |
02-24-2022, 09:19 | #371 (permalink) |
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | hello pandora team hello pandora team many people pandora share unlock bootloader other tool autho bypass use other tool untick box auth option start repair job don but plz stop sharing that should not be the case pandora box team need security high for stop sharing |
The Following User Says Thank You to asif123456789 For This Useful Post: |
