07-25-2021, 20:51 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Germany, Munich Age: 33
Member: 1389024 Status: Offline Thanks Meter: 12 | Lenovo TB-7304X not Unlocked Operation: Unlock bootloader Software version: 2.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Get sec config... OK [00000005] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM20 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0x61EE004E, 0xC1C1C935, 0x6D4ABC8D, 0x5BA154A9 Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Read flash info... OK EMMC_ID: 0x150100464536324D4203FBF3F2EDBBE3 Load EMI config from database [DB VER: 164 DB DATE: 07-17-2021] OK [1] Trying EMI [AE1819FF, 5DCFFA1A, AFC1552B, 049461E7] Init DRAM... OK Enable DRAM... OK Sync with DA... OK Wait for DA H/W detection... OK EMMC INFO: EMMC_ID : 0x150100464536324D4203FBF3F2EDC4E3 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x03A3E00000 (14,56Gb) RAM INFO: INT_SRAM: 0x0000020000 (128,00Kb) EXT_RAM : 0x0040000000 (1,00Gb) Not supported library version! |
